    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 891.4k Views 74 Watching
    • H Offline
      hco125
      @j-e-f-f & @lavolp3
      I figured out the issue…idiot error (me). I typed the config option as “apiKey” instead of “apikey” and it wouldn’t read it as registered. So sorry for taking your time. Works now.
        j.e.f.f Project Sponsor Module Developer @djsunrise19
        @djsunrise19 said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
        Looks very nice. Is there a way to get the “feels like” temperature, too? I can’t find anything about it.
        I’m planning to add it. This is something I’d like as well.
          j.e.f.f Project Sponsor Module Developer @Johans
          @johans said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
          @j-e-f-f
          No, It doesn’t come back.
          I made a new installation on fresh SD card.
          All works fine without installing your module, after that it’s not working anymore.
          Can you try something? Completely remove MMM-DarkSkyForecast (i.e.delete the directory with rmdir -rf MMM-DarkSkyForecast), and comment out the entry in the config. Restart MM. Does your player come back now? If so, try this:
          Reinstall my module using git clone ... but DON’T run npm install in the MMM-DarkSkyForecast directory. All of the dependencies are currently included with Magic Mirror, so it should work as-is.
          Put the DarkSky entry back in your config and restart MM. If everything works then the issue is that my module is installing a different version of one of the dependencies than what is included in MM, and likely is causing the incompatibility with the MMM-Widget module.
          • richland007R Offline
            richland007
            @j-e-f-f Thank you for this nice weather module :)
            I do have a strange occurrence happening however… no matter if i use ca, us, si for units in front of every high temperature number i get a square… the temperature is displayed along with that square … what is that??
            Oh another thing …how can i make the background of your module non transparent/black or semi transparent?? I am trying to use the @Sean MMM-WeatherBackground and the majority of pictures are too bright to read this module.
            • Cr4z33C Offline
              Cr4z33 @j.e.f.f
              This post is deleted!
                richland007
                Any ideas at what those squares are in front of my temperature numbers everybody ?? ;)
                  j.e.f.f Project Sponsor Module Developer @richland007
                  @richland007 said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                  Try this in your custom.css file:
                  .MMM-DarkSkyForecast .module-content {
                    background-color: rgba(0,0,0,0.5);
                  The first three parameters 0,0,0 are the color (in this case black), and the last parameter 0.5 is the level of transparency. Adjust accordingly to suit your needs.
                    No idea why this is happening, but it generally means that the browser is trying to render a character that is outside of the character set.
                    Can you PM me with your config? I wonder if the data is providing those characters.
                    richland007R Cr4z33C 2 Replies Last reply Reply Quote 0
                      richland007 @j.e.f.f
                      @j-e-f-f Thank you for your reply.
                      Do you want my entire MM config.js file or just the MMM-DarkSkyForecast part of it??
                      D
                      • lavolp3L Offline
                        lavolp3 Module Developer
                        EDIT: SORRY, nevermind… small mistake in my latitude gave wrong values…
                        How to troubleshoot modules
                        MMM-soccer v2, MMM-AVStock
                        • Cr4z33C Offline
                          Cr4z33 @j.e.f.f
                          @j-e-f-f any way I can see the wind direction too?
                          • lavolp3L Offline
                            lavolp3 Module Developer @Cr4z33
                            @cr4z33 it is shown if you include
                            concise: false
                            into the config.
                            That’s the way to show more info.
                            If you want to ONLY show the wind direction you would have to manipulate the .js file manually in line 429
                                  windSpeed: Math.round(speed) + " " + this.getUnit("windSpeed") + (!this.config.concise ? " " + this.getOrdinal(bearing) : ""),
                            into
                                  windSpeed: Math.round(speed) + " " + this.getUnit("windSpeed") + " " + this.getOrdinal(bearing),
                            In my case this unfortunately messes up the layout a bit. But it seems to work.
                            Cr4z33C J 2 Replies Last reply Reply Quote 0
                            • Cr4z33C Offline
                              Cr4z33 @lavolp3
                              @lavolp3 said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                              concise: false
                              into the config.
                              That’s already perfect thanks! :thumbs_up_medium-light_skin_tone:
                                D
                                Just the dark sky portion.
                                  jackoliver361
                                  Hey i have your module working but when i also add the MMM-Awsome-alexa module it moves to this location even though ive set it to display in the top_right. It goes into the right location when mmm-awesome-alexa is removed. Any ideas ? 0_1548268916774_problem.JPG
                                    j.e.f.f Project Sponsor Module Developer @lavolp3
                                    Or you can write rules to hide things in your custom.css file. That way your change doesn’t get overwritten by a module update. I’ve wrapped everything in a css class, so you can pick and choose what is displayed. Start MM in dev mode and you can use the inspector to figure out the class names, or examine MMM-DarkSkyForecast.njk to see the HTML layout and the classes applied.
                                    For example, let’s say you wanted the wind direction, but not the max wind speed. First set concise: false in the module’s config. Then hide the max speed as follows:
                                    MMM-DarkSkyForecast .wrapper.tiled .forecast-container .forecast-item .wind-gusts {
                                        display: none;
                                    Make sure to take a look at .MMM-DarkSkyForecast.css to see hoe specific the existing rule is. Yours needs to be at least as specific if you want it to override the default. For example, this would not have worked:
                                    MMM-DarkSkyForecast .wind-gusts {
                                        display: none;
                                    since the existing rule is more specific:
                                        display: block;
                                      j.e.f.f Project Sponsor Module Developer @jackoliver361
                                      @jackoliver361 said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                                      This is strange behaviour… Does this happen regardless of where you specify awesome-alexa to be? For example if you specify that it should be bottom_center does it still mess up Dark Sky?
                                        btorres79
                                        Sorry for this noob question but is it possible to change the temperature display from celsius to farenheit?
                                        • N Offline
                                          nobita @j.e.f.f
                                          from your info " …this module requires MagicMirror version 2.2.0 or later…"
                                          so How can I know my version of Magic Mirror?
                                          Thanks so much
                                            j.e.f.f Project Sponsor Module Developer @btorres79
                                            @btorres79 said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                                            yep. Set units: "us" in your config.
                                            • 6
                                            • 7
                                            • 16
                                            • 17
                                            • 5 / 17
