    MMM-SystemStats (cpu temp/load, fre ram ...)
    74 Posts 36 Posters 82.5k Views 35 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @BenRoe
      @BenRoe said in MMM-SystemStats (cpu temp/load, fre ram ...):
      The update v1.1 is out. Thx to Bruce17 for the pull request.
      I followed the update instructions. It seems to be working fine and the “DeprecationWarning: sys is deprecated. Use util instead.” is no longer being reported. Nice!
      • T
        toldenburger
        Any way I can make this module alight to the left?
        DocVooDooD 1 Reply Last reply
        • DocVooDooD
          DocVooDoo @toldenburger
          @toldenburger
          position: ‘top_left’, // This can be any of the regions.
          or
          position: ‘bottom_left’, // This can be any of the regions.
          T 1 Reply Last reply
          • T
            toldenburger @DocVooDoo
            @DocVooDoo Ah sorry I wasn’t clear enough:
            I don’t mean the position of the module, but the alignment of the actual text. It seems to be centered by default and I can’t find a css in the module.
            DocVooDooD strawberry 3.141S 2 Replies Last reply
            • DocVooDooD
              @toldenburger Oh, I would like to know.
              • strawberry 3.141S
                strawberry 3.141 Project Sponsor Module Developer @toldenburger
                @toldenburger put that in custom.css
                .MMM-SystemStats table td {
                  text-align: left !important;
                Mykle1M 1 Reply Last reply
                Reply Quote 3
                • Mykle1M
                  Mykle1 Project Sponsor Module Developer @strawberry 3.141
                  @strawberry-3.141 said in MMM-SystemStats (cpu temp/load, fre ram ...):
                  Oh, I’m so glad you got here first, before I tried to help him. :wink:
                    BenRoe Module Developer
                    @toldenburger @DocVooDoo the v1.2 is out
                    • add pull request #2 (automatic translate loding label)
                    • new config item (align the labels)
                    • Sandy2503S
                      Sandy2503
                      How Can I change the Fontsize of the Modul ?
                      Sandy2503
                      AgilesChromsA 1 Reply Last reply
                        McSorley
                        Perfect along with MMM-RemoteControl to hide and enable it when I am testing.
                        • AgilesChromsA
                          AgilesChroms @Sandy2503
                          @Sandy2503
                          one solution
                          wrapper.className = this.config.classes ? this.config.classes : “bold small bright”;
                            PhilReis
                            Hello, can i view this module only when the CPU temperature is over XX °C?
                            • lavolp3L
                              lavolp3 Module Developer
                              Hello @BenRoe
                              I have this module installed for some time and was always wondering how to interprete the “System load” part.
                              Now I finally did a bit of research and am still wondering why this value is used. Why is it such an imprtant value for you?
                              Also, I’m trying to implement “sd card usage”. I think it’s a quite important value (since my card is quite full :-))
                              How to troubleshoot modules
                              MMM-soccer v2, MMM-AVStock
                              ? 1 Reply Last reply
                                A Former User @lavolp3
                                @lavolp3 How about trying MMM-Tools?(https://github.com/eouia/MMM-Tools)
                                justjim1220J lavolp3L 2 Replies Last reply
                                • justjim1220J
                                  justjim1220 Module Developer @Guest
                                  @sean
                                  Got any idea on how to get this and any ofnthe other PC stats modules to show the CPU and GPU temps with Windows PC’s?
                                  Jim Hallock - 1995
                                    A Former User @justjim1220
                                    @justjim1220
                                    See this
                                    https://stackoverflow.com/questions/24004300/batch-file-get-cpu-temperature-in-c-and-set-as-variable
                                    • lavolp3L
                                      lavolp3 Module Developer @Guest
                                      @sean ooooh that looks good!
                                        djuscha
                                        I want to move module 10 px to the right. if i change custom css it’s not what i do wrong
                                        .MMM-SystemStats  {
                                           margin-right: 10px;
                                        it does not change even after the reboot
                                        lavolp3L 1 Reply Last reply
                                        • lavolp3L
                                          lavolp3 Module Developer @djuscha
                                          @djuscha I think you cannot move a module itself. Usually you need to use the main container inluding the content. Here you can try the td with class “title”.
                                          .MMM-SystemStats .title  {
                                             margin-right: 10px;
                                          OR the table itself
                                          .MMM-SystemStats table {
                                             margin-right: 10px;
                                            djuscha
                                            @lavolp3 said in MMM-SystemStats (cpu temp/load, fre ram ...):
                                            I tried both, that did not work :(
                                            • 1 / 4
