    MMM-voice
    voice control
    329 Posts 55 Posters 998.0k Views 50 Watching
      pepemujica @strawberry 3.141
      @strawberry-3.141 Just 111111
      johnnyboyJ 1 Reply Last reply Reply Quote 0
      • johnnyboyJ Offline
        johnnyboy @pepemujica
        @pepemujica
        I take it you have already deleted the instal, and dowloaded another? Seen this happen and a fresh instal usualy does the trick? Sometimes, for whatever strange weird wonderfull reason, the download gets corrupted or fails to instal everything!
          pepemujica @johnnyboy
          @johnnyboy So, how do I do a proper unistall for this module?
            @pepemujica
            I have uninstalled modules by - sudo apt-get purge (name of module) then sudo apt-get clean… then done another git pull of the module and installed… reading any notes first of course incase there are any points I need to pay particular attention to?
              @johnnyboy I get this: 0_1490807719620_upload-f9553ba2-dae5-4af3-9035-92d9ee8508bd
              • yawnsY Offline
                yawns Moderator
                mmm-voice is no apt package, it is a module for magic mirror.
                To remove it you do this
                cd ~/MagicMirror/modules
                rm -r mmm-voice
                johnnyboyJ 1 Reply Last reply Reply Quote 1
                • strawberry 3.141S Offline
                  strawberry 3.141 Project Sponsor Module Developer @strawberry 3.141
                  @strawberry-3.141 said in MMM-voice:
                  • remove the module directory
                  • open your bashrc file and delete at the bottom:
                  export LD_LIBRARY_PATH=:/usr/local/lib
                  export PKG_CONFIG_PATH=:/usr/local/lib/pkgconfig
                  • in /home/pi/ there should be directories called pocketsphinx and sphinxbase, go into them and execute make uninstall, afterwards you can remove them.
                  • run apt-get autoremove to uninstall dependencies that are not longer needed on your system
                    @strawberry-3.141 Thanks for answering!
                    I’ve already done this, but sitill got the error at the right of the microphone
                    This time the error log has only a “1”
                      pepemujica @pepemujica
                      @strawberry-3-141
                      0_1490812600092_upload-a01aedc7-9ab8-454f-b257-c318fa74b947
                        johnnyboy @yawns
                        @yawns said in MMM-voice:
                        rm -r mmm-voice
                        I stand corrected @yawns… Sorry for giving wrong direction @pepemujica :-(
                        • 14
                        • 15
                        • 16
                        • 17
                        • 18
                        • 32
                        • 33
                        • 16 / 33
