    MMM-SystemStats (cpu temp/load, fre ram ...)
    74 Posts 36 Posters 78.5k Views 35 Watching
    • T Offline
      tgriffo
      I shall try again (currently travelling for work) later this week and report back with more details…
      • K Offline
        KirAsh4 Moderator
        Deprecation is not the same as a hint. That message is a warning to let you know that while it may work today, it may not in the near future because sys is being deprecated and ultimately phased out (and removed) in favor of util. It would make sense to write code for the packages that will continue to work, and not for things that will be deprecated.
          Mar @BenRoe
          @BenRoe the classes config item is the exact same name used by the MMM-ProfileSwitcher plugin unfortunately.
            Mykle1 Project Sponsor Module Developer @KirAsh4
            @KirAsh4 said in MMM-SystemStats (cpu temp/load, fre ram ...):
            I also get that warning message but it works and nothing seems to be wrong or unstable. I like having the stats to keep an eye on how things are running, then I hide it with MMM-Remote-Control until the next time I want to check.
            So, do you recommend NOT using it? Is there any “danger” in using it?
              BenRoe Module Developer
              @Mykle1 it is not “danger”. Next days a update is coming.
                The update v1.1 is out. Thx to Bruce17 for the pull request.
                Update instructions
                  Mykle1 Project Sponsor Module Developer @BenRoe
                  @BenRoe said in MMM-SystemStats (cpu temp/load, fre ram ...):
                  I followed the update instructions. It seems to be working fine and the “DeprecationWarning: sys is deprecated. Use util instead.” is no longer being reported. Nice!
                  • T Offline
                    toldenburger
                    Any way I can make this module alight to the left?
                    DocVooDooD 1 Reply Last reply Reply Quote 0
                    • DocVooDooD Offline
                      DocVooDoo @toldenburger
                      @toldenburger
                      position: ‘top_left’, // This can be any of the regions.
                      or
                      position: ‘bottom_left’, // This can be any of the regions.
                      • T Offline
                        toldenburger @DocVooDoo
                        @DocVooDoo Ah sorry I wasn’t clear enough:
                        I don’t mean the position of the module, but the alignment of the actual text. It seems to be centered by default and I can’t find a css in the module.
                        DocVooDooD strawberry 3.141S 2 Replies Last reply Reply Quote 0
                          @toldenburger Oh, I would like to know.
                          • strawberry 3.141S Offline
                            strawberry 3.141 Project Sponsor Module Developer @toldenburger
                            @toldenburger put that in custom.css
                            .MMM-SystemStats table td {
                              text-align: left !important;
                            Mykle1M 1 Reply Last reply Reply Quote 3
                              Mykle1 Project Sponsor Module Developer @strawberry 3.141
                              @strawberry-3.141 said in MMM-SystemStats (cpu temp/load, fre ram ...):
                              Oh, I’m so glad you got here first, before I tried to help him. :wink:
                                @toldenburger @DocVooDoo the v1.2 is out
                                • add pull request #2 (automatic translate loding label)
                                • new config item (align the labels)
                                • Sandy2503S Offline
                                  Sandy2503
                                  How Can I change the Fontsize of the Modul ?
                                  Sandy2503
                                  AgilesChromsA 1 Reply Last reply Reply Quote 0
                                    McSorley
                                    Perfect along with MMM-RemoteControl to hide and enable it when I am testing.
                                    • AgilesChromsA Offline
                                      AgilesChroms @Sandy2503
                                      @Sandy2503
                                      one solution
                                      wrapper.className = this.config.classes ? this.config.classes : “bold small bright”;
                                        PhilReis
                                        Hello, can i view this module only when the CPU temperature is over XX °C?
                                        • lavolp3L Offline
                                          lavolp3 Module Developer
                                          Hello @BenRoe
                                          I have this module installed for some time and was always wondering how to interprete the “System load” part.
                                          Now I finally did a bit of research and am still wondering why this value is used. Why is it such an imprtant value for you?
                                          Also, I’m trying to implement “sd card usage”. I think it’s a quite important value (since my card is quite full :-))
                                          How to troubleshoot modules
                                          MMM-soccer v2, MMM-AVStock
                                            [[global:former-user]] @lavolp3
                                            @lavolp3 How about trying MMM-Tools?(https://github.com/eouia/MMM-Tools)
                                            justjim1220J lavolp3L 2 Replies Last reply Reply Quote 0
                                            • 1 / 4
