    I have some problems about config file
    configproblem
    16 Posts 5 Posters 11.1k Views 4 Watching
      Mykle1 Project Sponsor Module Developer @AlexHpoin
      @AlexHpoin said in I have some problems about config file:
      It shows please create a config file.
      Are you sure it’s named config.js ?
      I just copied what you posted and it fired right up.
      • T Offline
        tomyboy96 Project Sponsor @AlexHpoin
        @AlexHpoin Have u saved the config file in the right place?
        • G Offline
          greda
          You must to have config.js in this path : cd /MagicMirror/config!
          If you use Putty
          If you use WinSCP
          If it does not work. I advise you to copy the original config.js.
          A 2 Replies Last reply Reply Quote 0
          • cowboysdudeC Offline
            var config = {
            port: 8080,
            ipWhitelist: [], // Set [] to allow all IP addresses
            // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
            // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
            language: “zh”,
            timeFormat: 24,
            units: “metric”,
            module: “alert”,
            module: “updatenotification”,
            position: “top_bar”
            module: “clock”,
            position: “top_left”
            module: “calendar”,
            header: “US Holidays”,
            position: “top_left”,
            symbol: "calendar-check-o ",
            url: “webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics”
            module: “compliments”,
            position: “lower_third”
            module: “currentweather”,
            position: “top_right”,
            locationID: “1809062”, //ID from http://www.openweathermap.org/help/city_list.txt
            appid: “c8d34ea2cd422XXXX4b1101e96e894d1”
            module: “weatherforecast”,
            header: “Weather Forecast”,
            appid: “c8d34ea2cd422XXXXXXX101e96e894d1”
            module: “newsfeed”,
            position: “bottom_bar”,
            feeds: [
            title: “New York Times”,
            url: “http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml”
            showSourceTitle: true,
            showPublishDate: true
            Did MagicMirror install without any errors?
              It is for just this type of situation that I wrote this:
              How to create a working config - For absolute beginners
                AlexHpoin @cowboysdude
                @cowboysdude
                npm WARN prefer global coffee-script@1.10.0 should be installed with -g
                npm WARN prefer global jsonlint@1.6.2 should be installed with -g
                npm WARN prefer global colorguard@1.2.0 should be installed with -g
                > uws@0.14.5 install /var/www/html/node_modules/uws
                > node-gyp rebuild > build_log.txt 2>&1 || exit 0
                  AlexHpoin @greda
                  @greda YES.I have saved my config.js to the right place```
                  /config/config.js
                    AlexHpoin @greda
                    @greda I use :
                    sudo mv /var/www/html/config/config.js.sample /var/www/html/config/config.js
                    to create my config file,and then reboot.
                      cowboysdude Module Developer @AlexHpoin
                      @AlexHpoin You should just be in the directory
                      ~MagicMirror/config
                      and type
                      cp config.js.sample config.js
                      Mykle1M A 2 Replies Last reply Reply Quote 1
                        @cowboysdude
                        Isn’t it crazy?
                          @cowboysdude I did…but it does not work…
                            @AlexHpoin At this point I would just start over.
                            There’s really no way of telling what happened. There seems to be an error of some kind, whether it’s file permission or something didn’t install correctly.
                              I’m curious. Did you even try or look at this?
                              https://forum.magicmirror.builders/topic/4528/how-to-create-a-working-config-for-absolute-beginners
