    MMM-voice
    voice control
    329 Posts 55 Posters 1.1m Views 50 Watching
      pepemujica
      I’m doing this:
      "Clone this repo into ~/MagicMirror/modules directory.
      Run command bash dependencies.sh in ~/MagicMirror/modules/MMM-voice/installers directory, to install all dependencies. This will need a couple of minutes."
      When I run bash dependencies.sh I have the error I’ve post at step 6
      • cowboysdudeC
        Yes that would be the correct way :) I see you’ve also posted in troubleshooting and strawberry is there trying to help you…
        P 1 Reply Last reply
          pepemujica @cowboysdude
          @cowboysdude said in MMM-voice:
          traw
          Yes, but still can’t find the answer :(
          • cowboysdudeC
            cowboysdude Module Developer @pepemujica
            @pepemujica Go back to the troubleshooting post and ask strawberry to help you, he will :)
              pepemujica
              Hi, I’m having troubles here:
              0_1490484812893_upload-30f66be8-0e70-43db-9d09-ace55c7ecf8b
              Any idea why?
              Kind regards
                pepemujica @pepemujica
                Could solve this, but when I open the module, I only see the mic with “Error”
                Any idea why?
                Kind regards
                • strawberry 3.141S
                  strawberry 3.141 Project Sponsor Module Developer @pepemujica
                  @pepemujica what is inside your error log?
                    pepemujica @strawberry 3.141
                    @strawberry-3.141 Just 111111
                    johnnyboyJ 1 Reply Last reply
                    • johnnyboyJ
                      johnnyboy @pepemujica
                      @pepemujica
                      I take it you have already deleted the instal, and dowloaded another? Seen this happen and a fresh instal usualy does the trick? Sometimes, for whatever strange weird wonderfull reason, the download gets corrupted or fails to instal everything!
                        pepemujica @johnnyboy
                        @johnnyboy So, how do I do a proper unistall for this module?
                        • johnnyboyJ
                          @pepemujica
                          I have uninstalled modules by - sudo apt-get purge (name of module) then sudo apt-get clean… then done another git pull of the module and installed… reading any notes first of course incase there are any points I need to pay particular attention to?
                            @johnnyboy I get this: 0_1490807719620_upload-f9553ba2-dae5-4af3-9035-92d9ee8508bd
                            • yawnsY
                              yawns Moderator
                              mmm-voice is no apt package, it is a module for magic mirror.
                              To remove it you do this
                              cd ~/MagicMirror/modules
                              rm -r mmm-voice
                              • strawberry 3.141S
                                strawberry 3.141 Project Sponsor Module Developer @strawberry 3.141
                                @strawberry-3.141 said in MMM-voice:
                                • remove the module directory
                                • open your bashrc file and delete at the bottom:
                                export LD_LIBRARY_PATH=:/usr/local/lib
                                export PKG_CONFIG_PATH=:/usr/local/lib/pkgconfig
                                • in /home/pi/ there should be directories called pocketsphinx and sphinxbase, go into them and execute make uninstall, afterwards you can remove them.
                                • run apt-get autoremove to uninstall dependencies that are not longer needed on your system
                                  @strawberry-3.141 Thanks for answering!
                                  I’ve already done this, but sitill got the error at the right of the microphone
                                  This time the error log has only a “1”
                                    @strawberry-3-141
                                    0_1490812600092_upload-a01aedc7-9ab8-454f-b257-c318fa74b947
                                    • johnnyboyJ
                                      johnnyboy @yawns
                                      @yawns said in MMM-voice:
                                      rm -r mmm-voice
                                      I stand corrected @yawns… Sorry for giving wrong direction @pepemujica :-(
                                      • strawberry 3.141S
                                        @pepemujica can you enable debug: true in the config and have a look what the debug log says
                                        P 2 Replies Last reply
                                          @strawberry-3.141 at the module config?
                                            @strawberry-3.141 Got this:
                                            INFO: pocketsphinx.c(152): Parsed model-specific feature parameters from /usr/local/share/pocketsphinx/model/en-us/en-us/feat.params
                                            Current configuration:
                                            [NAME] [DEFLT] [VALUE]
                                            -agc none none
                                            -agcthresh 2.0 2.000000e+00
                                            -allphone
                                            -allphone_ci yes yes
                                            -alpha 0.97 9.700000e-01
                                            -ascale 20.0 2.000000e+01
                                            -aw 1 1
                                            -backtrace no no
                                            -beam 1e-48 1.000000e-48
                                            -bestpath yes yes
                                            -bestpathlw 9.5 9.500000e+00
                                            -ceplen 13 13
                                            -cmn live batch
                                            -cmninit 40,3,-1 41.00,-5.29,-0.12,5.09,2.48,-4.07,-1.37,-1.78,-5.08,-2.05,-6.45,-1.42,1.17
                                            -compallsen no no
                                            -debug 0
                                            -dict modules/MMM-voice/MMM-voice.dic
                                            -dictcase no no
                                            -dither no no
                                            -doublebw no no
                                            -ds 1 1
                                            -fdict
                                            -feat 1s_c_d_dd 1s_c_d_dd
                                            -featparams
                                            -fillprob 1e-8 1.000000e-08
                                            -frate 100 100
                                            -fsg
                                            -fsgusealtpron yes yes
                                            -fsgusefiller yes yes
                                            -fwdflat yes yes
                                            -fwdflatbeam 1e-64 1.000000e-64
                                            -fwdflatefwid 4 4
                                            -fwdflatlw 8.5 8.500000e+00
                                            -fwdflatsfwin 25 25
                                            -fwdflatwbeam 7e-29 7.000000e-29
                                            -fwdtree yes yes
                                            -hmm /usr/local/share/pocketsphinx/model/en-us/en-us
                                            -input_endian little little
                                            -jsgf
                                            -keyphrase
                                            -kws
                                            -kws_delay 10 10
                                            -kws_plp 1e-1 1.000000e-01
                                            -kws_threshold 1e-30 1.000000e-30
                                            -latsize 5000 5000
                                            -lda
                                            -ldadim 0 0
                                            -lifter 0 22
                                            -lm modules/MMM-voice/MMM-voice.lm
                                            -lmctl
                                            -lmname
                                            -logbase 1.0001 1.000100e+00
                                            -logfn
                                            -logspec no no
                                            -lowerf 133.33334 1.300000e+02
                                            -lpbeam 1e-40 1.000000e-40
                                            -lponlybeam 7e-29 7.000000e-29
                                            -lw 6.5 6.500000e+00
                                            -maxhmmpf 30000 30000
                                            -maxwpf -1 -1
                                            -mdef
                                            -mean
                                            -mfclogdir
                                            -min_endfr 0 0
                                            -mixw
                                            -mixwfloor 0.0000001 1.000000e-07
                                            -mllr
                                            -mmap yes yes
                                            -ncep 13 13
                                            -nfft 512 512
                                            -nfilt 40 25
                                            -nwpen 1.0 1.000000e+00
                                            -pbeam 1e-48 1.000000e-48
                                            -pip 1.0 1.000000e+00
                                            -pl_beam 1e-10 1.000000e-10
                                            -pl_pbeam 1e-10 1.000000e-10
                                            -pl_pip 1.0 1.000000e+00
                                            -pl_weight 3.0 3.000000e+00
                                            -pl_window 5 5
                                            -rawlogdir
                                            -remove_dc no no
                                            -remove_noise yes yes
                                            -remove_silence yes yes
                                            -round_filters yes yes
                                            -samprate 16000 1.600000e+04
                                            -seed -1 -1
                                            -sendump
                                            -senlogdir
                                            -senmgau
                                            -silprob 0.005 5.000000e-03
                                            -smoothspec no no
                                            -svspec 0-12/13-25/26-38
                                            -tmat
                                            -tmatfloor 0.0001 1.000000e-04
                                            -topn 4 4
                                            -topn_beam 0 0
                                            -toprule
                                            -transform legacy dct
                                            -unit_area yes yes
                                            -upperf 6855.4976 6.800000e+03
                                            -uw 1.0 1.000000e+00
                                            -vad_postspeech 50 50
                                            -vad_prespeech 20 20
                                            -vad_startspeech 10 10
                                            -vad_threshold 3.0 3.000000e+00
                                            -var
                                            -varfloor 0.0001 1.000000e-04
                                            -varnorm no no
                                            -verbose no no
                                            -warp_params
                                            -warp_type inverse_linear inverse_linear
                                            -wbeam 7e-29 7.000000e-29
                                            -wip 0.65 6.500000e-01
                                            -wlen 0.025625 2.562500e-02
                                            INFO: feat.c(715): Initializing feature stream to type: ‘1s_c_d_dd’, ceplen=13, CMN=‘batch’, VARNORM=‘no’, AGC=‘none’
                                            INFO: acmod.c(162): Using subvector specification 0-12/13-25/26-38
                                            INFO: mdef.c(518): Reading model definition: /usr/local/share/pocketsphinx/model/en-us/en-us/mdef
                                            INFO: mdef.c(531): Found byte-order mark BMDF, assuming this is a binary mdef file
                                            INFO: bin_mdef.c(336): Reading binary model definition: /usr/local/share/pocketsphinx/model/en-us/en-us/mdef
                                            INFO: bin_mdef.c(516): 42 CI-phone, 137053 CD-phone, 3 emitstate/phone, 126 CI-sen, 5126 Sen, 29324 Sen-Seq
                                            INFO: tmat.c(149): Reading HMM transition probability matrices: /usr/local/share/pocketsphinx/model/en-us/en-us/transition_matrices
                                            INFO: acmod.c(113): Attempting to use PTM computation module
                                            INFO: ms_gauden.c(127): Reading mixture gaussian parameter: /usr/local/share/pocketsphinx/model/en-us/en-us/means
                                            INFO: ms_gauden.c(242): 42 codebook, 3 feature, size:
                                            INFO: ms_gauden.c(244): 128x13
                                            INFO: ms_gauden.c(127): Reading mixture gaussian parameter: /usr/local/share/pocketsphinx/model/en-us/en-us/variances
                                            INFO: ms_gauden.c(304): 222 variance values floored
                                            INFO: ptm_mgau.c(476): Loading senones from dump file /usr/local/share/pocketsphinx/model/en-us/en-us/sendump
                                            INFO: ptm_mgau.c(500): BEGIN FILE FORMAT DESCRIPTION
                                            INFO: ptm_mgau.c(563): Rows: 128, Columns: 5126
                                            INFO: ptm_mgau.c(595): Using memory-mapped I/O for senones
                                            INFO: ptm_mgau.c(838): Maximum top-N: 4
                                            INFO: phone_loop_search.c(114): State beam -225 Phone exit beam -225 Insertion penalty 0
                                            INFO: dict.c(320): Allocating 4130 * 32 bytes (129 KiB) for word entries
                                            INFO: dict.c(333): Reading main dictionary: modules/MMM-voice/MMM-voice.dic
                                            INFO: dict.c(213): Dictionary size 29, allocated 0 KiB for strings, 0 KiB for phones
                                            INFO: dict.c(336): 29 words read
                                            INFO: dict.c(358): Reading filler dictionary: /usr/local/share/pocketsphinx/model/en-us/en-us/noisedict
                                            INFO: dict.c(213): Dictionary size 34, allocated 0 KiB for strings, 0 KiB for phones
                                            INFO: dict.c(361): 5 words read
                                            INFO: dict2pid.c(396): Building PID tables for dictionary
                                            INFO: dict2pid.c(406): Allocating 42^3 * 2 bytes (144 KiB) for word-initial triphones
                                            INFO: dict2pid.c(132): Allocated 42672 bytes (41 KiB) for word-final triphones
                                            INFO: dict2pid.c(196): Allocated 42672 bytes (41 KiB) for single-phone word triphones
                                            INFO: ngram_model_trie.c(354): Trying to read LM in trie binary format
                                            INFO: ngram_model_trie.c(365): Header doesn’t match
                                            INFO: ngram_model_trie.c(177): Trying to read LM in arpa format
                                            INFO: ngram_model_trie.c(193): LM of order 3
                                            INFO: ngram_model_trie.c(195): #1-grams: 25
                                            INFO: ngram_model_trie.c(195): #2-grams: 46
                                            INFO: ngram_model_trie.c(195): #3-grams: 23
                                            INFO: lm_trie.c(474): Training quantizer
                                            INFO: lm_trie.c(482): Building LM trie
                                            INFO: ngram_search_fwdtree.c(74): Initializing search tree
                                            INFO: ngram_search_fwdtree.c(101): 28 unique initial diphones
                                            INFO: ngram_search_fwdtree.c(186): Creating search channels
                                            INFO: ngram_search_fwdtree.c(323): Max nonroot chan increased to 157
                                            INFO: ngram_search_fwdtree.c(333): Created 28 root, 29 non-root channels, 5 single-phone words
                                            INFO: ngram_search_fwdflat.c(157): fwdflat: min_ef_width = 4, max_sf_win = 25
                                            INFO: continuous.c(307): pocketsphinx_continuous COMPILED ON: Mar 29 2017, AT: 15:15:03
                                            ALSA lib pcm_hw.c:1693:(_snd_pcm_hw_open) Invalid value for card
                                            Error opening audio device plughw:1 for capture: No such file or directory
                                            FATAL: “continuous.c”, line 245: Failed to open audio device
                                            • 10
                                            • 16
                                            • 17
                                            • 8 / 17
