    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 916.4k Views 74 Watching
    • Feedy88F Offline
      Feedy88
      OpenWeatherMaps now introduced a new OneCall-API which is similar to the old DarkSky. There is even a table for migrating from DarkSky to OpenWeather. Maybe someone who has coding skills could see rebuild this lovely module? In the end Dark Sky API will be discontinued completely so everyone will need to look out for something else :)
        solei
        @michael5r What is the command line that allows me to reduce the spaces in the “forescast” table?
        cual es la linea de comando que me permite reducir los espacios en la tabla de “forescast”?
          sdetweil @lavolp3
          @lavolp3 @Mykle1 has converted one of his weather modules to climacell.
          I have converted weather on another platform too.
            mm_mtl
            I am having issue it says LOADING…
            here is my config
            module: “MMM-DarkSkyForecast”,
            header: “Weather”,
            position: “top_right”,
            classes: “default everyone”,
            disabled: false,
            apikey: " from climacell*",
            latitude: “45.582152”,
            longitude: “-73.584595”,
            iconset: “4c”,
            concise: false,
            forecastLayout: “table”
            please help :(
              Mykle1 Project Sponsor Module Developer @mm_mtl
              @mm_mtl
              You can’t use a Climacell API key with MMM-DarkSkyForecast.
                mm_mtl @Mykle1
                @Mykle1
                any other key I can use ?
                  @mm_mtl
                  Each module has directions on how to acquire the proper API, or it should. Darksky requires a Darksky API key but they no longer issue free keys. You would have to purchase one in that case. Free Climacell API keys work with modules utilizing Climacell data, and so forth, and so on. You already have a Climacell key. That will work with modules using Climacell data
                  Please refer to the readme file of each module you wish to use
                  • BKeyportB Offline
                    BKeyport Module Developer @Mykle1
                    @Mykle1 They’re not even issuing paid ones. This module is dead to new users as a result.
                      Mykle1 Project Sponsor Module Developer @BKeyport
                      @BKeyport
                      Yes, if you’re talking about Darksky. We were discussing Climacel as well, which does issue free API keys. But you already knew that, being the head investigator of the MM forum.
                      • BKeyportB Offline
                        har har, Mykle. :)
                        You know if anyone has used Climacel data for a module? That looks really promising… (For now, knowing how weather companies get bought up)
                          sdetweil @BKeyport
                          @BKeyport u are joking, right?
                          MMM-Climacell-Hourly
                          MMM-BMW-CC
                          BKeyportB 1 Reply Last reply Reply Quote 1
                          • BKeyportB Offline
                            @sdetweil I’ve been using MMM-WeatherorNot for so long I seriously didn’t know…
                            • E Offline
                              Egnos
                              hello everyone, from today the module doesn’t work anymore.
                              The module remains in “Loading” and on the terminal I have this error:
                              [01.02.2021 12: 56.02.875] [LOG] [MMM-DarkSkyForecast] 1-Feb-21 12:56 ** ERROR ** null
                              Do you know if something has happened?
                              Many Thanks!
                                sdetweil @Egnos
                                @egnos id say the api has finally been turned off as they said would happen
                                  @sdetweil said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                                  Hmm, I don’t know about that, Sammo. My BMW-DS weather is still working using an old Darksky api key. I’ve been waiting for it to fail, knowing the end is near.
                                    sdetweil @Mykle1
                                    @mykle1 hm. i suppose its possible i could be wrong! lol
                                      I was gonna post a 26k png file showing the Darksky api still working but the forum refused.
                                      You’re never wrong, Sam. You’re just not always right. :-)
                                      • E Offline
                                        Egnos @Mykle1
                                        @mykle1 @sdetweil
                                        False alarm! It works again! I don’t know why…
                                        From your posts it seems that the end of this API is near … when will it happen can you advise me with similar graphics?
                                        Thank you very much
                                          sdetweil @Egnos
                                          @egnos they said aug 2020. so, delayed already
                                          • E Offline
                                            Egnos @sdetweil
                                            @sdetweil can you advise me with similar graphics?
                                            Thanks 😉
                                            S nitewing76N 2 Replies Last reply Reply Quote 0
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 16 / 17
