    I have some problems about config file
    configproblem
    16 Posts 5 Posters 11.2k Views 4 Watching
    • T
      tomyboy96 Project Sponsor @AlexHpoin
      @AlexHpoin What happens when you boot it up?
      • A
        AlexHpoin @tomyboy96
        @tomyboy96
        It shows please create a config file.
        Thank you
        Mykle1M T 2 Replies Last reply Reply Quote 0
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @AlexHpoin
          @AlexHpoin said in I have some problems about config file:
          Are you sure it’s named config.js ?
          I just copied what you posted and it fired right up.
          • T
            @AlexHpoin Have u saved the config file in the right place?
            • G
              greda
              You must to have config.js in this path : cd /MagicMirror/config!
              If you use Putty
              If you use WinSCP
              If it does not work. I advise you to copy the original config.js.
              A 2 Replies Last reply Reply Quote 0
              • cowboysdudeC
                var config = {
                port: 8080,
                ipWhitelist: [], // Set [] to allow all IP addresses
                // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
                // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
                language: “zh”,
                timeFormat: 24,
                units: “metric”,
                module: “alert”,
                module: “updatenotification”,
                position: “top_bar”
                module: “clock”,
                position: “top_left”
                module: “calendar”,
                header: “US Holidays”,
                position: “top_left”,
                symbol: "calendar-check-o ",
                url: “webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics”
                module: “compliments”,
                position: “lower_third”
                module: “currentweather”,
                position: “top_right”,
                locationID: “1809062”, //ID from http://www.openweathermap.org/help/city_list.txt
                appid: “c8d34ea2cd422XXXX4b1101e96e894d1”
                module: “weatherforecast”,
                header: “Weather Forecast”,
                appid: “c8d34ea2cd422XXXXXXX101e96e894d1”
                module: “newsfeed”,
                position: “bottom_bar”,
                feeds: [
                title: “New York Times”,
                url: “http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml”
                showSourceTitle: true,
                showPublishDate: true
                Did MagicMirror install without any errors?
                • Mykle1M
                  It is for just this type of situation that I wrote this:
                  How to create a working config - For absolute beginners
                  • A
                    AlexHpoin @cowboysdude
                    @cowboysdude
                    npm WARN prefer global coffee-script@1.10.0 should be installed with -g
                    npm WARN prefer global jsonlint@1.6.2 should be installed with -g
                    npm WARN prefer global colorguard@1.2.0 should be installed with -g
                    > uws@0.14.5 install /var/www/html/node_modules/uws
                    > node-gyp rebuild > build_log.txt 2>&1 || exit 0
                    • A
                      AlexHpoin @greda
                      @greda YES.I have saved my config.js to the right place```
                      /config/config.js
                      • A
                        AlexHpoin @greda
                        @greda I use :
                        sudo mv /var/www/html/config/config.js.sample /var/www/html/config/config.js
                        to create my config file,and then reboot.
                        • cowboysdudeC
                          cowboysdude Module Developer @AlexHpoin
                          @AlexHpoin You should just be in the directory
                          ~MagicMirror/config
                          and type
                          cp config.js.sample config.js
                          Mykle1M A 2 Replies Last reply Reply Quote 1
                          • Mykle1M
                            @cowboysdude
                            Isn’t it crazy?
                            • A
                              @cowboysdude I did…but it does not work…
                              • cowboysdudeC
                                @AlexHpoin At this point I would just start over.
                                There’s really no way of telling what happened. There seems to be an error of some kind, whether it’s file permission or something didn’t install correctly.
                                • Mykle1M
                                  I’m curious. Did you even try or look at this?
                                  https://forum.magicmirror.builders/topic/4528/how-to-create-a-working-config-for-absolute-beginners
