    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 923.6k Views 74 Watching
    • lavolp3L
      lavolp3 Module Developer @mrdenmark
      @mrdenmark well, you COULD go into the .njk template file and put in an <hr> just above this part
              {# Daily #}
              {% if config.showDailyForecast %}
      or give the forecast-item hourly classes a border-top: 1px solid #cccvia css.
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      • M
        mrdenmark @lavolp3
        @lavolp3
        it worked,thankyou:)
        • lavolp3L
          @mrdenmark thinking about that again the better way would be to give the daily forecast part a border-top in your custom css. That way you would not have to struggle when you want to update the module.
          Let me know if you need help with that.
          • B
            BD0G
            I do. :)
            • lavolp3L
              lavolp3 Module Developer @BD0G
              @BD0G
              The css way is not as easy as I would have assumed.
              All the elements in the forecast belong have “.forecast-item .hourly” classes so are not distinguishable.
              I currently don’t know of a pure css way to get in between them and give the first daily forecast a margin or a border.
              • T
                trividar
                It’s possible to add animated .mov format icons to this module? I have found some amazing icons, but just bevor I buy it i will be shure that it will be working… animated weather icons…
                THX!
                • T
                  TyFusion
                  Hey guys,
                  I’m trying to use this model and this stucks in loading :
                  		  module: "MMM-DarkSkyForecast",
                  		  header: "Weather",
                  		  classes: "default everyone",
                  		  disabled: false,
                  		    		apikey: "xxxxx",
                  		    		latitude: "39,462900",
                  		    		longitude: "-8.473200",
                  		    		iconset: "4c",
                  		    		concise: false,
                  		    		forecastLayout: "table"
                  What 's the problem here?
                  LordyL T 2 Replies Last reply Reply Quote 0
                  • LordyL
                    Lordy @TyFusion
                    @TyFusion said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                    MMM-DarkSkyForecast
                    Installation
                    1)Navigate into your MagicMirror modules folder and execute
                    git clone https://github.com/jclarke0000/MMM-DarkSkyForecast.git.
                    2)Enter the new MMM-DarkSkyForecast directory and execute npm install.                                                       3) reboot
                    Did you follow these instructions?
                    • T
                      ttarzan @TyFusion
                      @TyFusion I think you have to exchange the decimal point for a dot at latitude.
                      Try “latitude: “39.462900”,”
                      LordyL 1 Reply Last reply Reply Quote 1
                      • LordyL
                        Lordy @ttarzan
                        @ttarzan
                        You might be right, I overlook that tonight.
                        • drippyerD
                          drippyer
                          Just wanted to let folks know that DarkSky is no longer accepting new users to the API now that they have been acquired by Apple.
                          • J
                            j.e.f.f Project Sponsor Module Developer
                            Yeah… not sure what I’m going to do about this yet… Need to rewrite my weather module AGAIN due to API going belly-up. Any suggestions on a good, free API?
                            H M 2 Replies Last reply Reply Quote 1
                            • H
                              Hadr1en Project Sponsor @j.e.f.f
                              @j-e-f-f maybe try yr.no ? it’s free :)
                              • N
                                numb3rs
                                https://openweathermap.org/api
                                • J
                                  j.e.f.f Project Sponsor Module Developer @Hadr1en
                                  @Hadr1en @numb3rs Thanks! Will look into both of these.
                                  • T
                                    trividar @j.e.f.f
                                    @j-e-f-f it is possible to use animated icons (4c) for the main icon?
                                    • P
                                      PH1TCH
                                      @j-e-f-f Great module, definitely my favorite weather module so far!
                                      2 things would make it perfect in my opinion: Feels like temperature and sunrise/sunset data.
                                      Do you have any plans to add those in the future?
                                      Thank You!
                                      • M
                                        michaelsfp @j.e.f.f
                                        @j-e-f-f The best replacement for DarkSky that I’ve found is https://www.climacell.co/weather-api/ since its hyper-local. Free tier gets you 30,000 calls/month.
                                        lavolp3L 1 Reply Last reply Reply Quote 1
                                        • Cr4z33C
                                          Cr4z33 @drippyer
                                          @drippyer said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                                          Maybe I shouldn’t say it, but… you can find many working DarkSky API codes around (that can be used simultaneously by more than one user).
                                          Just do a proper search in Google Images and here you go. 😂
                                          • lavolp3L
                                            lavolp3 Module Developer @michaelsfp
                                            @michaelsfp said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                                            This one sounds really interesting! Thanks! Seems to have minutely data for Europe as well which is rare.
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 15 / 17
