    Snilles Magic Mirror Project
    44 Posts 13 Posters 71.3k Views 19 Watching
    • cowboysdudeC Offline
      cowboysdude Module Developer @Snille
      @Snille Sorry didn’t see the link!! That looks awesome. The bottom is a touch menu If I"m thinking correctly?
      Please do share how you have the LED’s working for backlight… I’m very interested in that! :)
      SnilleS 1 Reply Last reply Reply Quote 0
      • SnilleS Offline
        Snille Module Developer @cowboysdude
        @cowboysdude Thank you!! :) The LEDs you say. :) Ok, for the moment, the mirror is not “aware” of the leds. This is something I’m planing to implement. But as it works now I’m using PixelWeb with Bibliopixel 2.x as a back end. Then I’m using the below sh script to trigger different (predefined so far) animations.
        #!/bin/bash
        # Snilles MagicMirror Led Conrol Script.
        # Use in conjunction with PixelWEB.
        # Connfigure here!
        # URL to PixelWEB API On the MM.
        apiurl="http://x.x.x.x:8081/api";
        # Default program if no argument is set.
        defprog="back";
        # Default red amount if non is set.
        defred="45";
        # Default green amount if non is set.
        defgreen="30";
        # Default blue amount if non is set.
        defblue="0";
        # Default brightness amount.
        defamount="50";
        ## -------------------------- Dont edit below!! --------------------------- ##
        while [[ $# -gt 0 ]] ; do
        	case $1 in
        		-h|-\?|--help)
        			echo "Usage: mirrorleds.sh -p or --program [back, running, alarm, rainbow or thunder (rainbow and thunder needs no colors)] -r or -red [0-255] -g or --green [0-255] -b or --blue [0-255] -a or --amount [0-255]";
        			exit;
        		-p|--program)
        			if [ -n "$2" ]; then
        				program="$2"
        				shift
        			else
        				program="$defprog"
        			fi
        		-r|--red)
        				if [[ "$2" == ?(-)+([0-9]) ]]; then
        					if [ "$2" -gt "255" ]; then
        						red="255"
        					elif [ "$2" -lt "0" ]; then
        						red="0"
        					else
        						red="$2"
        					fi
        					shift
        				else
        					red="$defred"
        				fi
        			fi
        		-g|--green)
        						green="255"
        						green="0"
        					else
        						green="$2"
        					fi
        					shift
        				else
        					green="$defgreen"
        				fi
        			fi
        		-b|--blue)
        						blue="255"
        						blue="0"
        					else
        						blue="$2"
        					fi
        					shift
        				else
        					blue="$defblue"
        				fi
        			fi
        		-a|--amount)
        						amount="255"
        						amount="0"
        					else
        						amount="$2"
        					fi
        					shift
        				else
        					amount="$defamount"
        				fi
        			fi
        	esac
        	shift
        done
        # Default program if non was given.
        if [ -z "$program" ]; then
        	program="$defprog"
        fi
        # Default red amount if non was given.
        if [ -z "$red" ]; then
        	red="$defred"
        fi
        # Default green amount if non was given.
        if [ -z "$green" ]; then
        	green="$defgreen"
        fi
        # Default blue amount if non was given.
        if [ -z "$blue" ]; then
        	blue="$defblue"
        fi
        # Default amount if non was given.
        if [ -z "$amount" ]; then
        	amount="$defamount"
        fi
        # Compose the colors
        colors="$red,$green,$blue";
        # 22 Pixel Alarm
        if [ "$program" == "alarm" ]; then
        	curl -H "Content-Type: application/json" -X POST --data '{"action":"startAnim","config":{"id":"ColorChase","config":{"end":-1,"start":0,"width":22,"color":['$colors']},"run":{"amt":1,"fps":300,"seconds":null,"max_steps":0,"untilComplete":false,"max_cycles":1}}}' $apiurl;
        fi
        # Rainbowalarm (multi color spinning)
        if [ "$program" == "rainbow" ]; then
        	curl -H "Content-Type: application/json" -X POST --data '{"action":"startAnim","config":{"id":"ColorPattern","config":{"colors":[[255,0,0],[255,165,0],[255,255,0],[0,255,0],[0,0,255],[128,0,128]],"width":20},"run":{"amt":1,"fps":300,"seconds":null,"max_steps":0,"untilComplete":false,"max_cycles":1}}}' $apiurl;
        fi
        # 1 Running Pixel
        if [ "$program" == "running" ]; then
        	curl -H "Content-Type: application/json" -X POST --data '{"action":"startAnim","config":{"id":"ColorChase","config":{"end":-1,"start":0,"width":1,"color":['$colors']},"run":{"amt":1,"fps":40,"seconds":null,"max_steps":0,"untilComplete":false,"max_cycles":1}}}' $apiurl;
        fi
        # Backlight
        if [ "$program" == "back" ]; then
        	curl -H "Content-Type: application/json" -X POST --data '{"action":"startAnim","config":{"id":"ColorPattern","config":{"colors":[['$colors']],"width":1},"run":{"amt":1,"fps":1,"seconds":null,"max_steps":0,"untilComplete":false,"max_cycles":1}}}' $apiurl;
        fi
        # Thunder
        if [ "$program" == "thunder" ]; then
        	curl -H "Content-Type: application/json" -X POST --data '{"action":"startAnim","config":{"id":"WhiteTwinkle","config":{"max_led":null,"speed":2,"density":1,"max_bright":'$amount'},"run":{"amt":1,"fps":300,"seconds":null,"max_steps":0,"untilComplete":false,"max_cycles":1}}}' $apiurl;
        fi
        # Stop everything
        if [ "$program" == "stop" ]; then
        	curl -H "Content-Type: application/json" -X POST --data '{"action":"stopAnim"}' $apiurl;
        fi
        # Add a new line...
        echo $"";
        Then I’m using Alexa (for now) to trigger different animations (via the HA-Bridge server). But later on this will be triggered by a module that “picks up” other modules communication so I can animate the leds depending on for example weather events, calendar events, memo events or whatever I can figure out. :) I just have to convince my wife that animating the leds IS a good thing… :)
          @Snille Awesome, Thank you!
          • SnilleS Offline
            I just added a quick comment on all the pictures in the gallery so you know what you are looking at. :)
              @Snille That is just awesome! Thank you!
              • Y Offline
                yawns Moderator
                Like cowboysdude I totally missed the link to your google gallery. The build is very amazing, I am a bit jealous on the 3D printer :)
                Very nice!
                • SnilleS Offline
                  Snille Module Developer @yawns
                  @yawns Thank you! :) I know the post is way to long, but when I see others builds, I always want to know how they did things. So I just included all the information at the top. So people don’t have to ask for it. :)
                  Y 1 Reply Last reply Reply Quote 1
                  • Y Offline
                    yawns Moderator @Snille
                    @Snille said in Snilles Magic Mirror Project:
                    In fact I read your post, I just did not notice the “see here” link under your photo :)
                    I do like to see how others created their mirror (or other things)
                    • SnilleS Offline
                      @yawns Hehe, yes. If you are about to buy a 3D-Printer, I can recommend a PRUSA 3D-Printer. It’s my third printer and it’s by far the best one I have had (I built the first one myself). I’ve been 3D-Printing stuff for about 6 years and it’s great if you really want to get things done your “own” way. :) You can find some of the stuff I’ve done here.
                      Y Mykle1M 2 Replies Last reply Reply Quote 1
                      • Y Offline
                        @Snille
                        I just bought a house, currently there is no budget for a 3D printer or any other “toys”. But I will get one in the future. Thanks for the reccomondation
                          Mykle1 Project Sponsor Module Developer @Snille
                          That ball sculpture is crazy cool!!!
                          SnilleS 1 Reply Last reply Reply Quote 1
                          • SnilleS Offline
                            Snille Module Developer @Mykle1
                            @Mykle1 Thank you! :) And I have not yet published all the drawings and files for this this sculpture. :)
                            Mykle1M 1 Reply Last reply Reply Quote 3
                              @Snille
                              Genius!
                              • SnilleS Offline
                                @ceddirr I saw your questions about the project… Answers below. :)
                                First, I forgot to say thank you for your kind words!
                                Question: “Which order is it? At first the IR frame, then the one way mirror, and finally the screen, is it correct?”
                                Answer: Correct, from the “front” the IR-Frame is first, placed directly on to the mirror and behind the mirror sits the screen. :)
                                Question: “I can see that the custom css of the MMM-Memo is already written in css file from the module’s folder. But, how do you manage to use it, and have this look with your memos? Mine are just white and simple… Thank you =)”
                                Answer: Well, I’m actually not doing so much in the CSS file. The only thing I set in the custom.css is the size of the Memo. The rest is “built in”.
                                This is the CSS part (in my custom.css file):
                                /* MMM-Memo -----------------------------------------*/
                                .MMM-Memo .small {
                                	font-family: "Roboto Condensed", sans-serif;
                                .note {
                                  width: 500px;
                                  height: 200px;
                                And this is in my config.js:
                                	module: "MMM-Memo",
                                	position: "upper_third",
                                	classes: "default everyone",
                                		memoTitle: "Flyginformation",
                                		memoDisplayIfEmpty: false,
                                		memoRotation: -4,
                                		format: "YYYY-MM-DD - HH:mm",
                                		memoWidth: 500,
                                		memoDisplayHeader: true,
                                		memoDisplayDuration: true,
                                		memoDisplayId: true,
                                		memoColorBackground: "LightGoldenrod",
                                		memoDisplayNotification: true,
                                You can see all the options for the config on the MMM-Memo’s git.
                                There are lot’s and lot’s of options for colors and themes. :)
                                • G Offline
                                  grillchips
                                  I’m about to pull the trigger on the IR touch frame but not really sure how thick it is. The description says it’s about 8.7mm, do you remember if that is somewhat correct for your panel? I don’t always trust Chinese specifications. :D
                                  Feels like the whole mirror frame needs to be quite thick to keep everything in place. The screen I have with the boards on the back is about 5.5cm already, adding the touch frame and mirror glas to that will make it REALLY thick and large…
                                  I know there’s slimmer screens out there but ~5-7cm depth might be what most of us have?
                                  • SnilleS Offline
                                    Snille Module Developer @grillchips
                                    @grillchips Yes, it’s correct. I did not measure it exactly, but the description is correct. Give or take 0,5 mm I would say.
                                    • G Offline
                                      grillchips
                                      Sweet, thanks!
                                      Talked to one of the sellers on Aliexpress and it seems like a 21.5" touch screen needs the glass while larger ones only needs the frame. That shouldn’t make any noticeable difference in performance/feel/look, right?
                                      • SnilleS Offline
                                        @grillchips Hmm… I don’t see why they would need the glass? It’s basically an array of IR leds on two sides and another array of IR receivers on the opposite two sides. I’m using a 32" frame and that worked in mid air when I tested. :)
                                        • G Offline
                                          grillchips
                                          Great to hear how it works! First time with a touch frame/panel for me so I’m a bit nervous.
                                          This is what they sent me:
                                          “Thanks for your inquiry. Yes, 27 inch and above size , we can send without glass. 21.5inch and 24inch, We need to send glass.”
                                          Really doesn’t tell why but I guess it doesn’t matter then… :D
                                          • SnilleS Offline
                                            @grillchips I don’t get the answer you got… Maybe they want to sell you a glass? :) Anyway, here is the store I bought mine from: https://www.aliexpress.com/store/922495?spm=a2g0s.9042311.0.0.9vCMC5
                                            I think they have “all” the sizes. :)
