    MMM-voice
    voice control
    329 Posts 55 Posters 1.1m Views 50 Watching
    • L
      lucallmon @strawberry 3.141
      @strawberry-3.141 I did not use sudo should I?
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @lucallmon
        @lucallmon I never installed it with sudo rights
        • L
          @strawberry-3.141 one of my biggest problems is that after trying to install this module, my AlexaPi doesn’t work anymore. I think it has something to do with the re-install of sphinx. Once I figure this out, I’ll reinstall AlexaPi.
          • L
            @strawberry-3.141 so what is your suggestion in my case?
            • strawberry 3.141S
              @lucallmon can you check your access rights for user pi in MMM-voice, modules and a different module
              • L
                @strawberry-3.141 sorry, i’m pretty much a NOOB, how do I do that?
                • L
                  lucallmon
                  @strawberry-3-141 Ok, using sudo to install dependencies, I was able to get through 5/6, but now 6/6 failed:
                  [STEP 5/6] Installing npm dependencies
                  dependencies.sh: line 106: cd: /root/MagicMirror/modules/MMM-voice: No such file or directory
                  npm WARN enoent ENOENT: no such file or directory, open '/root/pocketsphinx/package.json'
                  npm WARN pocketsphinx No description
                  npm WARN pocketsphinx No repository field.
                  npm WARN pocketsphinx No README data
                  npm WARN pocketsphinx No license field.
                  [STEP 5/6] Installing npm dependencies | Done
                  [STEP 6/6] Manipulating dependencies
                  dependencies.sh: line 118: cd: /root/MagicMirror/modules/MMM-voice/node_modules/pocketsphinx-continuous: No such file or directory
                  sed: can't read index.js: No such file or directory
                  [STEP 6/6] Manipulating dependencies | Failed
                  thoughts?
                  • strawberry 3.141S
                    @lucallmon this will not work as it tries to look and do stuff in /root/... instead of /home/pi/...
                    • strawberry 3.141S
                      I’m curious if someone ever tried to find the easter egg in this module :thinking:
                      Mykle1M A 2 Replies Last reply Reply Quote 1
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @strawberry 3.141
                        @strawberry-3.141 said in MMM-voice:
                        I tried the voice command, “Show me some boobs”, but I got nothing. :-)
                        The same exact response I get from my wife.
                        • A
                          abcdennis @strawberry 3.141
                          @strawberry-3.141 I found it, I just didn’t want to post any spoilers.
                          • Mykle1M
                            Mykle1 Project Sponsor Module Developer @abcdennis
                            @abcdennis said in MMM-voice:
                            How about a hint then? You can pm it if you don’t want to spoil it for others
                            strawberry 3.141S Mykle1M 2 Replies Last reply Reply Quote 1
                            • strawberry 3.141S
                              strawberry 3.141 Project Sponsor Module Developer @Mykle1
                              @Mykle1 A hint would be if you want to test it as a voice command you need to have mmm-tts installed as well or you try to reverse engineer it then you can start at the mmm-tts notification ;)
                              • Mykle1M
                                This is an impossibility. “shrug”
                                • strawberry 3.141S
                                  @Mykle1 then you need mmm-tts to hear the response when you found it :)
                                  • cowboysdudeC
                                    I’m sworn to secrecy… will not tell :) Install MMM-TTS and you’ll love it when you find it! :)
                                    • Mykle1M
                                      My mirror does not have sound (yet) so I’ll have to install tts on my MM Sports Laptop
                                      • Mykle1M
                                        @strawberry-3.141
                                        Do I run sudo apt-get festival in the MMM-TTS directory?
                                        cowboysdudeC strawberry 3.141S 2 Replies Last reply Reply Quote 0
                                        • cowboysdudeC
                                          • strawberry 3.141S
                                            @Mykle1 it doesnt matter in which directory you run the command
                                            • 16
                                            • 17
                                            • 6 / 17
