    MMM-Worldclock
    39 Posts 9 Posters 20.5k Views 9 Watching
      MacG @SoleLo
      @solelo Just try to set the width higher and higher, eventually nothing will overlap anymore. But it will probably be quite wide, with the cities next to the time. Maybe that’s why style: ‘top’ is the better choice.
        sdetweil @SoleLo
        @solelo see this
        https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1632064035932
        u can change the styles livee and then save it to custom.css…
        note that you can doc the dev window at the bottom too, using the 3 dot menu next to the X to close the dev window
          MacG
          A supplement to the development tools. When you open it, you can select “Sources” and pause script execution with the “pause button” or F8 in the lower third. This makes it easier to get through all the style classes, which otherwise update every second.
          • goldyfruitG Offline
            goldyfruit Project Sponsor
            I used to install the original woldclock module, just switched to this one and it worked out of the box.
            Thanks for the work. :clapping_hands:
            Build smart things with magic and love! | https://smartgic.io
              SymmetriC
              How do I center horizontally at the top of the screen instead of left?
                sdetweil @SymmetriC
                @SymmetriC put it in the top_center position
                BKeyportB S 2 Replies Last reply Reply Quote 0
                • BKeyportB Offline
                  @sdetweil or top_bar
                    SymmetriC @sdetweil
                    @sdetweil Thank you! That worked and the solution was easier than I thought! lol
                      JohnGalt
                      @BKeyport, @ulrichwisser and all: Please let me know if the following questions would be better served under a new topic, but since my issues originated with this older module, and the new module shares the same name I thought it appropriate to post under this topic…
                      Issue: the old module is no longer supported by the developer, who suggests using a newer module which uses the same module name. After cloning the new module, the instructions call for doing an ‘npm ci’ command, which fails due to a lack of an existing package-lock,json file.
                      Question: Is there something different I should be doing, o si this something the developer needs to fix?
                      Old module: https://github.com/BKeyport/MMM-Worldclock
                      New module: https://github.com/ulrichwisser/MMM-Worldclock
                      Error Message:
                      pi@mirror1:~/MagicMirror/modules $ cd MMM-Worldclock
                      pi@mirror1:~/MagicMirror/modules/MMM-Worldclock $ npm ci
                      npm ERR! code EUSAGE
                      npm ERR!
                      npm ERR! The `npm ci` command can only install with an existing package-lock.json or
                      npm ERR! npm-shrinkwrap.json with lockfileVersion >= 1. Run an install with npm@5 or
                      npm ERR! later to generate a package-lock.json file, then try again.
                      npm ERR!
                      npm ERR! Clean install a project
                      npm ERR!
                      npm ERR! Usage:
                      npm ERR! npm ci
                      npm ERR!
                      npm ERR! Options:
                      npm ERR! [--install-strategy <hoisted|nested|shallow|linked>] [--legacy-bundling]
                      npm ERR! [--global-style] [--omit <dev|optional|peer> [--omit <dev|optional|peer> ...]]
                      npm ERR! [--strict-peer-deps] [--foreground-scripts] [--ignore-scripts] [--no-audit]
                      npm ERR! [--no-bin-links] [--no-fund] [--dry-run]
                      npm ERR! [-w|--workspace <workspace-name> [-w|--workspace <workspace-name> ...]]
                      npm ERR! [-ws|--workspaces] [--include-workspace-root] [--install-links]
                      npm ERR!
                      npm ERR! aliases: clean-install, ic, install-clean, isntall-clean
                      npm ERR!
                      npm ERR! Run "npm help ci" for more info
                      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2025-08-05T17_16_59_150Z-debug-0.log
                        sdetweil @JohnGalt
                        @JohnGalt npm install then
                          JohnGalt @sdetweil
                          @sdetweil – That’s what I thought. Just did that and it’s working now…
                          Thanks, as always!
                          • BKeyportB Offline
                            BKeyport Module Developer @JohnGalt
                            My version of the module developed a fatal bug that I couldn’t get rid of… The best move was to shut it down.
                              JohnGalt @BKeyport
                              @BKeyport – Sorry to hear that, but thanks for the module while you maintained it.
                              And a big thanks for directing us to another module, and not just leaving it hanging out there!
                              • UncleRogerU Offline
                                UncleRoger
                                @BKeyport
                                Was the altflag option something that was related to the fatal bug in your version? If not, do you think it’s something that could be added to the latest one?
                                • BKeyportB Offline
                                  BKeyport Module Developer @UncleRoger
                                  @UncleRoger No, it wasn’t that. I forgot about that code. I might go back in and grab it and offer it to the other version once updated.
