    MMM-NewsFeedTicker
    94 Posts 15 Posters 92.0k Views 14 Watching
    • justjim1220J
      justjim1220 Module Developer @Cr4z33
      @cr4z33
      what news site is it?
      “Life’s Too Short To Dance With Ugly People”
      Jim Hallock - 1995
      Cr4z33C 1 Reply Last reply
      • Cr4z33C
        Cr4z33 @justjim1220
        @justjim1220 said in MMM-NewsFeedTicker:
        @cr4z33
        It’s
        http://feeds.feedburner.com/SkyitTg24
        and I would like to load
        https://tg24.sky.it/static/images/lv/skytg24_logo_header.png
        as default icon (also because I notice that ALL the news feeds I set don’t show the icon in the scrolling bar).
        Last but not least is it normal that it uses almost 50% of the CPU load? :frowning_face_with_open_mouth:
        I’ve got a Raspberry Pi 3 B+ and a Samsung EVO Plus 32GB micro SD card.
        Mykle1M justjim1220J 2 Replies Last reply
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @Cr4z33
          @cr4z33 said in MMM-NewsFeedTicker:
          It sure is. The Pi struggles with that type of animation. I’m surprised it’s only 50%. You should monitor your CPU temp, as well.
          • Cr4z33C
            Cr4z33 @Mykle1
            @mykle1 said in MMM-NewsFeedTicker:
            So it’s not a matter of not so fast SD card then right?
            I am using a heatsink on it therefore the average temperature so far is between 50° Celsius and 60° Celsius.
            Mykle1M 1 Reply Last reply
            • Mykle1M
              Well, it could be, but that’s unlikely. The CPU load issue has been around for some time and animations, especially marquee animations(scrolling) are the #1 culprit, or I miss my mark. Of course, if you used something more robust than a Pi that has a GPU you’d see a world of difference in the way MM performs.
              • justjim1220J
                @cr4z33
                Apologies, I am working on the issue of using a custom logo if one doesn’t get pulled from the site.
                Please stand by… :smiling_face_with_sunglasses:
                Jim Hallock - 1995
                mumblebajM 1 Reply Last reply
                Reply Quote 1
                • justjim1220J
                  some found sports news that work for those interested…
                  http://www.espn.com/espn/news/story?page=rssinfo for all sports
                  http://www.espn.com/espn/rss/nfl/news for NFL
                  https://www.foxsports.com/rss-feeds for list of all sports
                  https://api.foxsports.com/v1/rss?partnerKey=zBaFxRyGKCfxBagJG9b8pqLyndmvo7UU&tag=nfl for NFL
                  https://www.cbssports.com/xml/rss for all sports
                  https://www.cbssports.com/rss/headlines/nfl/ for NFL
                  https://www.rotowire.com/rss/ for all sports
                  https://www.rotowire.com/rss/news.htm?sport=nfl for NFL
                  I also wanted to add that if you place the newsfeeds in the config, it also works better to place them in the js file as well. Not sure why, but I noticed that it does.
                  So, wanted to pass that on.
                  I am still working on getting a custom logo to show if one does not get pulled from the rss site.
                  Jim Hallock - 1995
                  • Cr4z33C
                    Cr4z33 @justjim1220
                    @Mykle1 thanks for clearing things out.
                    Take your time don’t worry. ;)
                    In the meantime I am going to try too to put everything into the NewsFeeds js and see how things work.
                    Update
                    I saw no improvements by inserting the feeds straight into the JS. :disappointed_face:
                    • Cr4z33C
                      Cr4z33
                      Sorry @justjim1220 I noticed only now that you removed the newsfeed ticker background in your latest screenshots.
                      I would like to try that out and see if performance improves. :)
                      How do you do that?
                      justjim1220J 1 Reply Last reply
                      • justjim1220J
                        @cr4z33
                        In the css file, just change background-color: maroon; to background: none;
                        can be done with the image as well, but that could make the image difficult to see.
                        Jim Hallock - 1995
                        • Cr4z33C
                          Cr4z33 @justjim1220
                          @justjim1220
                          OK, thanks.
                          Update:
                          When not using a background then overall performance improves! :thumbs_up_medium-light_skin_tone:
                          Reply Quote 1
                          • Cr4z33C
                            Cr4z33
                            Although I am using the UTF-8 encoding for ALL of my newsfeeds accented letters (i.e é, à, etc.) and currency symbols (i.e €) are not displayed properly.
                            Any idea why?
                            			module: "MMM-NewsFeedTicker",
                            			position: "bottom_bar",
                            			disabled: false,
                            			//classes: "day_scheduler"
                            			    feeds: [
                            						title: "Hardware Upgrade",
                            						url: "https://feeds.hwupgrade.it/rss_hwup.xml",
                            						encoding: "UTF-8", //ISO-8859-1
                            						className: "myClass",
                            						defaultLogo : ""
                            • justjim1220J
                              you might have better luck using encoding: "ISO-8859-15" or encoding: "ISO-8859-9"
                              The latter one is supposed to work best with European characters
                              Jim Hallock - 1995
                              Cr4z33C 2 Replies Last reply
                              • Cr4z33C
                                Cr4z33 @justjim1220
                                @justjim1220
                                That did the trick thanks. :thumbs_up_medium-light_skin_tone:
                                • justjim1220J
                                  @cr4z33
                                  Yep! Always lad to help! :smiling_face_with_sunglasses:
                                  Jim Hallock - 1995
                                  • C
                                    cyberphox
                                    So is there a way to use this without the scrolling function to ease up on CPU usage?
                                    • Cr4z33C
                                      Cr4z33 @cyberphox
                                      @cyberphox if you don’t want it to scroll then why don’t you use the default newsfeed module of MagicMirror? :thinking_face:
                                      C justjim1220J 2 Replies Last reply
                                      • C
                                        cyberphox @Cr4z33
                                        @cr4z33 I like the logo feature with multiple feeds
                                        • Cr4z33C
                                          Cr4z33 @cyberphox
                                          @cyberphox oh OK.
                                          • Cr4z33C
                                            Cr4z33 @justjim1220
                                            I still got some wrong encodings from time to time, but doing a search it came out that Italian users have to use encoding: "ISO-8859-16" instead.
                                            Reply Quote 1
                                            • 2 / 5
