    [MMM-Remote-Control](v2-dev) Extensible REST API, Dynamic Menus, and Socket Communications, plus other updates
    76 Posts 13 Posters 73.8k Views 13 Watching
    • Cr4z33C Offline
      Cr4z33 @shbatm
      @shbatm I need to replace the monitor ON / OFF commands with these TV ones from the package ‘cec-client’.
      Where do I have to look at?
      TV ON:
      echo on 0 | cec-client -s -d 1
      TV OFF:
      echo standby 0 | cec-client -s -d 1
      TV Status:
      echo pow 0 | cec-client -s -d 1
      • swvalentiS Offline
        swvalenti Project Sponsor @shbatm
        @shbatm said in [MMM-Remote-Control](v2-dev) Extensible REST API, Dynamic Menus, and Socket Communications, plus other updates:
        @nobita said in [MMM-Remote-Control](v2-dev) Extensible REST API, Dynamic Menus, and Socket Communications, plus other updates:
        I have to Remove from jopyth or not
        You can checkout my fork/branch without removing @Jopyth’s by adding a remote:
        $ cd ~/MagicMirror/modules/MMM-Remote-Control
        $ git remote add shbatm https://github.com/shbatm/MMM-Remote-Control.git
        $ git fetch shbatm
        $ git checkout -b shbatm-develop shbatm/develop
        $ npm install
        After that you can switch back and forth using git checkout master and git checkout shbatm-develop
        @shbatm
        I followed this and I am on the dev branch but when I launch the remote in browser I don’t see any of the added features?
          shbatm Module Developer @swvalenti
          @swvalenti Most of the changes are in the background with the API and are enabled by default, but the new front-end features have to be turned on in your config:
              module: 'MMM-Remote-Control'
              // uncomment the following line to show the URL of the remote control on the mirror
              // , position: 'bottom_left'
              // you can hide this module afterwards from the remote control itself
                  customCommand: {},  // Optional, See "Using Custom Commands" below
                  customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
                  showModuleApiMenu: true, // Optional, Enable the Module Controls menu
                  pm2ProcessName: "mm",  // Optional, if you don't use the default PM2 process, provide the name here.
                  apiKey: "",         // Optional, See API/README.md for details
          • Cr4z33C Offline
            Cr4z33 @shbatm
            @shbatm please see my post. ;)
              I am unable to switch back to master after git checkout master in the $ cd ~/MagicMirror/modules/MMM-Remote-Control what am I doing wrong?
              • Cr4z33C Offline
                Cr4z33 @Cr4z33
                @cr4z33 said in [MMM-Remote-Control](v2-dev) Extensible REST API, Dynamic Menus, and Socket Communications, plus other updates:
                TV ON:
                TV OFF:
                TV Status:
                @shbatm so I found out by myself the lines to edit in node_helper.js.
                I can succesfully turn off the TV by using the remote module, but for some unknown reason I can’t turn it on… :thinking_face:
                Running the command from the terminal works perfectly.
                  sdetweil @swvalenti
                  @swvalenti what does the command say? also do git branch to see what branch you are on
                  swvalentiS 1 Reply Last reply Reply Quote 0
                    swvalenti Project Sponsor @sdetweil
                    @sdetweil on the dev branch below is the error
                    git checkout master
                    error: pathspec ‘master’ did not match any file(s) known to git.
                      sdetweil @swvalenti
                      @swvalenti ok, what does git branch say
                        @sdetweil develop
                        • shbatm-develop
                          sdetweil @swvalenti
                          @swvalenti so there is no branch called ‘master’
                            @sdetweil oh boy that is odd, how do I get the master back?
                              sdetweil @swvalenti
                              @swvalenti rename the current folder/directory out of the way, and git clone the remote repo (your fork or his ) again.
                              then get to the right branch, and then copy any modified files from the saved repo into this new copy,
                              once complete, remove the old saved directory
                                sdetweil @swvalenti
                                @swvalenti the master repo has master and develop as branches
                                  shbatm Module Developer @Cr4z33
                                  @cr4z33 try adding them using the customCommands config setting (see the develop branch README.
                                  Cr4z33C 2 Replies Last reply Reply Quote 0
                                  • Cr4z33C Offline
                                    Cr4z33 @shbatm
                                    @shbatm OK thanks I will try that tomorrow.
                                    • Cr4z33C Offline
                                      Cr4z33 @shbatm
                                      I set the dev branch module like the following:
                                      			module: 'MMM-Remote-Control',
                                      			disabled: false,
                                      			customCommand: {
                                      					monitorOnCommand: 'echo on 0 | cec-client -s -d 1',
                                      					monitorOffCommand: 'echo standby 0 | cec-client -s -d 1',
                                      					monitorStatusCommand: 'echo pow 0 | cec-client -s -d 1'
                                      None of the commands are working. :confused_face:
                                      I get the ‘Done’ message, but then nothing happens…
                                      The syntax is 100% correct and working if used in the terminal.
                                        mohace
                                        Hi, I can’t see newsfeed options in Module Controls.
                                        Can you help me please?
                                        • Cr4z33C Offline
                                          Cr4z33 @mohace
                                          @mohace I can.
                                          Double check if you edited anything or try deleting and reinstalling the module?
                                            bolish
                                            Hi @shbatm
                                            I already asked this question on git issues on Jopyth’s version but I just figured out that you are the guy behind the custom menu!
                                            Would it be possible to have an action item for a menu?
                                            I mean, when you click on the menu, it opens the menu but also as the ability to trigger an action.
                                            Regards
                                            • 2 / 4
