    MMM-voice
    voice control
    329 Posts 55 Posters 1.1m Views 50 Watching
      Mykle1 Project Sponsor Module Developer @strawberry 3.141
      @strawberry-3.141 said in MMM-voice:
      Solution will follow on sunday.
      I got it! Was that Siri’s boyfriend? :-)
      johnnyboyJ 1 Reply Last reply Reply Quote 0
      • johnnyboyJ Offline
        johnnyboy @Mykle1
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @johnnyboy
          @johnnyboy I can’t confirm that mykle got it right as he didn’t send the solution to me yet.
          But as it is the last day anyways I can confirm that it is related to one of those two fairytales ;)
          @Mykle1 if you see him http://michaelteeuw.nl/post/151621813122/homekit-curtains as siris boyfriend then probably yes :rofl:
            Go ahead :-)
              strawberry 3.141 Project Sponsor Module Developer @Mykle1
              @Mykle1 yeah he got it
                johnnyboy @strawberry 3.141
                  Here it is Warning spoiler alert
                    Is that you speaking the activation phrase, Straw?
                      pepemujica @strawberry 3.141
                      @strawberry-3.141 Hi, I have the same problem, but I am installing at home, any idea why?
                      [STEP 5/6] Installing npm dependencies
                      dependencies.sh: line 106: cd: /home/christian/MagicMirror/modules/MMM-voice: No such file or directory
                      npm WARN enoent ENOENT: no such file or directory, open '/home/christian/pocketsphinx/package.json’
                      npm WARN pocketsphinx No description
                      npm WARN pocketsphinx No repository field.
                      npm WARN pocketsphinx No README data
                      npm WARN pocketsphinx No license field.
                      [STEP 5/6] Installing npm dependencies | Done
                      [STEP 6/6] Manipulating dependencies
                      dependencies.sh: line 118: cd: /home/christian/MagicMirror/modules/MMM-voice/node_modules/pocketsphinx-continuous: No such file or directory
                      sed: can’t read index.js: No such file or directory
                      [STEP 6/6] Manipulating dependencies | Failed
                      • cowboysdudeC Offline
                        cowboysdude Module Developer @pepemujica
                        @pepemujica said in MMM-voice:
                        Are you just installing by running ‘npm install’ in the MMM-voice directory?
                          pepemujica
                          I’m doing this:
                          "Clone this repo into ~/MagicMirror/modules directory.
                          Run command bash dependencies.sh in ~/MagicMirror/modules/MMM-voice/installers directory, to install all dependencies. This will need a couple of minutes."
                          When I run bash dependencies.sh I have the error I’ve post at step 6
                            Yes that would be the correct way :) I see you’ve also posted in troubleshooting and strawberry is there trying to help you…
                              pepemujica @cowboysdude
                              @cowboysdude said in MMM-voice:
                              traw
                              Yes, but still can’t find the answer :(
                                @pepemujica Go back to the troubleshooting post and ask strawberry to help you, he will :)
                                  pepemujica
                                  Hi, I’m having troubles here:
                                  0_1490484812893_upload-30f66be8-0e70-43db-9d09-ace55c7ecf8b
                                  Any idea why?
                                  Kind regards
                                    pepemujica @pepemujica
                                    Could solve this, but when I open the module, I only see the mic with “Error”
                                    Any idea why?
                                    Kind regards
                                      strawberry 3.141 Project Sponsor Module Developer @pepemujica
                                      @pepemujica what is inside your error log?
                                        @strawberry-3.141 Just 111111
                                          johnnyboy @pepemujica
                                          @pepemujica
                                          I take it you have already deleted the instal, and dowloaded another? Seen this happen and a fresh instal usualy does the trick? Sometimes, for whatever strange weird wonderfull reason, the download gets corrupted or fails to instal everything!
                                            pepemujica @johnnyboy
                                            @johnnyboy So, how do I do a proper unistall for this module?
                                            • 10
                                            • 16
                                            • 17
                                            • 8 / 17
