    MMM-SystemStats (cpu temp/load, fre ram ...)
    74 Posts 36 Posters 82.5k Views 35 Watching
      BenRoe Module Developer
      @Mykle1 it is not “danger”. Next days a update is coming.
        The update v1.1 is out. Thx to Bruce17 for the pull request.
        Update instructions
        Mykle1M 1 Reply Last reply
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @BenRoe
          @BenRoe said in MMM-SystemStats (cpu temp/load, fre ram ...):
          I followed the update instructions. It seems to be working fine and the “DeprecationWarning: sys is deprecated. Use util instead.” is no longer being reported. Nice!
          • T
            toldenburger
            Any way I can make this module alight to the left?
            DocVooDooD 1 Reply Last reply
            • DocVooDooD
              DocVooDoo @toldenburger
              @toldenburger
              position: ‘top_left’, // This can be any of the regions.
              or
              position: ‘bottom_left’, // This can be any of the regions.
              T 1 Reply Last reply
              • T
                toldenburger @DocVooDoo
                @DocVooDoo Ah sorry I wasn’t clear enough:
                I don’t mean the position of the module, but the alignment of the actual text. It seems to be centered by default and I can’t find a css in the module.
                DocVooDooD strawberry 3.141S 2 Replies Last reply
                • DocVooDooD
                  @toldenburger Oh, I would like to know.
                  • strawberry 3.141S
                    strawberry 3.141 Project Sponsor Module Developer @toldenburger
                    @toldenburger put that in custom.css
                    .MMM-SystemStats table td {
                      text-align: left !important;
                    Reply Quote 3
                    • Mykle1M
                      Mykle1 Project Sponsor Module Developer @strawberry 3.141
                      @strawberry-3.141 said in MMM-SystemStats (cpu temp/load, fre ram ...):
                      Oh, I’m so glad you got here first, before I tried to help him. :wink:
                        @toldenburger @DocVooDoo the v1.2 is out
                        • add pull request #2 (automatic translate loding label)
                        • new config item (align the labels)
                        • Sandy2503S
                          Sandy2503
                          How Can I change the Fontsize of the Modul ?
                          Sandy2503
                          AgilesChromsA 1 Reply Last reply
                            McSorley
                            Perfect along with MMM-RemoteControl to hide and enable it when I am testing.
                            • AgilesChromsA
                              AgilesChroms @Sandy2503
                              @Sandy2503
                              one solution
                              wrapper.className = this.config.classes ? this.config.classes : “bold small bright”;
                                PhilReis
                                Hello, can i view this module only when the CPU temperature is over XX °C?
                                • lavolp3L
                                  lavolp3 Module Developer
                                  Hello @BenRoe
                                  I have this module installed for some time and was always wondering how to interprete the “System load” part.
                                  Now I finally did a bit of research and am still wondering why this value is used. Why is it such an imprtant value for you?
                                  Also, I’m trying to implement “sd card usage”. I think it’s a quite important value (since my card is quite full :-))
                                  How to troubleshoot modules
                                  MMM-soccer v2, MMM-AVStock
                                  ? 1 Reply Last reply
                                    A Former User @lavolp3
                                    @lavolp3 How about trying MMM-Tools?(https://github.com/eouia/MMM-Tools)
                                    justjim1220J lavolp3L 2 Replies Last reply
                                    • justjim1220J
                                      justjim1220 Module Developer @Guest
                                      @sean
                                      Got any idea on how to get this and any ofnthe other PC stats modules to show the CPU and GPU temps with Windows PC’s?
                                      Jim Hallock - 1995
                                        A Former User @justjim1220
                                        @justjim1220
                                        See this
                                        https://stackoverflow.com/questions/24004300/batch-file-get-cpu-temperature-in-c-and-set-as-variable
                                        • lavolp3L
                                          lavolp3 Module Developer @Guest
                                          @sean ooooh that looks good!
                                            djuscha
                                            I want to move module 10 px to the right. if i change custom css it’s not what i do wrong
                                            .MMM-SystemStats  {
                                               margin-right: 10px;
                                            it does not change even after the reboot
                                            lavolp3L 1 Reply Last reply
                                            • 1 / 4
