I have some problems about config file
configproblem
16 Posts 5 Posters 8.0k Views 4 Watching
    AlexHpoin
    Last two weeks,I have began my project.But until now,I have faced a hard problems.
    My config.js has gone through the check without any problem.
    but It still can not work.
    Could someone help me find out where is wrong?
    THANK YOU VERY MUCH!!!
    var config = {
    	port: 8080,
    	ipWhitelist: [], // Set [] to allow all IP addresses
    	language: "zh",
    	timeFormat: 24,
    	units: "metric",
    			module: "alert",
    			module: "updatenotification",
    			position: "top_bar"
    			module: "clock",
    			position: "top_left"
    			header: "US Holidays",
    						symbol: "calendar-check-o ",
    			module: "compliments",
    			position: "lower_third"
    			module: "currentweather",
    				locationID: "1809062",  //ID from http://www.openweathermap.org/help/city_list.txt
    				appid: "c8d34ea2cd422XXXX4b1101e96e894d1"
    			module: "weatherforecast",
    			header: "Weather Forecast",
    				appid: "c8d34ea2cd422XXXXXXX101e96e894d1"
    			module: "newsfeed",
    			position: "bottom_bar",
    				feeds: [
    						title: "New York Times",
    				showSourceTitle: true,
    				showPublishDate: true
    T 1 Reply Last reply Aug 15, 2017, 2:20 PM Reply Quote 0
    • T Offline
      tomyboy96 Project Sponsor @AlexHpoin
      @AlexHpoin What happens when you boot it up?
      A 1 Reply Last reply Aug 15, 2017, 3:28 PM Reply Quote 0
        AlexHpoin @tomyboy96
        @tomyboy96
        It shows please create a config file.
        Thank you
        M T 2 Replies Last reply Aug 15, 2017, 6:28 PM Reply Quote 0
          Mykle1 Project Sponsor Module Developer @AlexHpoin
          @AlexHpoin said in I have some problems about config file:
          Are you sure it’s named config.js ?
          I just copied what you posted and it fired right up.
          • T Offline
            @AlexHpoin Have u saved the config file in the right place?
            • G Offline
              greda
              You must to have config.js in this path : cd /MagicMirror/config!
              If you use Putty
              If you use WinSCP
              If it does not work. I advise you to copy the original config.js.
              A 2 Replies Last reply Aug 16, 2017, 3:47 PM Reply Quote 0
                var config = {
                port: 8080,
                // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
                // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
                language: “zh”,
                timeFormat: 24,
                units: “metric”,
                module: “alert”,
                module: “updatenotification”,
                position: “top_bar”
                module: “clock”,
                position: “top_left”
                module: “calendar”,
                header: “US Holidays”,
                position: “top_left”,
                url: “webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics”
                module: “compliments”,
                position: “lower_third”
                module: “currentweather”,
                position: “top_right”,
                locationID: “1809062”, //ID from http://www.openweathermap.org/help/city_list.txt
                appid: “c8d34ea2cd422XXXX4b1101e96e894d1”
                module: “weatherforecast”,
                header: “Weather Forecast”,
                appid: “c8d34ea2cd422XXXXXXX101e96e894d1”
                module: “newsfeed”,
                position: “bottom_bar”,
                feeds: [
                title: “New York Times”,
                url: “http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml”
                Did MagicMirror install without any errors?
                A 1 Reply Last reply Aug 16, 2017, 3:38 PM Reply Quote 0
                  It is for just this type of situation that I wrote this:
                  How to create a working config - For absolute beginners
                    AlexHpoin @cowboysdude
                    @cowboysdude
                    npm WARN prefer global coffee-script@1.10.0 should be installed with -g
                    npm WARN prefer global jsonlint@1.6.2 should be installed with -g
                    npm WARN prefer global colorguard@1.2.0 should be installed with -g
                    > uws@0.14.5 install /var/www/html/node_modules/uws
                    > node-gyp rebuild > build_log.txt 2>&1 || exit 0
                      AlexHpoin @greda
                      @greda YES.I have saved my config.js to the right place```
                      /config/config.js
