    MMM-voice
    voice control
    329 Posts 55 Posters 1.1m Views 50 Watching
    • strawberry 3.141S
      strawberry 3.141 Project Sponsor Module Developer @lucallmon
      @lucallmon I never installed it with sudo rights
      lucallmonL 1 Reply Last reply
      • lucallmonL
        lucallmon @strawberry 3.141
        @strawberry-3.141 one of my biggest problems is that after trying to install this module, my AlexaPi doesn’t work anymore. I think it has something to do with the re-install of sphinx. Once I figure this out, I’ll reinstall AlexaPi.
        • lucallmonL
          @strawberry-3.141 so what is your suggestion in my case?
          • strawberry 3.141S
            @lucallmon can you check your access rights for user pi in MMM-voice, modules and a different module
            • lucallmonL
              @strawberry-3.141 sorry, i’m pretty much a NOOB, how do I do that?
              • lucallmonL
                lucallmon
                @strawberry-3-141 Ok, using sudo to install dependencies, I was able to get through 5/6, but now 6/6 failed:
                [STEP 5/6] Installing npm dependencies
                dependencies.sh: line 106: cd: /root/MagicMirror/modules/MMM-voice: No such file or directory
                npm WARN enoent ENOENT: no such file or directory, open '/root/pocketsphinx/package.json'
                npm WARN pocketsphinx No description
                npm WARN pocketsphinx No repository field.
                npm WARN pocketsphinx No README data
                npm WARN pocketsphinx No license field.
                [STEP 5/6] Installing npm dependencies | Done
                [STEP 6/6] Manipulating dependencies
                dependencies.sh: line 118: cd: /root/MagicMirror/modules/MMM-voice/node_modules/pocketsphinx-continuous: No such file or directory
                sed: can't read index.js: No such file or directory
                [STEP 6/6] Manipulating dependencies | Failed
                thoughts?
                • strawberry 3.141S
                  @lucallmon this will not work as it tries to look and do stuff in /root/... instead of /home/pi/...
                  P 1 Reply Last reply
                  • strawberry 3.141S
                    I’m curious if someone ever tried to find the easter egg in this module :thinking:
                    Mykle1M A 2 Replies Last reply
                    • Mykle1M
                      Mykle1 Project Sponsor Module Developer @strawberry 3.141
                      @strawberry-3.141 said in MMM-voice:
                      I tried the voice command, “Show me some boobs”, but I got nothing. :-)
                      The same exact response I get from my wife.
                      • A
                        abcdennis @strawberry 3.141
                        @strawberry-3.141 I found it, I just didn’t want to post any spoilers.
                        Mykle1M 1 Reply Last reply
                        Reply Quote 2
                        • Mykle1M
                          Mykle1 Project Sponsor Module Developer @abcdennis
                          @abcdennis said in MMM-voice:
                          How about a hint then? You can pm it if you don’t want to spoil it for others
                          strawberry 3.141S Mykle1M 2 Replies Last reply
                          • strawberry 3.141S
                            strawberry 3.141 Project Sponsor Module Developer @Mykle1
                            @Mykle1 A hint would be if you want to test it as a voice command you need to have mmm-tts installed as well or you try to reverse engineer it then you can start at the mmm-tts notification ;)
                            • Mykle1M
                              This is an impossibility. “shrug”
                              • strawberry 3.141S
                                @Mykle1 then you need mmm-tts to hear the response when you found it :)
                                • cowboysdudeC
                                  I’m sworn to secrecy… will not tell :) Install MMM-TTS and you’ll love it when you find it! :)
                                  • Mykle1M
                                    My mirror does not have sound (yet) so I’ll have to install tts on my MM Sports Laptop
                                    • Mykle1M
                                      @strawberry-3.141
                                      Do I run sudo apt-get festival in the MMM-TTS directory?
                                      cowboysdudeC strawberry 3.141S 2 Replies Last reply
                                      • cowboysdudeC
                                        • strawberry 3.141S
                                          @Mykle1 it doesnt matter in which directory you run the command
                                          • strawberry 3.141S
                                            Ok @abcdennis got the correct answer, let’s see who else get the right answer. Next hint on Thursday.
                                            • 16
                                            • 17
                                            • 6 / 17
