    MMM-voice
    voice control
    329 Posts 55 Posters 1.1m Views 50 Watching
    • johnnyboyJ
      johnnyboy @Mykle1
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @johnnyboy
        @johnnyboy I can’t confirm that mykle got it right as he didn’t send the solution to me yet.
        But as it is the last day anyways I can confirm that it is related to one of those two fairytales ;)
        @Mykle1 if you see him http://michaelteeuw.nl/post/151621813122/homekit-curtains as siris boyfriend then probably yes :rofl:
        Mykle1M 1 Reply Last reply
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @strawberry 3.141
          @strawberry-3.141 said in MMM-voice:
          Go ahead :-)
          • strawberry 3.141S
            strawberry 3.141 Project Sponsor Module Developer @Mykle1
            @Mykle1 yeah he got it
            johnnyboyJ 1 Reply Last reply
            • johnnyboyJ
              johnnyboy @strawberry 3.141
              • strawberry 3.141S
                Here it is Warning spoiler alert
                • Mykle1M
                  Is that you speaking the activation phrase, Straw?
                    pepemujica @strawberry 3.141
                    @strawberry-3.141 Hi, I have the same problem, but I am installing at home, any idea why?
                    [STEP 5/6] Installing npm dependencies
                    dependencies.sh: line 106: cd: /home/christian/MagicMirror/modules/MMM-voice: No such file or directory
                    npm WARN enoent ENOENT: no such file or directory, open '/home/christian/pocketsphinx/package.json’
                    npm WARN pocketsphinx No description
                    npm WARN pocketsphinx No repository field.
                    npm WARN pocketsphinx No README data
                    npm WARN pocketsphinx No license field.
                    [STEP 5/6] Installing npm dependencies | Done
                    [STEP 6/6] Manipulating dependencies
                    dependencies.sh: line 118: cd: /home/christian/MagicMirror/modules/MMM-voice/node_modules/pocketsphinx-continuous: No such file or directory
                    sed: can’t read index.js: No such file or directory
                    [STEP 6/6] Manipulating dependencies | Failed
                    • cowboysdudeC
                      cowboysdude Module Developer @pepemujica
                      @pepemujica said in MMM-voice:
                      Are you just installing by running ‘npm install’ in the MMM-voice directory?
                        pepemujica
                        I’m doing this:
                        "Clone this repo into ~/MagicMirror/modules directory.
                        Run command bash dependencies.sh in ~/MagicMirror/modules/MMM-voice/installers directory, to install all dependencies. This will need a couple of minutes."
                        When I run bash dependencies.sh I have the error I’ve post at step 6
                        • cowboysdudeC
                          Yes that would be the correct way :) I see you’ve also posted in troubleshooting and strawberry is there trying to help you…
                          P 1 Reply Last reply
                            pepemujica @cowboysdude
                            @cowboysdude said in MMM-voice:
                            traw
                            Yes, but still can’t find the answer :(
                            • cowboysdudeC
                              @pepemujica Go back to the troubleshooting post and ask strawberry to help you, he will :)
                                pepemujica
                                Hi, I’m having troubles here:
                                0_1490484812893_upload-30f66be8-0e70-43db-9d09-ace55c7ecf8b
                                Any idea why?
                                Kind regards
                                  pepemujica @pepemujica
                                  Could solve this, but when I open the module, I only see the mic with “Error”
                                  Any idea why?
                                  Kind regards
                                  • strawberry 3.141S
                                    strawberry 3.141 Project Sponsor Module Developer @pepemujica
                                    @pepemujica what is inside your error log?
                                      @strawberry-3.141 Just 111111
                                      • johnnyboyJ
                                        johnnyboy @pepemujica
                                        @pepemujica
                                        I take it you have already deleted the instal, and dowloaded another? Seen this happen and a fresh instal usualy does the trick? Sometimes, for whatever strange weird wonderfull reason, the download gets corrupted or fails to instal everything!
                                          pepemujica @johnnyboy
                                          @johnnyboy So, how do I do a proper unistall for this module?
                                          • johnnyboyJ
                                            @pepemujica
                                            I have uninstalled modules by - sudo apt-get purge (name of module) then sudo apt-get clean… then done another git pull of the module and installed… reading any notes first of course incase there are any points I need to pay particular attention to?
                                            • 10
                                            • 16
                                            • 17
                                            • 8 / 17
