    I have some problems about config file
    configproblem
    16 Posts 5 Posters 11.4k Views 4 Watching
    • A
      AlexHpoin @tomyboy96
      @tomyboy96
      It shows please create a config file.
      Thank you
      Mykle1M T 2 Replies Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @AlexHpoin
        @AlexHpoin said in I have some problems about config file:
        Are you sure it’s named config.js ?
        I just copied what you posted and it fired right up.
        • T
          tomyboy96 Project Sponsor @AlexHpoin
          @AlexHpoin Have u saved the config file in the right place?
          • G
            greda
            You must to have config.js in this path : cd /MagicMirror/config!
            If you use Putty
            If you use WinSCP
            If it does not work. I advise you to copy the original config.js.
            A 2 Replies Last reply
            • cowboysdudeC
              var config = {
              port: 8080,
              ipWhitelist: [], // Set [] to allow all IP addresses
              // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
              // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
              language: “zh”,
              timeFormat: 24,
              units: “metric”,
              module: “alert”,
              module: “updatenotification”,
              position: “top_bar”
              module: “clock”,
              position: “top_left”
              module: “calendar”,
              header: “US Holidays”,
              position: “top_left”,
              symbol: "calendar-check-o ",
              url: “webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics”
              module: “compliments”,
              position: “lower_third”
              module: “currentweather”,
              position: “top_right”,
              locationID: “1809062”, //ID from http://www.openweathermap.org/help/city_list.txt
              appid: “c8d34ea2cd422XXXX4b1101e96e894d1”
              module: “weatherforecast”,
              header: “Weather Forecast”,
              appid: “c8d34ea2cd422XXXXXXX101e96e894d1”
              module: “newsfeed”,
              position: “bottom_bar”,
              feeds: [
              title: “New York Times”,
              url: “http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml”
              showSourceTitle: true,
              showPublishDate: true
              Did MagicMirror install without any errors?
              A 1 Reply Last reply
              • Mykle1M
                It is for just this type of situation that I wrote this:
                How to create a working config - For absolute beginners
                • A
                  AlexHpoin @cowboysdude
                  @cowboysdude
                  npm WARN prefer global coffee-script@1.10.0 should be installed with -g
                  npm WARN prefer global jsonlint@1.6.2 should be installed with -g
                  npm WARN prefer global colorguard@1.2.0 should be installed with -g
                  > uws@0.14.5 install /var/www/html/node_modules/uws
                  > node-gyp rebuild > build_log.txt 2>&1 || exit 0
                  • A
                    AlexHpoin @greda
                    @greda YES.I have saved my config.js to the right place```
                    /config/config.js
                    • A
                      AlexHpoin @greda
                      @greda I use :
                      sudo mv /var/www/html/config/config.js.sample /var/www/html/config/config.js
                      to create my config file,and then reboot.
                      • cowboysdudeC
                        cowboysdude Module Developer @AlexHpoin
                        @AlexHpoin You should just be in the directory
                        ~MagicMirror/config
                        and type
                        cp config.js.sample config.js
                        Mykle1M A 2 Replies Last reply
                        • Mykle1M
                          @cowboysdude
                          Isn’t it crazy?
                          Reply Quote 2
                          • A
                            @cowboysdude I did…but it does not work…
                            • cowboysdudeC
                              @AlexHpoin At this point I would just start over.
                              There’s really no way of telling what happened. There seems to be an error of some kind, whether it’s file permission or something didn’t install correctly.
                              • Mykle1M
                                I’m curious. Did you even try or look at this?
                                https://forum.magicmirror.builders/topic/4528/how-to-create-a-working-config-for-absolute-beginners
