    Not really a mirror at all - but is really helpful
    Scheduled Pinned Locked Moved Showcase
    24 Posts 10 Posters 41.1k Views 20 Watching
      dinkybluebug245 @yawns
      thanks - Uploaded the code here.
      https://github.com/dinkybluebug/MMM-CustomCSSv2
      Y 1 Reply Last reply
      Reply Quote 2
      • Y
        yawns Moderator @dinkybluebug245
        @dinkybluebug245
        maybe a dumb question, but what did you do to the calendar module to make it show the day and the time for each entry?
        D 1 Reply Last reply
          • Y
            @dinkybluebug245
            it looks like this.
            If I change it to timeFormat: 'absolute' I see the real date (e.g. November 26th) but still no time.
            D 2 Replies Last reply
                @yawns Ive uploaded my version of calendar.js to github. access it here : https://github.com/dinkybluebug/MMM-CustomCSSv2
                It has amended javascript for calendar to show day of week and time.
                D Y 2 Replies Last reply
                Reply Quote 2
                  dinkybluebug245 @dinkybluebug245
                  I had installed the remote control module too, and tweaked it slightly, so I can move between Normal and Party mode, instead of using bash scripts via SHH
                  0_1479750249211_upload-7516ce5e-a72d-486b-b4ae-75f901144e0c
                  • Y
                    @dinkybluebug245 said in Not really a mirror at all - but is really helpful.:
                    Thanks for this, very much appreciated!
                    • MichMichM
                      MichMich
                      I really really really like your setup! :) Nice work!
                        dinkybluebug245 @MichMich
                        @MichMich Thanks Michael - Im new to all this - so appreciate your comment
                          schlachtkreuzer6 @dinkybluebug245
                          @dinkybluebug245 hey nice work! What did you change in the remote control module to switch between partymodus and normal?
                            dinkybluebug245 @schlachtkreuzer6
                            @schlachtkreuzer6 In Nodehelper.js - I changed lines 104-117. I didnt need the option of monitor on and off, as I have a PIR sensor attached to my display.
                            if (query.action === 'MONITORON')
                            			exec('cp ../MagicMirror/css/party_custom.css ../MagicMirror/css/custom.css', opts, function(error, stdout, stderr){ self.checkForExecError(error, stdout, stderr, res); });
                            			exec('cp ../MagicMirror/config/party_config.js ../MagicMirror/config/config.js', opts, function(error, stdout, stderr){ self.checkForExecError(error, stdout, stderr, res); });
                            			exec('pm2 restart mm', opts, function(error, stdout, stderr){ self.checkForExecError(error, stdout, stderr, res); });
                            			return true;
                            		if (query.action === 'MONITOROFF')
                            			exec('cp ../MagicMirror/css/normal_custom.css ../MagicMirror/css/custom.css', opts, function(error, stdout, stderr){ self.checkForExecError(error, stdout, stderr, res); });
                            			exec('cp ../MagicMirror/config/normal_config.js ../MagicMirror/config/config.js', opts, function(error, stdout, stderr){ self.checkForExecError(error, stdout, stderr, res); });
                            			return true;
                            As the functions had changed, I then changed the text displayed in the app , by changing the text in the remote.html file. Line 80- 87
                                           <div id="monitor-on-button" class="menu-element button main-menu">
                                                <span class="fa fa-fw fa-glass" aria-hidden="true"></span>
                                                <span class="text">Party Mode</span>
                                            </div>
                                            <div id="monitor-off-button" class="menu-element button main-menu">
                                                <span class="fa fa-fw fa-calendar" aria-hidden="true"></span>
                                                 <span class="text">Calendar Mode</span>
                                            </div>```
                            Reply Quote 2
                              Bangee Module Developer
                              nice work! :-)
                              • N
                                nobita @dinkybluebug245
                                @dinkybluebug245 , I Would like to know what is your forecast weather module? It not like from openweathermap.org , Thanks so much your kinds
                                • Y
                                  yawns Moderator
                                  According to his config on github he uses MMM-WunderGround
                                  • N
                                    nobita
                                    How to Build frame around MMM-WunderGround and Calendar,Thanks for your help
                                    • Y
                                      yawns Moderator @nobita
                                      @nobita
                                      Please take a look at his css file, escpacially this part:
                                      .calendar, div#module_2_MMM-WunderGround table.small {
                                      	background-color: rgba(63, 182, 236, 0.23);
                                          border-radius: 10px;
                                      	padding: 10px;
                                      	box-shadow: 5px 5px 5px 1px #d3d3d3;
                                      Add these to your custom.css file and play around with it
                                      johnnyboyJ 1 Reply Last reply
                                      Reply Quote 2
                                      • L
                                        lucallmon
                                        Could you please write a more detailed Readme file on how to install and how to make adjustments to MMM-Remote-Control? I’d like to do this for a display in my kitchen as well but I’m a NOOB and some of the stuff you mention just doesn’t make sense to me. Thanks.
                                        • johnnyboyJ
                                          johnnyboy @yawns
                                          @yawns
                                          Cant see picture of his mirror… can you add it again please?
                                          • Y
                                            yawns Moderator @johnnyboy
                                            @johnnyboy said in Not really a mirror at all - but is really helpful:
                                            @yawns
                                            Done
