    MMM-voice
    voice control
    329 Posts 55 Posters 1.0m Views 50 Watching
      Mykle1 Project Sponsor Module Developer @strawberry 3.141
      @strawberry-3.141 said in MMM-voice:
      you have to either override the class align-left which is getting confuse or set an important flag
      Ohhh, I was so close! Thank you again :thumbsup_tone1:
        c.keen
        Hi guys,
        I would like to control my mirror by using MMM-voice. The installation was quite easy. But now, the icon on the mirror gives an “ERROR” after the microphone has been initialised. I have read the whole thread and tried a few options but none of them worked. Reading the error.log it gives only “127”. Reading the debug.log it says: “pocketsphinx_continuous:: error while loading shared libraries: libpocketsphinx.so.3: cannot open shared object file: No such directory”.
        At first I thought that not all dependencies have been installed correctly althought the installer did not give any warnings or errors. So I thought the I have to install pocketsphinx_continuous and lmtool myself but found them in the node_modules folder.
        Can you please help me?
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @c.keen
          @c.keen do you have an entry in your bashrc file at the bottom?
            c.keen
            please excuse, how do I find the bashrc file? I know some commands but am not really damiliar with raspbian / linux …
              c.keen
              found the bashrc file !
              the last few lines it does not comment on magic mirror or a module itself … (?)
              # enable programmable completion features (you don't need to enable
              # this, if it's already enabled in /etc/bash.bashrc and /etc/profile
              # sources /etc/bash.bashrc).
              if ! shopt -oq posix; then
                if [ -f /usr/share/bash-completion/bash_completion ]; then
                  . /usr/share/bash-completion/bash_completion
                elif [ -f /etc/bash_completion ]; then
                  . /etc/bash_completion
                fi
              fi
              export LD_LIBRARY_PATH=:/usr/local/lib
              export PKG_CONFIG_PATH=:/usr/local/lib/pkgconfig
              export LD_LIBRARY_PATH=:/usr/local/lib:/usr/local/lib
              export PKG_CONFIG_PATH=:/usr/local/lib/pkgconfig:/usr/local/lib/pkgconfig
                c.keen
                the bold part was not in the file itself (the forum software did it). The file ends with … pkgconfig as can be seen above
                  @c.keen ok looks like you ran the installer multiple times, but your links are set so it should find the libpocketsphinx. Did you try to restart the raspberry or the terminal?
                    c.keen
                    At first when I tried to install using the bash script it stopped at the second step (can’t remember exactly why). But second time it worked itself completely through the steps. Starting the mirror I got the “Error” message. Then I read the thread here completely and removed all components necessary.
                    I installed it again using the script and no warnings or errors were reported. But still, after “initialising” the Error message was displayed. ?? As described in the error.log I found “127” and in the debug.log the long message I reported in an earlier thread.
                    I still have no idea …
                      c.keen
                      And I started the raspberry and the terminal multiple times since the error
                      • lucallmonL Offline
                        lucallmon
                        My entire mirror is JACKED UP hard after trying to install this module. How do I go about deleting all dependencies and everything in relation to this module?
                        Going through the dependencies setup, it got to 5/6 and it gave me a slew of errors and then stopped. I’ve tried multiple times to re-install and it gives me the same. Now all I want to do is get rid of of it so I can go back to a working mirror. Any help would be greatly appreciated. @strawberry-3-141 @Mykle1
                          strawberry 3.141 Project Sponsor Module Developer @lucallmon
                          @lucallmon would be interesting what these errors are, because step 5/6 is only performing a usual npm install as you do in most of the modules.
                          • remove the module directory
                          • open your bashrc file and delete at the bottom:
                          • in /home/pi/ there should be directories called pocketsphinx and sphinxbase, go into them and execute make uninstall, afterwards you can remove them.
                          • run apt-get autoremove to uninstall dependencies that are not longer needed on your system
                            lucallmon
                            during [STEP 5/6] Installing npm dependencies
                            I get the following errors and then it stops: ```
                            npm ERR! Linux 4.4.50-v7+
                            npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “install”
                            npm ERR! node v6.10.0
                            npm ERR! npm v3.10.10
                            npm ERR! path /home/pi/MagicMirror/modules/MMM-voice
                            npm ERR! code EACCES
                            npm ERR! errno -13
                            npm ERR! syscall access
                            npm ERR! Error: EACCES: permission denied, access ‘/home/pi/MagicMirror/modules/MMM-voice’
                            npm ERR! at Error (native)
                            npm ERR! { Error: EACCES: permission denied, access ‘/home/pi/MagicMirror/modules/MMM-voice’
                            npm ERR! errno: -13,
                            npm ERR! code: ‘EACCES’,
                            npm ERR! syscall: ‘access’,
                            npm ERR! path: ‘/home/pi/MagicMirror/modules/MMM-voice’ }
                            npm ERR!
                            npm ERR! Please try running this command again as root/Administrator.
                            npm ERR! path npm-debug.log.3606122589
                            npm ERR! errno -13
                            npm ERR! syscall open
                            npm ERR! Error: EACCES: permission denied, open ‘npm-debug.log.3606122589’
                            npm ERR! { Error: EACCES: permission denied, open ‘npm-debug.log.3606122589’
                            npm ERR! syscall: ‘open’,
                            npm ERR! path: ‘npm-debug.log.3606122589’ }
                            npm ERR!
                            npm ERR! /home/pi/MagicMirror/modules/MMM-voice/npm-debug.log
                            [STEP 5/6] Installing npm dependencies | Failed
                            thoughts?
                              @lucallmon these are some access right issues, how do you run the installer?
                              lucallmonL 2 Replies Last reply Reply Quote 0
                                lucallmon @strawberry 3.141
                                @strawberry-3.141 I did not use sudo should I?
                                  @lucallmon I never installed it with sudo rights
                                  lucallmonL 1 Reply Last reply Reply Quote 0
                                    @strawberry-3.141 one of my biggest problems is that after trying to install this module, my AlexaPi doesn’t work anymore. I think it has something to do with the re-install of sphinx. Once I figure this out, I’ll reinstall AlexaPi.
                                      @strawberry-3.141 so what is your suggestion in my case?
                                        @lucallmon can you check your access rights for user pi in MMM-voice, modules and a different module
                                          @strawberry-3.141 sorry, i’m pretty much a NOOB, how do I do that?
                                            lucallmon
                                            @strawberry-3-141 Ok, using sudo to install dependencies, I was able to get through 5/6, but now 6/6 failed:
                                            dependencies.sh: line 106: cd: /root/MagicMirror/modules/MMM-voice: No such file or directory
                                            npm WARN enoent ENOENT: no such file or directory, open '/root/pocketsphinx/package.json'
                                            npm WARN pocketsphinx No description
                                            npm WARN pocketsphinx No repository field.
                                            npm WARN pocketsphinx No README data
                                            npm WARN pocketsphinx No license field.
                                            [STEP 5/6] Installing npm dependencies | Done
                                            [STEP 6/6] Manipulating dependencies
                                            dependencies.sh: line 118: cd: /root/MagicMirror/modules/MMM-voice/node_modules/pocketsphinx-continuous: No such file or directory
                                            sed: can't read index.js: No such file or directory
                                            [STEP 6/6] Manipulating dependencies | Failed
                                            thoughts?
                                            • 16
                                            • 17
                                            • 6 / 17
