    MMM-voice
    voice control
    329 Posts 55 Posters 973.6k Views 50 Watching
      DirkS @iMAGiC
      @iMAGiC i tried that many times. But i changed the word to Jarvis.
      Now the status is just ERROR :(
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @DirkS
        @DirkS hey dirk, try to add debug: true in the config section, this will create a more detailed log. we also can get in touch via pm, then i can help you more and quicker via teamviewer
        • ? Offline
          A Former User
          Been busy the last two weeks, so not had chance to look at MM in a while, still having issues installing the dependencies, truth be told, not my area of expertise, playing with terminal .
          Thus installing them is where i am coming unstuck.
          Mentioned previously failing at Level 1
          "Run command bash dependencies.sh in ~/MagicMirror/modules/MMM-voice/installers directory, to install all dependencies. This will need a couple of minutes.
          Would highly appreciate if anyone can pipe up the actual commands for installation on Mac (Terminal) for these commands…
          e[0m
          \e[96m[STEP 1/6] Installing Packages\e[90m
          sudo: apt-get: command not found
          \e[31m[STEP 1/6] Installing Packages | Failed\e[0m
          NA-3:installers #####$ sudo chmod 777 /Users/billijaywest/MagicMirror/modules/MMM-voice/installers
          NA-3:installers ####$ bash dependencies.sh
          \e[0m
          As i have managed to manually install only Install, but the rest (and always fails at n1) i am stuck on lack of knowledge of the installation.
          • P Offline
            Porkiddo
            Any luck with the ERROR message near the microphone? I have the same and no idea what to do next.
            • bheplerB Offline
              bhepler Module Developer
              @wjdw87 - Looking at the dependencies.sh file, the line it’s failing on is if sudo apt-get install bison libasound2-dev autoconf automake libtool python-dev swig python-pip -y ;
              If “command not found” is your error message, it looks like apt-get is not installed on your Mac.
              • P Offline
                Porkiddo @Porkiddo
                @Porkiddo said in MMM-voice:
                Done, I just restart npm and the error is gone
                  DirkS
                  thanks to @strawberry-3-141 the module works now very good! Hopefully the other module developer will add the voice function!
                    MagicMirrorPi
                    I had a problem with this module too. My first problem was to solve the issue with the usb soundcard. Then i insert the debug line in the config and get some more informations. Now, i say magic mirror and the microphone is blinking and i can say some keywords like HIDE ALL MODULES, and i can see, the module understand me correctly, but do nothing… Anybody know why?
                    • E Offline
                      ealfaror
                      The module works very good! I’m Spanish and I have had to modify some words to improve the results.
                      But, I’ve a question:
                      I want use only the VOICE module. It’s possible to predefine that module when MagicMirror starts?
                      Thanks!
                        strawberry 3.141 Project Sponsor Module Developer @ealfaror
                        @ealfaror Currently it’s not supported. If you want to change it https://github.com/fewieden/MMM-voice/blob/f9eb4cd4bde5c64ef894e8625250c4092aa0d4a7/node_helper.js#L18 this is were you need to change it mode: "VOICE". But keep in mind that manual changes can make trouble by a module update
                        • 6
                        • 7
                        • 8
                        • 9
                        • 32
                        • 33
                        • 7 / 33
