    Calendar times in 24 hour format?
    Scheduled Pinned Locked Moved Feature Requests
    31 Posts 9 Posters 29.0k Views 9 Watching
      MrEdOne
      Sorry for Dig this topic from grave but i have the same problem like @dinkybluebug245
      I have meeting on 15:00 but calendar say its 03:00. Without PM
      I have in config timeFormat: 24.
      Everything work fine, only wrong time is show.
      And this is bug after update to last version.
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @MrEdOne
        @MrEdOne
        Two things to try.
        Is your time and time zone set correctly on your Pi itself?
        You could also try timeFormat: 24, in the module entry of the config.
          MrEdOne
          timeFormat: 24, in calendar module not work.
          How can i check is my time and timezone correctly set?
          Im from Poland so i set Europe/Warsaw time in raspi-config.
          My clock works correctly.
          When i change timeFormat to 12 calendar add PM to 03:00 so it’s correctly, but when i change to 24, PM disappear.
          • Mykle1M
            @MrEdOne said in Calendar times in 24 hour format?:
            That makes perfect sense. 24 hour format would NOT show AM/PM, only 12 hour format would do that.
            3:00 PM in 12 hour format
            1500 in 24 hour format (no PM)
              MrEdOne
              Yes, but it won’t change 03:00 to 15:00
              • Mykle1M
                @MrEdOne
                Oh ok, that’s different
                It sounds like something is overriding the timeFormat: setting. Have you made any changes to the calendar.js file?
                  MrEdOne
                  Nope. A search only where is a timeformat in js but my knowledge is to small. :)
                  • Mykle1M
                    @MrEdOne
                    Are you typing timeformat ? That won’t work.
                    It has to be timeFormat with a capital F.
                    Wait a minute, the only options for timeFormat in the calendar module are absolute or relative
                      MrEdOne
                      But it not change anything.
                      With absolute and relative is the same.
                      • Mykle1M
                        @MrEdOne
                        It has to be timeFormat with a capital F. And at the top of your config also
                        /* Magic Mirror Config
                         * MIT Licensed.
                        var config = {
                                port: 8080,
                                language: 'en',
                                timeFormat: 24,
                                units: 'metric',
                          MrEdOne
                          Yes. I have everywhere timeFormat. on a top of config and in calendar module with capital F
                            MrEdOne
                            I give up. I don’t know where is error.
                            • SvenSommerS
                              SvenSommer
                              @MrEdOne
                              timeFormat uses the formatting of your operating system.
                              When “24” is configured the format “hh:mm” is returned. Which is exactly, what you are looking for.
                              Here is the code snippet from calender.js:
                              		switch (config.timeFormat) {
                              		case 12: {
                              			moment.updateLocale(config.language, {
                              				longDateFormat: {
                              					LT: "h:mm A"
                              			break;
                              		case 24: {
                              				longDateFormat: {
                              					LT: "hh:mm"
                              			break;
                              What do you get, when typing date in your console?
                              If it’s not in displayed in a format of 24h, change the setting of your OS.
                              Maybe this helps?
                              Looking for some building inspiration?
                              Check out my large, thin and metal framed mirror on robstechlog.com.
                              Modules released:
                              MMM-GoogleAnalytics
                              MMM-GrafanaChart
                              MMM-GrafanaGauges
                                MrEdOne
                                Here is output from date
                                pi@MagicMirror:~ $ date
                                wto, 25 lip 2017, 20:59:48 CEST
                                Yes in 12, but in 24 I have 03:00 instead 15:00
                                • SvenSommerS
                                  SvenSommer
                                  I think there is simply an understanding problem. You wrote:
                                  “When i change timeFormat to 12 calendar add PM to 03:00 so it’s correctly, but when i change to 24, PM disappear.”
                                  So, if I’m interpreting this right, you are looking for something that isn’t the usual case. You want to display something like: “20:59 PM”
                                  Is this correct?
                                  Modules released:
                                  MMM-GoogleAnalytics
                                  MMM-GrafanaChart
                                  MMM-GrafanaGauges
                                    MrEdOne
                                    • SvenSommerS
                                      SvenSommer
                                      Is your google calendar in the correct time zone?
                                      Modules released:
                                      MMM-GoogleAnalytics
                                      MMM-GrafanaChart
                                      MMM-GrafanaGauges
                                        MrEdOne
                                        You mean calendar on Google website?
                                        But everything work correctly until lastest update of mm
                                        • SvenSommerS
                                          SvenSommer
                                          Then I have no idea. Sorry…
                                          Modules released:
                                          MMM-GoogleAnalytics
                                          MMM-GrafanaChart
                                          MMM-GrafanaGauges
                                            MrEdOne
                                            Thx for response.
