    MMM-SystemStats (cpu temp/load, fre ram ...)
    74 Posts 36 Posters 79.8k Views 35 Watching
      Mykle1 Project Sponsor Module Developer @KirAsh4
      @KirAsh4 said in MMM-SystemStats (cpu temp/load, fre ram ...):
      Deprecation is not the same as a hint. That message is a warning to let you know that while it may work today, it may not in the near future because sys is being deprecated and ultimately phased out (and removed) in favor of util. It would make sense to write code for the packages that will continue to work, and not for things that will be deprecated.
      I also get that warning message but it works and nothing seems to be wrong or unstable. I like having the stats to keep an eye on how things are running, then I hide it with MMM-Remote-Control until the next time I want to check.
      So, do you recommend NOT using it? Is there any “danger” in using it?
        BenRoe Module Developer
        @Mykle1 it is not “danger”. Next days a update is coming.
          The update v1.1 is out. Thx to Bruce17 for the pull request.
          Update instructions
            Mykle1 Project Sponsor Module Developer @BenRoe
            @BenRoe said in MMM-SystemStats (cpu temp/load, fre ram ...):
            I followed the update instructions. It seems to be working fine and the “DeprecationWarning: sys is deprecated. Use util instead.” is no longer being reported. Nice!
            • T Offline
              toldenburger
              Any way I can make this module alight to the left?
              DocVooDooD 1 Reply Last reply Reply Quote 0
              • DocVooDooD Offline
                DocVooDoo @toldenburger
                @toldenburger
                position: ‘top_left’, // This can be any of the regions.
                or
                position: ‘bottom_left’, // This can be any of the regions.
                • T Offline
                  toldenburger @DocVooDoo
                  @DocVooDoo Ah sorry I wasn’t clear enough:
                  I don’t mean the position of the module, but the alignment of the actual text. It seems to be centered by default and I can’t find a css in the module.
                  DocVooDooD strawberry 3.141S 2 Replies Last reply Reply Quote 0
                    @toldenburger Oh, I would like to know.
                    • strawberry 3.141S Offline
                      strawberry 3.141 Project Sponsor Module Developer @toldenburger
                      @toldenburger put that in custom.css
                      .MMM-SystemStats table td {
                        text-align: left !important;
                      Mykle1M 1 Reply Last reply Reply Quote 3
                        Mykle1 Project Sponsor Module Developer @strawberry 3.141
                        @strawberry-3.141 said in MMM-SystemStats (cpu temp/load, fre ram ...):
                        Oh, I’m so glad you got here first, before I tried to help him. :wink:
                          @toldenburger @DocVooDoo the v1.2 is out
                          • add pull request #2 (automatic translate loding label)
                          • new config item (align the labels)
                          • Sandy2503S Offline
                            Sandy2503
                            How Can I change the Fontsize of the Modul ?
                            Sandy2503
                            AgilesChromsA 1 Reply Last reply Reply Quote 0
                              McSorley
                              Perfect along with MMM-RemoteControl to hide and enable it when I am testing.
                              • AgilesChromsA Offline
                                AgilesChroms @Sandy2503
                                @Sandy2503
                                one solution
                                wrapper.className = this.config.classes ? this.config.classes : “bold small bright”;
                                  PhilReis
                                  Hello, can i view this module only when the CPU temperature is over XX °C?
                                  • lavolp3L Offline
                                    lavolp3 Module Developer
                                    Hello @BenRoe
                                    I have this module installed for some time and was always wondering how to interprete the “System load” part.
                                    Now I finally did a bit of research and am still wondering why this value is used. Why is it such an imprtant value for you?
                                    Also, I’m trying to implement “sd card usage”. I think it’s a quite important value (since my card is quite full :-))
                                    How to troubleshoot modules
                                    MMM-soccer v2, MMM-AVStock
                                      A Former User @lavolp3
                                      @lavolp3 How about trying MMM-Tools?(https://github.com/eouia/MMM-Tools)
                                      justjim1220J lavolp3L 2 Replies Last reply Reply Quote 0
                                      • justjim1220J Offline
                                        justjim1220 Module Developer @Guest
                                        @sean
                                        Got any idea on how to get this and any ofnthe other PC stats modules to show the CPU and GPU temps with Windows PC’s?
                                        Jim Hallock - 1995
                                          A Former User @justjim1220
                                          @justjim1220
                                          See this
                                          https://stackoverflow.com/questions/24004300/batch-file-get-cpu-temperature-in-c-and-set-as-variable
                                          • lavolp3L Offline
                                            lavolp3 Module Developer @Guest
                                            @sean ooooh that looks good!
                                            • 1 / 4
