    MMM-voice
    voice control
    329 Posts 55 Posters 1.1m Views 50 Watching
      c.keen
      And I started the raspberry and the terminal multiple times since the error
      • L Offline
        lucallmon
        My entire mirror is JACKED UP hard after trying to install this module. How do I go about deleting all dependencies and everything in relation to this module?
        Going through the dependencies setup, it got to 5/6 and it gave me a slew of errors and then stopped. I’ve tried multiple times to re-install and it gives me the same. Now all I want to do is get rid of of it so I can go back to a working mirror. Any help would be greatly appreciated. @strawberry-3-141 @Mykle1
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @lucallmon
          @lucallmon would be interesting what these errors are, because step 5/6 is only performing a usual npm install as you do in most of the modules.
          • remove the module directory
          • open your bashrc file and delete at the bottom:
          export LD_LIBRARY_PATH=:/usr/local/lib
          export PKG_CONFIG_PATH=:/usr/local/lib/pkgconfig
          • in /home/pi/ there should be directories called pocketsphinx and sphinxbase, go into them and execute make uninstall, afterwards you can remove them.
          • run apt-get autoremove to uninstall dependencies that are not longer needed on your system
          • L Offline
            lucallmon
            during [STEP 5/6] Installing npm dependencies
            I get the following errors and then it stops: ```
            npm ERR! Linux 4.4.50-v7+
            npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “install”
            npm ERR! node v6.10.0
            npm ERR! npm v3.10.10
            npm ERR! path /home/pi/MagicMirror/modules/MMM-voice
            npm ERR! code EACCES
            npm ERR! errno -13
            npm ERR! syscall access
            npm ERR! Error: EACCES: permission denied, access ‘/home/pi/MagicMirror/modules/MMM-voice’
            npm ERR! at Error (native)
            npm ERR! { Error: EACCES: permission denied, access ‘/home/pi/MagicMirror/modules/MMM-voice’
            npm ERR! errno: -13,
            npm ERR! code: ‘EACCES’,
            npm ERR! syscall: ‘access’,
            npm ERR! path: ‘/home/pi/MagicMirror/modules/MMM-voice’ }
            npm ERR!
            npm ERR! Please try running this command again as root/Administrator.
            npm ERR! path npm-debug.log.3606122589
            npm ERR! errno -13
            npm ERR! syscall open
            npm ERR! Error: EACCES: permission denied, open ‘npm-debug.log.3606122589’
            npm ERR! { Error: EACCES: permission denied, open ‘npm-debug.log.3606122589’
            npm ERR! syscall: ‘open’,
            npm ERR! path: ‘npm-debug.log.3606122589’ }
            npm ERR!
            npm ERR! /home/pi/MagicMirror/modules/MMM-voice/npm-debug.log
            [STEP 5/6] Installing npm dependencies | Failed
            thoughts?
              @lucallmon these are some access right issues, how do you run the installer?
              L 2 Replies Last reply Reply Quote 0
              • L Offline
                lucallmon @strawberry 3.141
                @strawberry-3.141 I did not use sudo should I?
                  @lucallmon I never installed it with sudo rights
                  • L Offline
                    @strawberry-3.141 one of my biggest problems is that after trying to install this module, my AlexaPi doesn’t work anymore. I think it has something to do with the re-install of sphinx. Once I figure this out, I’ll reinstall AlexaPi.
                    • L Offline
                      @strawberry-3.141 so what is your suggestion in my case?
                        @lucallmon can you check your access rights for user pi in MMM-voice, modules and a different module
                        • L Offline
                          @strawberry-3.141 sorry, i’m pretty much a NOOB, how do I do that?
                          • L Offline
                            lucallmon
                            @strawberry-3-141 Ok, using sudo to install dependencies, I was able to get through 5/6, but now 6/6 failed:
                            dependencies.sh: line 106: cd: /root/MagicMirror/modules/MMM-voice: No such file or directory
                            npm WARN enoent ENOENT: no such file or directory, open '/root/pocketsphinx/package.json'
                            npm WARN pocketsphinx No description
                            npm WARN pocketsphinx No repository field.
                            npm WARN pocketsphinx No README data
                            npm WARN pocketsphinx No license field.
                            [STEP 5/6] Installing npm dependencies | Done
                            [STEP 6/6] Manipulating dependencies
                            dependencies.sh: line 118: cd: /root/MagicMirror/modules/MMM-voice/node_modules/pocketsphinx-continuous: No such file or directory
                            sed: can't read index.js: No such file or directory
                            [STEP 6/6] Manipulating dependencies | Failed
                            thoughts?
                              @lucallmon this will not work as it tries to look and do stuff in /root/... instead of /home/pi/...
                                I’m curious if someone ever tried to find the easter egg in this module :thinking:
                                Mykle1M A 2 Replies Last reply Reply Quote 1
                                  Mykle1 Project Sponsor Module Developer @strawberry 3.141
                                  @strawberry-3.141 said in MMM-voice:
                                  I tried the voice command, “Show me some boobs”, but I got nothing. :-)
                                  The same exact response I get from my wife.
                                    abcdennis @strawberry 3.141
                                    @strawberry-3.141 I found it, I just didn’t want to post any spoilers.
                                      Mykle1 Project Sponsor Module Developer @abcdennis
                                      @abcdennis said in MMM-voice:
                                      How about a hint then? You can pm it if you don’t want to spoil it for others
                                      strawberry 3.141S Mykle1M 2 Replies Last reply Reply Quote 1
                                        strawberry 3.141 Project Sponsor Module Developer @Mykle1
                                        @Mykle1 A hint would be if you want to test it as a voice command you need to have mmm-tts installed as well or you try to reverse engineer it then you can start at the mmm-tts notification ;)
                                          This is an impossibility. “shrug”
                                            @Mykle1 then you need mmm-tts to hear the response when you found it :)
                                            • 16
                                            • 17
                                            • 6 / 17
