    Not really a mirror at all - but is really helpful
    Scheduled Pinned Locked Moved Showcase
    24 Posts 10 Posters 40.8k Views 20 Watching
      dinkybluebug245 @yawns
        @yawns Ive uploaded my version of calendar.js to github. access it here : https://github.com/dinkybluebug/MMM-CustomCSSv2
        It has amended javascript for calendar to show day of week and time.
        D Y 2 Replies Last reply Reply Quote 2
          dinkybluebug245 @dinkybluebug245
          I had installed the remote control module too, and tweaked it slightly, so I can move between Normal and Party mode, instead of using bash scripts via SHH
          0_1479750249211_upload-7516ce5e-a72d-486b-b4ae-75f901144e0c
          • Y
            yawns Moderator @dinkybluebug245
            @dinkybluebug245 said in Not really a mirror at all - but is really helpful.:
            Thanks for this, very much appreciated!
            • MichMichM
              MichMich
              I really really really like your setup! :) Nice work!
                dinkybluebug245 @MichMich
                @MichMich Thanks Michael - Im new to all this - so appreciate your comment
                  schlachtkreuzer6 @dinkybluebug245
                  @dinkybluebug245 hey nice work! What did you change in the remote control module to switch between partymodus and normal?
                    dinkybluebug245 @schlachtkreuzer6
                    @schlachtkreuzer6 In Nodehelper.js - I changed lines 104-117. I didnt need the option of monitor on and off, as I have a PIR sensor attached to my display.
                    if (query.action === 'MONITORON')
                    			exec('cp ../MagicMirror/css/party_custom.css ../MagicMirror/css/custom.css', opts, function(error, stdout, stderr){ self.checkForExecError(error, stdout, stderr, res); });
                    			exec('cp ../MagicMirror/config/party_config.js ../MagicMirror/config/config.js', opts, function(error, stdout, stderr){ self.checkForExecError(error, stdout, stderr, res); });
                    			exec('pm2 restart mm', opts, function(error, stdout, stderr){ self.checkForExecError(error, stdout, stderr, res); });
                    			return true;
                    		if (query.action === 'MONITOROFF')
                    			exec('cp ../MagicMirror/css/normal_custom.css ../MagicMirror/css/custom.css', opts, function(error, stdout, stderr){ self.checkForExecError(error, stdout, stderr, res); });
                    			exec('cp ../MagicMirror/config/normal_config.js ../MagicMirror/config/config.js', opts, function(error, stdout, stderr){ self.checkForExecError(error, stdout, stderr, res); });
                    			return true;
                    As the functions had changed, I then changed the text displayed in the app , by changing the text in the remote.html file. Line 80- 87
                                   <div id="monitor-on-button" class="menu-element button main-menu">
                                        <span class="fa fa-fw fa-glass" aria-hidden="true"></span>
                                        <span class="text">Party Mode</span>
                                    </div>
                                    <div id="monitor-off-button" class="menu-element button main-menu">
                                        <span class="fa fa-fw fa-calendar" aria-hidden="true"></span>
                                         <span class="text">Calendar Mode</span>
                                    </div>```
                      Bangee Module Developer
                      nice work! :-)
                      • N
                        nobita @dinkybluebug245
                        @dinkybluebug245 , I Would like to know what is your forecast weather module? It not like from openweathermap.org , Thanks so much your kinds
                        • Y
                          yawns Moderator
                          According to his config on github he uses MMM-WunderGround
                          • N
                            nobita
                            How to Build frame around MMM-WunderGround and Calendar,Thanks for your help
                            • Y
                              yawns Moderator @nobita
                              @nobita
                              Please take a look at his css file, escpacially this part:
                              .calendar, div#module_2_MMM-WunderGround table.small {
                              	background-color: rgba(63, 182, 236, 0.23);
                                  border-radius: 10px;
                              	padding: 10px;
                              	box-shadow: 5px 5px 5px 1px #d3d3d3;
                              Add these to your custom.css file and play around with it
                              johnnyboyJ 1 Reply Last reply Reply Quote 2
                              • L
                                lucallmon
                                Could you please write a more detailed Readme file on how to install and how to make adjustments to MMM-Remote-Control? I’d like to do this for a display in my kitchen as well but I’m a NOOB and some of the stuff you mention just doesn’t make sense to me. Thanks.
                                • johnnyboyJ
                                  johnnyboy @yawns
                                  @yawns
                                  Cant see picture of his mirror… can you add it again please?
                                  • Y
                                    yawns Moderator @johnnyboy
                                    @johnnyboy said in Not really a mirror at all - but is really helpful:
                                    @yawns
                                    Done
                                    • joela85J
                                      joela85
                                      I really like what you’ve done here, and am looking to do something similar.
                                      I’ve got a touchscreen monitor so firstly wondering if I can have them on different pages and swipe between them.
                                      I would also like this if I could have a slideshow playing and then when music played on my sonos speakers then that module would show instead of the slideshow, or over the top of?
                                      Anyone have any ideas?
