    MMM-voice
    voice control
    329 Posts 55 Posters 1.1m Views 50 Watching
      c.keen
      please excuse, how do I find the bashrc file? I know some commands but am not really damiliar with raspbian / linux …
        c.keen
        found the bashrc file !
        the last few lines it does not comment on magic mirror or a module itself … (?)
        # enable programmable completion features (you don't need to enable
        # this, if it's already enabled in /etc/bash.bashrc and /etc/profile
        # sources /etc/bash.bashrc).
        if ! shopt -oq posix; then
          if [ -f /usr/share/bash-completion/bash_completion ]; then
            . /usr/share/bash-completion/bash_completion
          elif [ -f /etc/bash_completion ]; then
            . /etc/bash_completion
          fi
        fi
        export LD_LIBRARY_PATH=:/usr/local/lib
        export PKG_CONFIG_PATH=:/usr/local/lib/pkgconfig
        export LD_LIBRARY_PATH=:/usr/local/lib:/usr/local/lib
        export PKG_CONFIG_PATH=:/usr/local/lib/pkgconfig:/usr/local/lib/pkgconfig
          c.keen
          the bold part was not in the file itself (the forum software did it). The file ends with … pkgconfig as can be seen above
          • strawberry 3.141S Offline
            strawberry 3.141 Project Sponsor Module Developer @c.keen
            @c.keen ok looks like you ran the installer multiple times, but your links are set so it should find the libpocketsphinx. Did you try to restart the raspberry or the terminal?
              c.keen
              At first when I tried to install using the bash script it stopped at the second step (can’t remember exactly why). But second time it worked itself completely through the steps. Starting the mirror I got the “Error” message. Then I read the thread here completely and removed all components necessary.
              I installed it again using the script and no warnings or errors were reported. But still, after “initialising” the Error message was displayed. ?? As described in the error.log I found “127” and in the debug.log the long message I reported in an earlier thread.
              I still have no idea …
                c.keen
                And I started the raspberry and the terminal multiple times since the error
                • L Offline
                  lucallmon
                  My entire mirror is JACKED UP hard after trying to install this module. How do I go about deleting all dependencies and everything in relation to this module?
                  Going through the dependencies setup, it got to 5/6 and it gave me a slew of errors and then stopped. I’ve tried multiple times to re-install and it gives me the same. Now all I want to do is get rid of of it so I can go back to a working mirror. Any help would be greatly appreciated. @strawberry-3-141 @Mykle1
                    strawberry 3.141 Project Sponsor Module Developer @lucallmon
                    @lucallmon would be interesting what these errors are, because step 5/6 is only performing a usual npm install as you do in most of the modules.
                    • remove the module directory
                    • open your bashrc file and delete at the bottom:
                    • in /home/pi/ there should be directories called pocketsphinx and sphinxbase, go into them and execute make uninstall, afterwards you can remove them.
                    • run apt-get autoremove to uninstall dependencies that are not longer needed on your system
                    • L Offline
                      lucallmon
                      during [STEP 5/6] Installing npm dependencies
                      I get the following errors and then it stops: ```
                      npm ERR! Linux 4.4.50-v7+
                      npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “install”
                      npm ERR! node v6.10.0
                      npm ERR! npm v3.10.10
                      npm ERR! path /home/pi/MagicMirror/modules/MMM-voice
                      npm ERR! code EACCES
                      npm ERR! errno -13
                      npm ERR! syscall access
                      npm ERR! Error: EACCES: permission denied, access ‘/home/pi/MagicMirror/modules/MMM-voice’
                      npm ERR! at Error (native)
                      npm ERR! { Error: EACCES: permission denied, access ‘/home/pi/MagicMirror/modules/MMM-voice’
                      npm ERR! errno: -13,
                      npm ERR! code: ‘EACCES’,
                      npm ERR! syscall: ‘access’,
                      npm ERR! path: ‘/home/pi/MagicMirror/modules/MMM-voice’ }
                      npm ERR!
                      npm ERR! Please try running this command again as root/Administrator.
                      npm ERR! path npm-debug.log.3606122589
                      npm ERR! errno -13
                      npm ERR! syscall open
                      npm ERR! Error: EACCES: permission denied, open ‘npm-debug.log.3606122589’
                      npm ERR! { Error: EACCES: permission denied, open ‘npm-debug.log.3606122589’
                      npm ERR! syscall: ‘open’,
                      npm ERR! path: ‘npm-debug.log.3606122589’ }
                      npm ERR!
                      npm ERR! /home/pi/MagicMirror/modules/MMM-voice/npm-debug.log
                      [STEP 5/6] Installing npm dependencies | Failed
                      thoughts?
                        @lucallmon these are some access right issues, how do you run the installer?
                        L 2 Replies Last reply Reply Quote 0
                        • L Offline
                          lucallmon @strawberry 3.141
                          @strawberry-3.141 I did not use sudo should I?
                            @lucallmon I never installed it with sudo rights
                            • L Offline
                              @strawberry-3.141 one of my biggest problems is that after trying to install this module, my AlexaPi doesn’t work anymore. I think it has something to do with the re-install of sphinx. Once I figure this out, I’ll reinstall AlexaPi.
                              • L Offline
                                @strawberry-3.141 so what is your suggestion in my case?
                                  @lucallmon can you check your access rights for user pi in MMM-voice, modules and a different module
                                  • L Offline
                                    @strawberry-3.141 sorry, i’m pretty much a NOOB, how do I do that?
                                    • L Offline
                                      lucallmon
                                      @strawberry-3-141 Ok, using sudo to install dependencies, I was able to get through 5/6, but now 6/6 failed:
                                      dependencies.sh: line 106: cd: /root/MagicMirror/modules/MMM-voice: No such file or directory
                                      npm WARN enoent ENOENT: no such file or directory, open '/root/pocketsphinx/package.json'
                                      npm WARN pocketsphinx No description
                                      npm WARN pocketsphinx No repository field.
                                      npm WARN pocketsphinx No README data
                                      npm WARN pocketsphinx No license field.
                                      [STEP 5/6] Installing npm dependencies | Done
                                      [STEP 6/6] Manipulating dependencies
                                      dependencies.sh: line 118: cd: /root/MagicMirror/modules/MMM-voice/node_modules/pocketsphinx-continuous: No such file or directory
                                      sed: can't read index.js: No such file or directory
                                      [STEP 6/6] Manipulating dependencies | Failed
                                      thoughts?
                                        @lucallmon this will not work as it tries to look and do stuff in /root/... instead of /home/pi/...
                                          I’m curious if someone ever tried to find the easter egg in this module :thinking:
                                          Mykle1M A 2 Replies Last reply Reply Quote 1
                                            Mykle1 Project Sponsor Module Developer @strawberry 3.141
                                            @strawberry-3.141 said in MMM-voice:
                                            I tried the voice command, “Show me some boobs”, but I got nothing. :-)
                                            The same exact response I get from my wife.
                                            • 16
                                            • 17
                                            • 6 / 17
