    MMM-Globe
    119 Posts 39 Posters 226.9k Views 40 Watching
      schlachtkreuzer6 @binderth
      @binderth niiiice! :)
        @binderth the globe is cut at south pole area, i think the white slice down there is the background color
        so i think the module cut a circle out of the webpage and down there is some part of the earth missing, or out of view. Also i got another issue: If I´m using the random Photo Module as background, i see a small black border around the full globe. So to fix that, there must be an adjustment for the size of the cutting circle. But anyway the main problem with that white slice is, the image source.
        SvenSommerS 1 Reply Last reply Reply Quote 0
          shgmongohh @binderth
          @binderth
          If I have a bit more time, I’d like to add the standard ones and make a pull request to choose from. There’s a list of (near) real-time images from EUMETSAT: http://oiswww.eumetsat.org/IPPS/html/latestImages.html
          Very nice work!
          It would be awesome, if you could add the real time images!
          Sebastian
          S 1 Reply Last reply Reply Quote -1
            schlachtkreuzer6 @shgmongohh
            @shgmongohh that would be awesome! thank you in advance :)
            • SvenSommerS Offline
              SvenSommer @schlachtkreuzer6
              @schlachtkreuzer6
              Hey guys,
              I was able to cut the white bar by cutting the last pixels (depending on the image size) from this image with adding the following to MMM-Globe.js
              getDom: function () {
                  if (this.config.style == "europeDiscNat") {
              	wrapper.style.height = 0.98 * this.config.imageSize - 1 + "px";
              	wrapper.style.overflow = "hidden";
                  var image = document.createElement("img");
                schlachtkreuzer6 @SvenSommer
                @SvenSommer Nice work! Thanks. Post it on github as well :)
                  @schlachtkreuzer6
                  done, I also included the sources from binderth and made a pull request.
                  L L 2 Replies Last reply Reply Quote 1
                  • L Offline
                    LukeCodewalker Module Developer @SvenSommer
                    @SvenSommer
                    could you please adjust the README.md that it contains your additional image-styles? then i will merge your pull request =)
                    thanks for your help improving the module
                    • L Offline
                      lolobyte @SvenSommer
                      @SvenSommer
                      Wrong, the picture source information was from me.
                      You can read my first entry above the post from @binderth !
                        SvenSommer
                        @lolobyte
                        Sorry. So, thank you for this excellente source!
                        @LukeCodewalker
                        readme is adjusted.
                        • L Offline
                          @SvenSommer
                          Merged! Thank you
                            binderth
                            so great coming home from skiing and everything is already fixed and commited! Thanks, guys!
                            looks awesome!
                              Burner911
                              This is awesome! Any chance of a view with North America centric? @LukeCodewalker
                                schlachtkreuzer6 @Burner911
                                @Burner911 if you find some image source :D
                                • L Offline
                                  lolobyte
                                  Here are some needful sources
                                  http://earthdirectory.net/gsat
                                  http://goes.gsfc.nasa.gov/
                                    SvenSommer @lolobyte
                                    @lolobyte
                                    Thank you for the links.
                                    For central america I found the following source the most usefull. Unfortunately it’s only available in high resulution.
                                    http://goes.gsfc.nasa.gov/goescolor/goeseast/overview2/color_lrg/latestfull.jpg
                                    alt text
                                    Has anybody found more usefull sources by now?
                                      Burner911
                                      @SvenSommer That is the exact image I found as well. Any chance we could make this work @LukeCodewalker?
                                      L SvenSommerS 2 Replies Last reply Reply Quote 0
                                      • I Offline
                                        in_a_days
                                        Hopefully we’ll have a new feed from GOES-16 soon as well!
                                        http://gizmodo.com/the-most-advanced-weather-satellite-yet-just-dropped-it-1791527000
                                        What ship would bear me ever back across so wide a Sea?
                                        • L Offline
                                          LukeCodewalker Module Developer @Burner911
                                          @Burner911 sure :) should be straight forward. I you know how to do it feel free to make a pull request. If not I can have a look at the weekend if I find some time.
                                            SvenSommer @Burner911
                                            This post is deleted!
                                            • 6
                                            • 2 / 6
