MMM-SystemStats (cpu temp/load, fre ram ...)
74 Posts 36 Posters 63.0k Views 35 Watching
    BenRoe Module Developer
    [card:benroe/MMM-SystemStats]
    It’s testet with a Raspberry Pi.
    MMM-MMM-SystemStats
    ToDO:
    • icons
    • sd-card available space
    • better indication for the system load
    If you found an issue, please report it here.
    If you like the module, give it a star on Github.
    T M B N 4 Replies Last reply Oct 2, 2016, 9:24 AM Reply Quote 3
    • T Offline
      tgriffo @BenRoe
      G’day @BenRoe
      when using your module (Raspberry Pi powered) I get the below message and nothing appears to work. If I comment out the MMM-SystemStats module config on config/config.js the other modules work again.
      (node:2247) DeprecationWarning: sys is deprecated. Use util instead.
      Any clues?
      Cheers,
      Tiago
        I also have this message, but everything works. It’s only a hint.
        Are there some other messages?
        • T Offline
          tgriffo
          I shall try again (currently travelling for work) later this week and report back with more details…
          • K Offline
            KirAsh4 Moderator
            Deprecation is not the same as a hint. That message is a warning to let you know that while it may work today, it may not in the near future because sys is being deprecated and ultimately phased out (and removed) in favor of util. It would make sense to write code for the packages that will continue to work, and not for things that will be deprecated.
            M 1 Reply Last reply Feb 6, 2017, 11:35 PM Reply Quote 0
              Mar @BenRoe
              @BenRoe the classes config item is the exact same name used by the MMM-ProfileSwitcher plugin unfortunately.
                Mykle1 Project Sponsor Module Developer @KirAsh4
                @KirAsh4 said in MMM-SystemStats (cpu temp/load, fre ram ...):
                I also get that warning message but it works and nothing seems to be wrong or unstable. I like having the stats to keep an eye on how things are running, then I hide it with MMM-Remote-Control until the next time I want to check.
                So, do you recommend NOT using it? Is there any “danger” in using it?
                  @Mykle1 it is not “danger”. Next days a update is coming.
                    The update v1.1 is out. Thx to Bruce17 for the pull request.
                    Update instructions
                    M 1 Reply Last reply Feb 7, 2017, 10:45 PM Reply Quote 1
                      Mykle1 Project Sponsor Module Developer @BenRoe
                      @BenRoe said in MMM-SystemStats (cpu temp/load, fre ram ...):
                      I followed the update instructions. It seems to be working fine and the “DeprecationWarning: sys is deprecated. Use util instead.” is no longer being reported. Nice!
                      • 1 / 8
