    Calendar times in 24 hour format?
    Scheduled Pinned Locked Moved Feature Requests
    31 Posts 9 Posters 29.3k Views 9 Watching
      dinkybluebug245 @jtyle6
      @jtyle6 Mine is already showing timeformat as 24, which shows the clock in 24 hour format. But calendar items are still showing 12 hour format with AM/PM
      J 1 Reply Last reply
        jtyle6 @dinkybluebug245
        @dinkybluebug245 said in Calendar times in 24 hour format?:
        ah, whoops sorry miss read the Topic.
          MrEdOne
          Sorry for Dig this topic from grave but i have the same problem like @dinkybluebug245
          I have meeting on 15:00 but calendar say its 03:00. Without PM
          I have in config timeFormat: 24.
          Everything work fine, only wrong time is show.
          And this is bug after update to last version.
          Mykle1M 1 Reply Last reply
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @MrEdOne
            @MrEdOne
            Two things to try.
            Is your time and time zone set correctly on your Pi itself?
            You could also try timeFormat: 24, in the module entry of the config.
              MrEdOne
              timeFormat: 24, in calendar module not work.
              How can i check is my time and timezone correctly set?
              Im from Poland so i set Europe/Warsaw time in raspi-config.
              My clock works correctly.
              When i change timeFormat to 12 calendar add PM to 03:00 so it’s correctly, but when i change to 24, PM disappear.
              • Mykle1M
                @MrEdOne said in Calendar times in 24 hour format?:
                That makes perfect sense. 24 hour format would NOT show AM/PM, only 12 hour format would do that.
                3:00 PM in 12 hour format
                1500 in 24 hour format (no PM)
                  MrEdOne
                  Yes, but it won’t change 03:00 to 15:00
                  • Mykle1M
                    @MrEdOne
                    Oh ok, that’s different
                    It sounds like something is overriding the timeFormat: setting. Have you made any changes to the calendar.js file?
                      MrEdOne
                      Nope. A search only where is a timeformat in js but my knowledge is to small. :)
                      • Mykle1M
                        @MrEdOne
                        Are you typing timeformat ? That won’t work.
                        It has to be timeFormat with a capital F.
                        Wait a minute, the only options for timeFormat in the calendar module are absolute or relative
                          MrEdOne
                          But it not change anything.
                          With absolute and relative is the same.
                          • Mykle1M
                            @MrEdOne
                            It has to be timeFormat with a capital F. And at the top of your config also
                            /* Magic Mirror Config
                             * MIT Licensed.
                            var config = {
                                    port: 8080,
                                    language: 'en',
                                    timeFormat: 24,
                                    units: 'metric',
                              MrEdOne
                              Yes. I have everywhere timeFormat. on a top of config and in calendar module with capital F
                                MrEdOne
                                I give up. I don’t know where is error.
                                • SvenSommerS
                                  SvenSommer
                                  @MrEdOne
                                  timeFormat uses the formatting of your operating system.
                                  When “24” is configured the format “hh:mm” is returned. Which is exactly, what you are looking for.
                                  Here is the code snippet from calender.js:
                                  		switch (config.timeFormat) {
                                  		case 12: {
                                  			moment.updateLocale(config.language, {
                                  				longDateFormat: {
                                  					LT: "h:mm A"
                                  			break;
                                  		case 24: {
                                  				longDateFormat: {
                                  					LT: "hh:mm"
                                  			break;
                                  What do you get, when typing date in your console?
                                  If it’s not in displayed in a format of 24h, change the setting of your OS.
                                  Maybe this helps?
                                  Looking for some building inspiration?
                                  Check out my large, thin and metal framed mirror on robstechlog.com.
                                  Modules released:
                                  MMM-GoogleAnalytics
                                  MMM-GrafanaChart
                                  MMM-GrafanaGauges
                                    MrEdOne
                                    Here is output from date
                                    pi@MagicMirror:~ $ date
                                    wto, 25 lip 2017, 20:59:48 CEST
                                    Yes in 12, but in 24 I have 03:00 instead 15:00
                                    • SvenSommerS
                                      SvenSommer
                                      I think there is simply an understanding problem. You wrote:
                                      “When i change timeFormat to 12 calendar add PM to 03:00 so it’s correctly, but when i change to 24, PM disappear.”
                                      So, if I’m interpreting this right, you are looking for something that isn’t the usual case. You want to display something like: “20:59 PM”
                                      Is this correct?
                                      Modules released:
                                      MMM-GoogleAnalytics
                                      MMM-GrafanaChart
                                      MMM-GrafanaGauges
                                        MrEdOne
                                        • SvenSommerS
                                          SvenSommer
                                          Is your google calendar in the correct time zone?
                                          Modules released:
                                          MMM-GoogleAnalytics
                                          MMM-GrafanaChart
                                          MMM-GrafanaGauges
                                            MrEdOne
                                            You mean calendar on Google website?
                                            But everything work correctly until lastest update of mm
