    Calendar times in 24 hour format?
    Scheduled Pinned Locked Moved Feature Requests
    31 Posts 9 Posters 27.3k Views 9 Watching
      dinkybluebug245
      Any way to change calendar times to 24 hour? (as in the clock?)
        jtyle6
        Change the timeFormat: in the config.js file in config folder so looks like this.
        /* Magic Mirror Config
         * MIT Licensed.
        var config = {
                port: 8080,
                language: 'en',
                timeFormat: 12,
                units: 'metric',
        Note: I Have only copied top half of mine.
          dinkybluebug245 @jtyle6
          @jtyle6 Mine is already showing timeformat as 24, which shows the clock in 24 hour format. But calendar items are still showing 12 hour format with AM/PM
            jtyle6 @dinkybluebug245
            @dinkybluebug245 said in Calendar times in 24 hour format?:
            ah, whoops sorry miss read the Topic.
              MrEdOne
              Sorry for Dig this topic from grave but i have the same problem like @dinkybluebug245
              I have meeting on 15:00 but calendar say its 03:00. Without PM
              I have in config timeFormat: 24.
              Everything work fine, only wrong time is show.
              And this is bug after update to last version.
                Mykle1 Project Sponsor Module Developer @MrEdOne
                @MrEdOne
                Two things to try.
                Is your time and time zone set correctly on your Pi itself?
                You could also try timeFormat: 24, in the module entry of the config.
                  MrEdOne
                  timeFormat: 24, in calendar module not work.
                  How can i check is my time and timezone correctly set?
                  Im from Poland so i set Europe/Warsaw time in raspi-config.
                  My clock works correctly.
                  When i change timeFormat to 12 calendar add PM to 03:00 so it’s correctly, but when i change to 24, PM disappear.
                    @MrEdOne said in Calendar times in 24 hour format?:
                    That makes perfect sense. 24 hour format would NOT show AM/PM, only 12 hour format would do that.
                    3:00 PM in 12 hour format
                    1500 in 24 hour format (no PM)
                      MrEdOne
                      Yes, but it won’t change 03:00 to 15:00
                        @MrEdOne
                        Oh ok, that’s different
                        It sounds like something is overriding the timeFormat: setting. Have you made any changes to the calendar.js file?
                          MrEdOne
                          Nope. A search only where is a timeformat in js but my knowledge is to small. :)
                            @MrEdOne
                            Are you typing timeformat ? That won’t work.
                            It has to be timeFormat with a capital F.
                            Wait a minute, the only options for timeFormat in the calendar module are absolute or relative
                              MrEdOne
                              But it not change anything.
                              With absolute and relative is the same.
                                @MrEdOne
                                It has to be timeFormat with a capital F. And at the top of your config also
                                 * MIT Licensed.
                                var config = {
                                        port: 8080,
                                        language: 'en',
                                        timeFormat: 24,
                                        units: 'metric',
                                  MrEdOne
                                  Yes. I have everywhere timeFormat. on a top of config and in calendar module with capital F
                                    MrEdOne
                                    I give up. I don’t know where is error.
                                    • SvenSommerS Offline
                                      SvenSommer
                                      @MrEdOne
                                      timeFormat uses the formatting of your operating system.
                                      When “24” is configured the format “hh:mm” is returned. Which is exactly, what you are looking for.
                                      Here is the code snippet from calender.js:
                                      		switch (config.timeFormat) {
                                      		case 12: {
                                      			moment.updateLocale(config.language, {
                                      				longDateFormat: {
                                      					LT: "h:mm A"
                                      			break;
                                      		case 24: {
                                      				longDateFormat: {
                                      					LT: "hh:mm"
                                      			break;
                                      What do you get, when typing date in your console?
                                      If it’s not in displayed in a format of 24h, change the setting of your OS.
                                      Maybe this helps?
                                      Looking for some building inspiration?
                                      Check out my large, thin and metal framed mirror on robstechlog.com.
                                      Modules released:
                                      MMM-GoogleAnalytics
                                      MMM-GrafanaChart
                                      MMM-GrafanaGauges
                                        MrEdOne
                                        Here is output from date
                                        pi@MagicMirror:~ $ date
                                        wto, 25 lip 2017, 20:59:48 CEST
                                        Yes in 12, but in 24 I have 03:00 instead 15:00
                                          SvenSommer
                                          I think there is simply an understanding problem. You wrote:
                                          “When i change timeFormat to 12 calendar add PM to 03:00 so it’s correctly, but when i change to 24, PM disappear.”
                                          So, if I’m interpreting this right, you are looking for something that isn’t the usual case. You want to display something like: “20:59 PM”
                                          Is this correct?
                                          Modules released:
                                          MMM-GoogleAnalytics
                                          MMM-GrafanaChart
                                          MMM-GrafanaGauges
                                            MrEdOne
