    MMM-RAIN-MAP (new: version 2.x)
    193 Posts 39 Posters 309.3k Views 42 Watching
      pminich @sdetweil
      @sdetweil All set, thanks. Still learning my way around npm, git, etc…
      • O Offline
        ossman
        Seems like we’re in the same Boat! Weirdly enough, it hasn’t rained today. I’ll have an eye on it once it starts again!
        • K Offline
          kevsfastz
          Is it possible to add a layer for tropical storm/hurricane tracks similar to how NHC does with their ‘interactive map’?
          https://www.nhc.noaa.gov/refresh/graphics_at1+shtml/122110.shtml?gm_track#contents
          • plainbrokeP Offline
            plainbroke @Jalibu
            @Jalibu said in MMM-RAIN-MAP (new: version 2.x):
            A few days ago, Openstreepmap obviously made some changes with their tile servers. They seem to block requests now, when the requests come from Electron applications. This is the case in most MagicMirror installations. As a consequence, MMM-RAIN-MAP does not show map tiles anymore.
            I suspect, that also other modules are effected.
            One possible fix is using another tile server for MMM-RAIN-MAP. One that still works at the moment, is the German fork “https://a.tile.openstreetmap.de/${z}/${x}/${y}.png”.
            I will adjust the module soon, to use this tile server as a default.
            You can also change the tile server by setting this property in the module config:
              mapUrl: "https://a.tile.openstreetmap.de/${z}/${x}/${y}.png"
            How do I go about getting that for the usa in particular kansas.?
            JalibuJ 1 Reply Last reply Reply Quote 0
            • JalibuJ Offline
              Jalibu Module Developer @plainbroke
              @pminich the same way. The German fork contains world wide map data.
                plainbroke @Jalibu
                @Jalibu
                Ok it finally found my location.
                The Lon and Lat where not registering in the module for some reason now they are… So all is good again…
                  sdetweil @plainbroke
                  @plainbroke said in MMM-RAIN-MAP (new: version 2.x):
                  system is case sensitive, and " (quotes) around numbers become strings, which cause problems all over the place
                  • O Offline
                    Oboudreaux
                    Does “substitudeModules” work in server only mode? “displayOnlyOnRain” works just fine but when the rain map pops up it appears under the module it’s supposed to hide.
                    • H Offline
                      hogedir
                      I have an issue, I want to setup rain map to france, but I have that : NO MAP at all (with openmap) can you help me please? thanks.
                      • JalibuJ Offline
                        Jalibu Module Developer @hogedir
                        @hogedir can you please create an issue on github for that? Without further information (config, version) it is hard to find the reason 😉
                        • H Offline
                          hogedir @Jalibu
                          @Jalibu ok no problem. can you indicate me where i can find some logs for this module especially?
                          • JalibuJ Offline
                            @hogedir in the Browser‘s console log and net tab
                            • H Offline
                              hogedir
                              @Jalibu it’s simply a raspi 4B 8GB, with a normal installation of MMM. I don’t know if i need to open a bug, it’s just the dump of the map that doesn’t work as you see on the screen.
                              A question : Your module accept FRENCH locations no for the rain map ?
                              Your module works well here, it’s only the map that is not get.
                              I don’t have any blocker in the dns. so I don’t undertand because all the other modules works fine, except of that map dump.
                              Here is my config.js :
                              module: “MMM-RAIN-MAP”,
                              position: “top_center”,
                              animationSpeedMs: 400,
                              colorScheme: 2,
                              colorizeTime: true,
                              defaultZoomLevel: 8,
                              displayTime: true,
                              displayTimeline: true,
                              displayClockSymbol: true,
                              displayHoursBeforeRain: -1,
                              extraDelayLastFrameMs: 1000,
                              extraDelayCurrentFrameMs: 3000,
                              // markers: [
                              // { lat: 49.41, lng: 8.717, color: “red” },
                              // { lat: 48.856, lng: 2.35, color: “green” },
                              // mapPositions: [
                              // { lat: 8.717, lng: -2.725, zoom: 9, loops: 1 },
                              // { lat: 8.717, lng: -2.725, zoom: 6, loops: 2 },
                              // { lat: 48.856, lng: 2.35, zoom: 6, loops: 1 },
                              // { lat: 48.856, lng: 2.35, zoom: 9, loops: 2 },
                              // { lat: 49.15, lng: 6.154, zoom: 5, loops: 2 },
                              // mapUrl: “https://a.tile.openstreetmap.de/48.2649/{x}/{y}.png”,
                              mapUrl: “https://a.tile.openstreetmap.de/#map=8/48.471/-2.725”,
                              // mapUrl: “https://tiles.wmflabs.org/bw-mapnik/8/48.471/-2.725”,
                              mapHeight: “420px”, // must be a pixel value (no percent)
                              mapWidth: “420px”, // must be a pixel value (no percent)
                              maxHistoryFrames: -1,
                              maxForecastFrames: -1,
                              substitudeModules: [],
                              updateIntervalInSeconds: 300,
                              • JalibuJ Offline
                                @hogedir your configuration is buggy. Please read the module’s Readme.
                                You don’t have to (and should not) change the mapUrl at all.
                                Use mapPositions to justify it. The module should work world-wide.
                                I’d recommend to use the default values whenever possible and just to set values you need to override.
                                Does that work for you?
                                 module: "MMM-RAIN-MAP",
                                 position: "top_center",
                                  mapPositions: [
                                   { lat: 48.472, lng: -2.725 }
                                • H Offline
                                  hogedir @Jalibu
                                  @Jalibu Thanks. I copied your code, and nothing again. No map.
                                  S JalibuJ 2 Replies Last reply Reply Quote 0
                                    sdetweil @hogedir
                                    @hogedir can you show the messages at mm startup?
                                    either npm start or if you use pm2, then
                                    pm2 logs --lines=50
                                    • JalibuJ Offline
                                      @hogedir I noticed there were wrong double quote characters in the code of my last post.
                                      Please try again with the code below. Otherwise, please open an issue on GitHub and provide all the information asked in the form (entire config & logs)
                                        mapPositions: [
                                      • H Offline
                                        hogedir
                                        @hogedir @Jalibu it’s working now Thanks ! : the map is showing well now BUT the rain is not showed very well !
                                        I compared what i see outside of my home and we had 5minutes before some rain and your data flow is not precise at all, i did not saw a rain in my region on your map but i saw it in weatherplaza.
                                        I give you the page which is more precise and realistic than the rain data you have in the module : https://www.weerplaza.nl/regenradar/europa/frankrijk/
                                        Map of rains with weather plaza : :
                                        Map of rains with your module : :
                                        Lots of difference, weather plaza is realistic (i checked outside 2 times yesterday, your module did not show well the rain.)
                                        • Second thing, I noticed something too : i want the “pause” time before the red zone to be more fast (some mms more fast). is it possible to change the “pause timer” ? Thanks
                                        • H Offline
                                          hogedir @Jalibu
                                          @Jalibu Look Here is the map of Weatherplaza (meteoplaza) in the same time than yours, if it can help.
                                          and then the data flow on the module (less rain and less precise) :
                                          thanks
                                            sdetweil @hogedir
                                            @hogedir it’s not ‘his’ data. he is requesting a graphic from a service, and displaying what they give.
                                            H 2 Replies Last reply Reply Quote 0
                                            • 10
                                            • 9 / 10
