    MMM-Worldclock
    39 Posts 9 Posters 24.1k Views 9 Watching
    • BKeyportB
      BKeyport Module Developer @MacG
      @macg They went for the biggest city in the timezone. I’m annoyed by that too. Los Angeles shouldn’t represent all of Pacific Time, damnit.
        SoleLo @MacG
        @macg can you share how you got them to be horizonal?
        M 1 Reply Last reply
          MacG @SoleLo
          @solelo With the first eight lines of the posted snippet of my custom.css, you get the horizontal representation. Copy them into your custom.css and adjust the pixel width.
          @BKeyport Pick Vancouver or the time zone itself (PST8PDT). :winking_face: That’s why I found the list of possibilities so helpful.
          @sdetweil Yes, I had chosen the Windy City then, too.
            SoleLo @MacG
            @macg Thanks! I added it to my custom.css but it didn’t change. Is there anything else I should be checking?
              MacG @SoleLo
              @solelo Actually, no. For completeness here are my settings from config.js:
              			module: 'MMM-Worldclock',
              			position: 'top_left', // This can be any of the regions, best in top_left or top_right regions
              				timeFormat: 'HH:mm', //Global time format, as defined in moment.js format()
              				style: 'top', // Which way do you want the flag and description from the clock? choices are 'top', 'left','right','bottom'
              				offsetTimezone: null, // Timezone you want to show the difference from. null, "", or omitted from config will be UTC.
              				clocks: [
              						title: "Weltzeit",
              						timezone: "UTC",
              						// timeFormat: "HH:mm MM/DD", // Time format override.
              						// altflag: "world.png" // if you'd like a flag from a file on your mirror device.
              						title: "Vancouver", // Too long of a title could cause bad text align.
              						timezone: "America/Vancouver",
              						flag: "ca", // If you'd like a flag from the standard library
              						title: "Boca Chica", // Too long of a title could cause bad text align.
              						timezone: "America/Chicago", //When omitted, Local time will be displayed.
              						flag: "us", // If you'd like a flag from the standard library
              						title: "Sydney", // Too long of a title could cause bad text align.
              						timezone: "Australia/Sydney",
              						flag: "au", // If you'd like a flag from the standard library
              Did you restart MM or do a reload (Ctrl-R)?
                SoleLo @MacG
                I added your custom css but the title is showing overlapped and I have it as style left, should I change it to top like yours?
                  MacG @SoleLo
                  @solelo Adjust the width to 200px
                   .MMM-Worldclock .world {
                         width: 200px;
                  The module may also have an alignment problem on the right side. Further customization of custom.css may be required.
                    SoleLo @MacG
                    @macg Ok thanks I’ll mess around with it some more and see if I can get it customized. I figured it was simple as adding your custom css snippet in but I guess not
                    M S 2 Replies Last reply
                      MacG @SoleLo
                      @solelo Just try to set the width higher and higher, eventually nothing will overlap anymore. But it will probably be quite wide, with the cities next to the time. Maybe that’s why style: ‘top’ is the better choice.
                        sdetweil @SoleLo
                        @solelo see this
                        https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1632064035932
                        u can change the styles livee and then save it to custom.css…
                        note that you can doc the dev window at the bottom too, using the 3 dot menu next to the X to close the dev window
                          MacG
                          A supplement to the development tools. When you open it, you can select “Sources” and pause script execution with the “pause button” or F8 in the lower third. This makes it easier to get through all the style classes, which otherwise update every second.
                          • goldyfruitG
                            goldyfruit Project Sponsor
                            I used to install the original woldclock module, just switched to this one and it worked out of the box.
                            Thanks for the work. :clapping_hands:
                            Build smart things with magic and love! | https://smartgic.io
                              SymmetriC
                              How do I center horizontally at the top of the screen instead of left?
                                sdetweil @SymmetriC
                                @SymmetriC put it in the top_center position
                                BKeyportB S 2 Replies Last reply
                                • BKeyportB
                                  @sdetweil or top_bar
                                    SymmetriC @sdetweil
                                    @sdetweil Thank you! That worked and the solution was easier than I thought! lol
                                      JohnGalt
                                      @BKeyport, @ulrichwisser and all: Please let me know if the following questions would be better served under a new topic, but since my issues originated with this older module, and the new module shares the same name I thought it appropriate to post under this topic…
                                      Issue: the old module is no longer supported by the developer, who suggests using a newer module which uses the same module name. After cloning the new module, the instructions call for doing an ‘npm ci’ command, which fails due to a lack of an existing package-lock,json file.
                                      Question: Is there something different I should be doing, o si this something the developer needs to fix?
                                      Old module: https://github.com/BKeyport/MMM-Worldclock
                                      New module: https://github.com/ulrichwisser/MMM-Worldclock
                                      Error Message:
                                      pi@mirror1:~/MagicMirror/modules $ cd MMM-Worldclock
                                      pi@mirror1:~/MagicMirror/modules/MMM-Worldclock $ npm ci
                                      npm ERR! code EUSAGE
                                      npm ERR!
                                      npm ERR! The `npm ci` command can only install with an existing package-lock.json or
                                      npm ERR! npm-shrinkwrap.json with lockfileVersion >= 1. Run an install with npm@5 or
                                      npm ERR! later to generate a package-lock.json file, then try again.
                                      npm ERR!
                                      npm ERR! Clean install a project
                                      npm ERR!
                                      npm ERR! Usage:
                                      npm ERR! npm ci
                                      npm ERR!
                                      npm ERR! Options:
                                      npm ERR! [--install-strategy <hoisted|nested|shallow|linked>] [--legacy-bundling]
                                      npm ERR! [--global-style] [--omit <dev|optional|peer> [--omit <dev|optional|peer> ...]]
                                      npm ERR! [--strict-peer-deps] [--foreground-scripts] [--ignore-scripts] [--no-audit]
                                      npm ERR! [--no-bin-links] [--no-fund] [--dry-run]
                                      npm ERR! [-w|--workspace <workspace-name> [-w|--workspace <workspace-name> ...]]
                                      npm ERR! [-ws|--workspaces] [--include-workspace-root] [--install-links]
                                      npm ERR!
                                      npm ERR! aliases: clean-install, ic, install-clean, isntall-clean
                                      npm ERR!
                                      npm ERR! Run "npm help ci" for more info
                                      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2025-08-05T17_16_59_150Z-debug-0.log
                                        sdetweil @JohnGalt
                                        @JohnGalt npm install then
                                        J 1 Reply Last reply
                                          JohnGalt @sdetweil
                                          @sdetweil – That’s what I thought. Just did that and it’s working now…
                                          Thanks, as always!
                                          BKeyportB 1 Reply Last reply
                                          • BKeyportB
                                            BKeyport Module Developer @JohnGalt
                                            My version of the module developed a fatal bug that I couldn’t get rid of… The best move was to shut it down.
