    {HowTo} turn on/off your monitor (Time based, PIR/Button, App)
    171 Posts 39 Posters 359.1k Views 54 Watching
    • cruunnerrC
      cruunnerr
      Hey mate,
      you are using this script.
      As i wrote in my post, it was just brainstorming. I never tested this script. :(
      But i can imagine that this will not work… For a Turn_on delay u probably need a loop-function.
      But when i read your posts i can’t find, that u need this :D
      So just try the script from the original 1# post :)
      • B
        blebbens
        Hello,
        I‘m using the PIR python-script-method.
        It is working fine… but, my mirror is installed in a floor, where people are crossing the mirror several times a day without looking at it.
        It would be a helpful solution, if the script switches on the monitor if a person is standing in front of the mirror for 6 seconds.
        Is there a possibility for modifying the script ?
        • cruunnerrC
          cruunnerr
          This will not work with a simple motion detector. Because “standing” is not “motion”. ;)
          Then u would need a light barrier or something like that.
          Or u need to shake your body for 6 seconds in front of the mirror XD
          • M
            MadScientist
            I wouldn’t know how to program it but you could try playing around with a photo resistor like this or this. But I think that will only work if you have constant light conditions. Maybe an IR light barrier with a reflector on the other side would work better.
            No idea if what you want is possible but that would be an awesome project.
            • cruunnerrC
              cruunnerr
              Or use an ultrasonic sensor. You could let it measure the distance and if its under a specific value for a specific time it could turn on the monitor
              • R
                Rec3ptor
                Would you mind sharing how you wired your LED to pin16 in step 2.2 Using PIR-Script for LED_PIN = 16?
                are you using resistors or mosfets etc? im a noob and dont want to break anything.
                • cruunnerrC
                  cruunnerr
                  In my Case I am using a RGB 5050 Stripe. I am using three pins with mosfets and for the software part PIGPIOD.
                  Just like that: https://dordnung.de/raspberrypi-ledstrip/
                  Here are my scripts:
                  monitor on:
                  vcgencmd display_power 1
                  pigs p 17 1
                  pigs p 22 1
                  pigs p 24 1
                  sleep 0.06s
                  pigs p 17 2
                  pigs p 22 2
                  pigs p 24 2
                  sleep 0.06s
                  pigs p 17 3
                  pigs p 22 3
                  pigs p 24 3
                  sleep 0.06s
                  pigs p 17 4
                  pigs p 22 4
                  pigs p 24 4
                  sleep 0.06s
                  pigs p 17 5
                  pigs p 22 5
                  pigs p 24 5
                  sleep 0.06s
                  pigs p 17 6
                  pigs p 22 6
                  pigs p 24 5
                  sleep 0.06s
                  pigs p 17 7
                  pigs p 22 7
                  pigs p 24 6
                  sleep 0.06s
                  pigs p 17 8
                  pigs p 22 8
                  pigs p 24 7
                  sleep 0.06s
                  pigs p 17 9
                  pigs p 22 9
                  pigs p 24 8
                  sleep 0.06s
                  pigs p 17 10
                  pigs p 22 10
                  pigs p 24 9
                  sleep 0.06s
                  pigs p 17 11
                  pigs p 22 11
                  pigs p 24 10
                  sleep 0.06s
                  pigs p 17 12
                  pigs p 22 12
                  pigs p 24 11
                  Monitor off:
                  pigs p 17 12
                  pigs p 22 12
                  pigs p 24 11
                  sleep 0.06s
                  pigs p 17 11
                  pigs p 22 11
                  pigs p 24 10
                  sleep 0.06s
                  pigs p 17 10
                  pigs p 22 10
                  pigs p 24 9
                  sleep 0.06s
                  pigs p 17 9
                  pigs p 22 9
                  pigs p 24 8
                  sleep 0.06s
                  pigs p 17 8
                  pigs p 22 8
                  pigs p 24 7
                  sleep 0.06s
                  pigs p 17 7
                  pigs p 22 7
                  pigs p 24 6
                  sleep 0.06s
                  pigs p 17 6
                  pigs p 22 6
                  pigs p 24 5
                  sleep 0.06s
                  pigs p 17 5
                  pigs p 22 5
                  pigs p 24 5
                  sleep 0.06s
                  pigs p 17 4
                  pigs p 22 4
                  pigs p 24 4
                  sleep 0.06s
                  pigs p 17 4
                  pigs p 22 4
                  pigs p 24 4
                  sleep 0.06s
                  pigs p 17 3
                  pigs p 22 3
                  pigs p 24 3
                  sleep 0.06s
                  pigs p 17 2
                  pigs p 22 2
                  pigs p 24 2
                  vcgencmd display_power 0
                  sleep 0.06s
                  pigs p 17 1
                  pigs p 22 1
                  pigs p 24 1
                  sleep 0.06s
                  pigs p 17 0
                  pigs p 22 0
                  pigs p 24 0
                  R 1 Reply Last reply
                  • richland007R
                    richland007
                    @cruunnerr Hey there great tutorial,
                    I want to use the cronjob to turn on and off the mirror at certain times of the day.
                    My monitor is a DVI monitor so it is connected digitally with a cable that on one end is HDMI that sticks in the Rpi and the other end is a DVI connector that goes in the monitor.
                    When i try the commands you have mentioned;
                    sudo tvservice -o to turn off
                    sudo tvservice -p to turn on
                    vcgencmd display_power 0 to turn off
                    vcgencmd display_power 1 to turn on
                    Both commands for OFF turn off the display however none of the ON commands work right …it does not come on fully!!!
                    Meaning that it is On just no picture… it says DVI = Active VGA - No Signal and the Rpi is working there is just no picture …and no there is no Power Saving feature, i don’t think, because the back light of the LCD i can see is on after the ON command.
                    I send the On and Off commands through Putty ssh but i am also logged in with VNC and the moment you click reboot from VNC (there is nothing on the screen just dark with On LCD back light) the picture comes immediately back on and reboot carries on as usual and the picture is back on!!
                    So i think the Rpi HDMI signal is at fault and not the monitor feature but i may be wrong …what do you think may man??
                    Thank you in advance
                    Denis
                    p.s I read all 11 pages of this thread form the begging to the end with the hopes of finding a solution before bothering you LOL :)
                    • T
                      teitlebot
                      @cruunnerr @Maros
                      Thanks to you guys I finally got it working although for me I needed to use crontab -e because if I edit the ect/ file it doenst work. Also I had to make the two changes @Maros had to make. I changed the pkill to kill and removed the /usr directory. I wish I understood more of what I was doing but it works now. Next question
                      I would also like to remove a specific module that I have called mmm facial recognition during certain hours. Would this be possible?
                      • richland007R
                        richland007
                        @cruunnerr Hey there buddy i know everyone is busy with the holidays coming up and i don’t want to bother you much but in regard to my predicament 2 posts above do you think if i add a cron job to restart the pi at the time i want the screen to be on will be a solution?? And how would i go about adding a restart as a cron job everyday in the morning at 7:30 am for example?/
                        Thank you
                        D
                        T 1 Reply Last reply
                        • cruunnerrC
                          cruunnerr
                          Hey dude,
                          sorry for not answering, but i am only rarely here :(
                          First i would try to edit the config file:
                          sudo nano /boot/config.txt
                          try to uncomment “hdmi_force_hotplug=1” and try to uncomment “config_hdmi_boost=4”
                          maybe play around with some other settings.
                          https://www.raspberrypi.org/documentation/configuration/config-txt/video.md
                          Rebooting the pi once a day is not the best solution :/
                          But however, if necessary:
                          http://www.simsalabim-solutions.net/vademecum/raspberry_pi/setting_up_reboot_cron_job_on_pi
                          Reply Quote 1
                          • R
                            Rec3ptor @cruunnerr
                            @cruunnerr Thanks for the reply, apreciate it. I now have a 5050 LED strip wired up with the mosfets.
                            working with the pir script (removed the module as you advised others)
                            what method did you use to run pigpiod deamon on startup. i added this in my crontab, guess that will do unless theres a better way.
                            @reboot /usr/local/bin/pigpiod
                            • cruunnerrC
                              cruunnerr
                              @Rec3ptor
                              If u followed the guide i posted, your PIGPIOD installation path should be “/usr/local/bin/pigpiod”
                              For autostart when booting u must edit the rc.local. Mine is like this:
                              pi@MagicMirror:~ $ cat /etc/rc.local
                              #!/bin/sh -e
                              # rc.local
                              # This script is executed at the end of each multiuser runlevel.
                              # Make sure that the script will "exit 0" on success or any other
                              # value on error.
                              # In order to enable or disable this script just change the execution
                              # bits.
                              # By default this script does nothing.
                              # Print the IP address
                              _IP=$(hostname -I) || true
                              if [ "$_IP" ]; then
                                printf "My IP address is %s\n" "$_IP"
                              fi
                              iwconfig wlan0 power off &
                              sleep 5 &
                              sleep 10 &
                              /usr/bin/python /home/pi/pir.py &
                              exit 0
                              So enter this via ssh:
                              sudo nano /etc/rc.local
                              and just put this into the file:
                              Mykle1M 1 Reply Last reply
                              Reply Quote 1
                              • Mykle1M
                                Mykle1 Project Sponsor Module Developer @cruunnerr
                                @cruunnerr
                                My nickname for you:
                                King Cron
                                :thumbsup:
                                Reply Quote 1
                                • T
                                  teitlebot @richland007
                                  @richland007 This wont be helpful but I will say I had a similar problem a few months back but now it works. Must be some configuration that changed in the mean time on my pi but I dont know what.
                                  • B
                                    bolish
                                    Hello there,
                                    I’m currently planning my project and will integrate PIR sensor + related 2.1 method through HDMI.There is one thing confusing me :
                                    • we talk about HDMI CEC in method 2.1
                                    • nevertheless, it seems the PIR Sensor module is “only” turning HDMI output off and that is triggering "issues such as “powersaving / no input”.
                                    But is HDMI CEC not allowing us to send a “turn screen off” command to the monitor instead of disabling the rasp. HDMIoutput and relying / hoping on the monitor’s behaviour?
                                    Sorry once more if I mssed the point, but would like to understand before moving forward.
                                    Regards
                                      sdetweil @bolish
                                      @bolish said in {HowTo} turn on/off your monitor (Time based, PIR/Button, App):
                                      as I understand it, not many monitors/tv’s provide support for external power off/on commands…
                                      none of my TV’s used for MM support this…
                                      B 1 Reply Last reply
                                      • B
                                        bolish @sdetweil
                                        @sdetweil Maybe you’re right! I didn’t considered that.
                                        But seems possible, correct? By changing the actual commands to the ones defined by the libcec librairy?
                                          sdetweil @bolish
                                          @bolish I do not know… as I said, none of my TVs support ANY commands to turn off/on…
                                          in my MMM-SleepWake module, I use module.hide() to hide everything, leaving a blank screen… for those devices that do not provide external control…
                                          Reply Quote 1
                                          • B
                                            bolish
                                            OK, I will then try myself when I will receive my stuff and let forums knows if working or not.
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 6 / 9
