    MMM-BMW-DS (A different kind of weather module)
    65 Posts 13 Posters 64.8k Views 11 Watching
      sdetweil @Mykle1
      @mykle1 easier if u just declare a defaults section in your module.js which has css: 1
      The when it is merged with the user supplied config, there will always be something set.
      Then u don’t need the if/then at all
      • Mykle1M
        I don’t know how I missed that. Thanks again for showing me the error of my ways. :-)
        // Module config defaults.
            defaults: {
                apiKey: "", // Get FREE API key from darksky.net
                tempUnits: "C", // C  or F
                lat: "40.123456", // Latitude
                lng: "-74.123456", // Longitude
                css: "1", // 1=default, 2=Clean, 3=Lord of the Rings, 4=handwriting, 5=Julee, 6=Englebert
                ownTitle: "Current Conditions", // Default = Current Conditions
                useHeader: false, // true if you want a header
                header: "Your Header", // Any text you want. useHeader must be true
                maxWidth: "100%",
                animationSpeed: 3000,
                initialLoadDelay: 4250,
                retryDelay: 2500,
                updateInterval: 5 * 60 * 1000,
        • cirdanC
          cirdan
          Mykle, kids called me at work today. magic mirror is making weird noises. 😀
          Afraid for hardware failure I went home only to find out mmmbmwds had added sounds and it rained for the first time.
          Would you consider building in a config switch to enable/disable sounds?
          Modules MMM-rainfc, MMM-bustimes, MMM-Harmony, MMM-Rijks
            sdetweil
            Rename the mp3 files to something else
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @cirdan
              @cirdan said in MMM-BMW-DS (A different kind of weather module):
              git pull in the MMM-BMW-DS directory and playSounds: "no" in the new config option. :thumbsup:
              Why can’t everything I try to do with modules be that easy?
              cirdanC 1 Reply Last reply Reply Quote 1
              • cirdanC
                cirdan @Mykle1
                @mykle1 tnx for the quick fix.
                (At last peace returns to the grey havens 😁)
                • R
                  RV Knight
                  Hi, sorry about bringing back up this old post. I’m currently having issues with it, it’s displaying in the bottom with acquiring you weather but doesn’t go any further than that. I’ve checked the config as far as I can tell but I’m still having issues, would it be possible to have some help? Thanks
                  Mykle1M 2 Replies Last reply Reply Quote 0
                  • Mykle1M
                    Mykle1 Project Sponsor Module Developer @RV Knight
                    @RV-Knight
                    Please post your config entry for MMM-BMW-DS (in a code block) so I can take a look at it for you. It should look something like this:
                                disabled: false,
                                module: "MMM-BMW-DS",
                                position: "bottom_bar",
                                    apiKey: "123456789123456789", // Your api key from darksky.net
                                    tempUnits: "F", // C of F
                                    lat: '42.123456',
                                    lng: '-74.123456',
                                    css: "2",
                                    playSounds: "no",
                                    header: "Your header",
                                    maxWidth: "100%",
                    You can also start your mirror using npm start dev. Click the Console tab in the window that opens (top left) and report any errors (appearing in RED). You may have to scroll
                    • Mykle1M
                      @RV-Knight
                      Have you made any progress?
                      • LordyL
                        Lordy
                        Great Module, i loved
                        • LordyL
                          Lordy
                          how or where can i enlarge the font and icon?
                          Wie oder wo kann ich die Schrift und das Symbol vergrößern?
                          • LordyL
                            Lordy
                            thanks, I’ve already found (copy and paste in “custom.css”.
                            • Mykle1M
                              Mykle1 Project Sponsor Module Developer @Lordy
                              @Lordy said in MMM-BMW-DS (A different kind of weather module):
                              Glad you found your solution. I post below some of the things you can use in custom.css for anyone that cares.
                              .MMM-BMW-DS .header {
                                color: yellow;                 /* Header color. */
                              .MMM-BMW-DS .image {             /* icon size */
                                 width: 1.75%;
                                 height: 1.75%;
                                 margin-top: 0px;
                                 margin-bottom: -10px;
                              .MMM-BMW-DS .current {
                                color: #FFFFFF;               /* Current text forecast color. Default is white. */
                                font-size: .6em;
                              .MMM-BMW-DS .summary {
                                color: #FFFFFF;               /* General summary text forecast color. Default is white. */
                                font-size: .6em;
                                display: none;                /* uncomment to hide */
                              .MMM-BMW-DS .daily {
                                color: #FFFFFF;               /* Days of the week and hi/lo temp color. Default is white. */
                                font-size: .6em;
                              • Mykle1M
                                Thank you, mate. :thumbsup:
                                • C
                                  cyberphox
                                  Cool module as always. Is there a setting somewhere for the summary?
                                  Mine isn’t showing
                                  • Mykle1M
                                    Mykle1 Project Sponsor Module Developer @cyberphox
                                    @cyberphox
                                    My bad, bro. Was supposed to be showing by default with the ability of hiding the summary via css. So, I made the correction and pushed it to the repo. Do a git pull in the MMM-BMW-DS or install as per the readme and the summary will be displayed by default.
                                    Then, if you want to hide the summary you would add this to your custom.css file.
                                       display: none;
                                    • C
                                      cyberphox
                                      Awesome! That did it! Thanks so much!
                                      • Mykle1M
                                        @cyberphox said in MMM-BMW-DS (A different kind of weather module):
                                        You’re welcome, bro! :thumbsup:
                                        Thanks for pointing that out to me.
                                        • G
                                          gonzonia
                                          With the end of DarkSky API, I’ve forked this and updated it to use PirateWeather. https://github.com/gonzonia/MMM-BMW-PW
                                          All coding credit goes to @Mykle1 . I pretty much just changed the name and a URL. Pirateweather does not support languages though and that was removed.
                                          Cr4z33C 1 Reply Last reply Reply Quote 1
                                          • Cr4z33C
                                            Cr4z33 @gonzonia
                                            @gonzonia any chance you might adapt it for Tomorrow.io (former ClimaCell) users too? :)
                                            G 2 Replies Last reply Reply Quote 0
                                            • 3 / 4
