    MMM-voice
    voice control
    329 Posts 55 Posters 1.1m Views 50 Watching
      c.keen
      the bold part was not in the file itself (the forum software did it). The file ends with … pkgconfig as can be seen above
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @c.keen
        @c.keen ok looks like you ran the installer multiple times, but your links are set so it should find the libpocketsphinx. Did you try to restart the raspberry or the terminal?
          c.keen
          At first when I tried to install using the bash script it stopped at the second step (can’t remember exactly why). But second time it worked itself completely through the steps. Starting the mirror I got the “Error” message. Then I read the thread here completely and removed all components necessary.
          I installed it again using the script and no warnings or errors were reported. But still, after “initialising” the Error message was displayed. ?? As described in the error.log I found “127” and in the debug.log the long message I reported in an earlier thread.
          I still have no idea …
            c.keen
            And I started the raspberry and the terminal multiple times since the error
            • L
              lucallmon
              My entire mirror is JACKED UP hard after trying to install this module. How do I go about deleting all dependencies and everything in relation to this module?
              Going through the dependencies setup, it got to 5/6 and it gave me a slew of errors and then stopped. I’ve tried multiple times to re-install and it gives me the same. Now all I want to do is get rid of of it so I can go back to a working mirror. Any help would be greatly appreciated. @strawberry-3-141 @Mykle1
              • strawberry 3.141S
                strawberry 3.141 Project Sponsor Module Developer @lucallmon
                @lucallmon would be interesting what these errors are, because step 5/6 is only performing a usual npm install as you do in most of the modules.
                • remove the module directory
                • open your bashrc file and delete at the bottom:
                export LD_LIBRARY_PATH=:/usr/local/lib
                export PKG_CONFIG_PATH=:/usr/local/lib/pkgconfig
                • in /home/pi/ there should be directories called pocketsphinx and sphinxbase, go into them and execute make uninstall, afterwards you can remove them.
                • run apt-get autoremove to uninstall dependencies that are not longer needed on your system
                • L
                  lucallmon
                  during [STEP 5/6] Installing npm dependencies
                  I get the following errors and then it stops: ```
                  npm ERR! Linux 4.4.50-v7+
                  npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “install”
                  npm ERR! node v6.10.0
                  npm ERR! npm v3.10.10
                  npm ERR! path /home/pi/MagicMirror/modules/MMM-voice
                  npm ERR! code EACCES
                  npm ERR! errno -13
                  npm ERR! syscall access
                  npm ERR! Error: EACCES: permission denied, access ‘/home/pi/MagicMirror/modules/MMM-voice’
                  npm ERR! at Error (native)
                  npm ERR! { Error: EACCES: permission denied, access ‘/home/pi/MagicMirror/modules/MMM-voice’
                  npm ERR! errno: -13,
                  npm ERR! code: ‘EACCES’,
                  npm ERR! syscall: ‘access’,
                  npm ERR! path: ‘/home/pi/MagicMirror/modules/MMM-voice’ }
                  npm ERR!
                  npm ERR! Please try running this command again as root/Administrator.
                  npm ERR! path npm-debug.log.3606122589
                  npm ERR! errno -13
                  npm ERR! syscall open
                  npm ERR! Error: EACCES: permission denied, open ‘npm-debug.log.3606122589’
                  npm ERR! { Error: EACCES: permission denied, open ‘npm-debug.log.3606122589’
                  npm ERR! syscall: ‘open’,
                  npm ERR! path: ‘npm-debug.log.3606122589’ }
                  npm ERR!
                  npm ERR! /home/pi/MagicMirror/modules/MMM-voice/npm-debug.log
                  [STEP 5/6] Installing npm dependencies | Failed
                  thoughts?
                  • strawberry 3.141S
                    @lucallmon these are some access right issues, how do you run the installer?
                    L 2 Replies Last reply Reply Quote 0
                    • L
                      lucallmon @strawberry 3.141
                      @strawberry-3.141 I did not use sudo should I?
                      • strawberry 3.141S
                        @lucallmon I never installed it with sudo rights
                        • L
                          @strawberry-3.141 one of my biggest problems is that after trying to install this module, my AlexaPi doesn’t work anymore. I think it has something to do with the re-install of sphinx. Once I figure this out, I’ll reinstall AlexaPi.
                          • L
                            @strawberry-3.141 so what is your suggestion in my case?
                            • strawberry 3.141S
                              @lucallmon can you check your access rights for user pi in MMM-voice, modules and a different module
                              • L
                                @strawberry-3.141 sorry, i’m pretty much a NOOB, how do I do that?
                                • L
                                  lucallmon
                                  @strawberry-3-141 Ok, using sudo to install dependencies, I was able to get through 5/6, but now 6/6 failed:
                                  dependencies.sh: line 106: cd: /root/MagicMirror/modules/MMM-voice: No such file or directory
                                  npm WARN enoent ENOENT: no such file or directory, open '/root/pocketsphinx/package.json'
                                  npm WARN pocketsphinx No description
                                  npm WARN pocketsphinx No repository field.
                                  npm WARN pocketsphinx No README data
                                  npm WARN pocketsphinx No license field.
                                  [STEP 5/6] Installing npm dependencies | Done
                                  [STEP 6/6] Manipulating dependencies
                                  dependencies.sh: line 118: cd: /root/MagicMirror/modules/MMM-voice/node_modules/pocketsphinx-continuous: No such file or directory
                                  sed: can't read index.js: No such file or directory
                                  [STEP 6/6] Manipulating dependencies | Failed
                                  thoughts?
                                  • strawberry 3.141S
                                    @lucallmon this will not work as it tries to look and do stuff in /root/... instead of /home/pi/...
                                    • strawberry 3.141S
                                      I’m curious if someone ever tried to find the easter egg in this module :thinking:
                                      Mykle1M A 2 Replies Last reply Reply Quote 1
                                      • Mykle1M
                                        Mykle1 Project Sponsor Module Developer @strawberry 3.141
                                        @strawberry-3.141 said in MMM-voice:
                                        I tried the voice command, “Show me some boobs”, but I got nothing. :-)
                                        The same exact response I get from my wife.
                                        • A
                                          abcdennis @strawberry 3.141
                                          @strawberry-3.141 I found it, I just didn’t want to post any spoilers.
                                          • Mykle1M
                                            Mykle1 Project Sponsor Module Developer @abcdennis
                                            @abcdennis said in MMM-voice:
                                            How about a hint then? You can pm it if you don’t want to spoil it for others
                                            strawberry 3.141S Mykle1M 2 Replies Last reply Reply Quote 1
                                            • 16
                                            • 17
                                            • 6 / 17
