    MMM-SystemStats (cpu temp/load, fre ram ...)
    74 Posts 36 Posters 81.2k Views 35 Watching
      Mar @BenRoe
      @BenRoe the classes config item is the exact same name used by the MMM-ProfileSwitcher plugin unfortunately.
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @KirAsh4
        @KirAsh4 said in MMM-SystemStats (cpu temp/load, fre ram ...):
        Deprecation is not the same as a hint. That message is a warning to let you know that while it may work today, it may not in the near future because sys is being deprecated and ultimately phased out (and removed) in favor of util. It would make sense to write code for the packages that will continue to work, and not for things that will be deprecated.
        I also get that warning message but it works and nothing seems to be wrong or unstable. I like having the stats to keep an eye on how things are running, then I hide it with MMM-Remote-Control until the next time I want to check.
        So, do you recommend NOT using it? Is there any “danger” in using it?
          BenRoe Module Developer
          @Mykle1 it is not “danger”. Next days a update is coming.
            The update v1.1 is out. Thx to Bruce17 for the pull request.
            Update instructions
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @BenRoe
              @BenRoe said in MMM-SystemStats (cpu temp/load, fre ram ...):
              I followed the update instructions. It seems to be working fine and the “DeprecationWarning: sys is deprecated. Use util instead.” is no longer being reported. Nice!
              • T
                toldenburger
                Any way I can make this module alight to the left?
                DocVooDooD 1 Reply Last reply Reply Quote 0
                • DocVooDooD
                  DocVooDoo @toldenburger
                  @toldenburger
                  position: ‘top_left’, // This can be any of the regions.
                  or
                  position: ‘bottom_left’, // This can be any of the regions.
                  • T
                    toldenburger @DocVooDoo
                    @DocVooDoo Ah sorry I wasn’t clear enough:
                    I don’t mean the position of the module, but the alignment of the actual text. It seems to be centered by default and I can’t find a css in the module.
                    DocVooDooD strawberry 3.141S 2 Replies Last reply Reply Quote 0
                    • DocVooDooD
                      @toldenburger Oh, I would like to know.
                      • strawberry 3.141S
                        strawberry 3.141 Project Sponsor Module Developer @toldenburger
                        @toldenburger put that in custom.css
                        .MMM-SystemStats table td {
                          text-align: left !important;
                        Mykle1M 1 Reply Last reply Reply Quote 3
                        • Mykle1M
                          Mykle1 Project Sponsor Module Developer @strawberry 3.141
                          @strawberry-3.141 said in MMM-SystemStats (cpu temp/load, fre ram ...):
                          Oh, I’m so glad you got here first, before I tried to help him. :wink:
                            @toldenburger @DocVooDoo the v1.2 is out
                            • add pull request #2 (automatic translate loding label)
                            • new config item (align the labels)
                            • Sandy2503S
                              Sandy2503
                              How Can I change the Fontsize of the Modul ?
                              Sandy2503
                              AgilesChromsA 1 Reply Last reply Reply Quote 0
                                McSorley
                                Perfect along with MMM-RemoteControl to hide and enable it when I am testing.
                                • AgilesChromsA
                                  AgilesChroms @Sandy2503
                                  @Sandy2503
                                  one solution
                                  wrapper.className = this.config.classes ? this.config.classes : “bold small bright”;
                                    PhilReis
                                    Hello, can i view this module only when the CPU temperature is over XX °C?
                                    • lavolp3L
                                      lavolp3 Module Developer
                                      Hello @BenRoe
                                      I have this module installed for some time and was always wondering how to interprete the “System load” part.
                                      Now I finally did a bit of research and am still wondering why this value is used. Why is it such an imprtant value for you?
                                      Also, I’m trying to implement “sd card usage”. I think it’s a quite important value (since my card is quite full :-))
                                      How to troubleshoot modules
                                      MMM-soccer v2, MMM-AVStock
                                        A Former User @lavolp3
                                        @lavolp3 How about trying MMM-Tools?(https://github.com/eouia/MMM-Tools)
                                        justjim1220J lavolp3L 2 Replies Last reply Reply Quote 0
                                        • justjim1220J
                                          justjim1220 Module Developer @Guest
                                          @sean
                                          Got any idea on how to get this and any ofnthe other PC stats modules to show the CPU and GPU temps with Windows PC’s?
                                          Jim Hallock - 1995
                                            A Former User @justjim1220
                                            @justjim1220
                                            See this
                                            https://stackoverflow.com/questions/24004300/batch-file-get-cpu-temperature-in-c-and-set-as-variable
                                            • 1 / 4
