I have some problems about config file
Last two weeks,I have began my project.But until now,I have faced a hard problems.
My config.js has gone through the check without any problem.
but It still can not work.
Could someone help me find out where is wrong?
THANK YOU VERY MUCH!!!var config = { port: 8080, ipWhitelist: [], // Set [] to allow all IP addresses // or add a specific IPv4 of 192.168.1.5 : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.5"], // or IPv4 range of 192.168.3.0 --> 192.168.3.15 use CIDR format : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/28"], language: "zh", timeFormat: 24, units: "metric", modules: [ { module: "alert", }, { module: "updatenotification", position: "top_bar" }, { module: "clock", position: "top_left" }, { module: "calendar", header: "US Holidays", position: "top_left", config: { calendars: [ { symbol: "calendar-check-o ", url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics" } ] } }, { module: "compliments", position: "lower_third" }, { module: "currentweather", position: "top_right", config: { location: "New York", locationID: "1809062", //ID from http://www.openweathermap.org/help/city_list.txt appid: "c8d34ea2cd422XXXX4b1101e96e894d1" } }, { module: "weatherforecast", position: "top_right", header: "Weather Forecast", config: { location: "New York", locationID: "1809062", //ID from http://www.openweathermap.org/help/city_list.txt appid: "c8d34ea2cd422XXXXXXX101e96e894d1" } }, { module: "newsfeed", position: "bottom_bar", config: { feeds: [ { title: "New York Times", url: "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml" } ], showSourceTitle: true, showPublishDate: true } }, ] }; /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== "undefined") {module.exports = config;} -
@AlexHpoin What happens when you boot it up?
@tomyboy96
It shows please create a config file.
Thank you -
@AlexHpoin said in I have some problems about config file:
Are you sure it’s named
config.js?I just copied what you posted and it fired right up.
@AlexHpoin Have u saved the config file in the right place?
You must to have config.js in this path : cd /MagicMirror/config!
If you use Putty
If you use WinSCP
If it does not work. I advise you to copy the original config.js.
var config = {
port: 8080,
// [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
// [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],language: “zh”,
timeFormat: 24,
units: “metric”,modules: [
module: “alert”,
module: “updatenotification”,
position: “top_bar”
module: “clock”,
position: “top_left”
module: “calendar”,
header: “US Holidays”,
position: “top_left”,
url: “webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics”
module: “compliments”,
position: “lower_third”
module: “currentweather”,
position: “top_right”,
locationID: “1809062”, //ID from http://www.openweathermap.org/help/city_list.txt
appid: “c8d34ea2cd422XXXX4b1101e96e894d1”
module: “weatherforecast”,
header: “Weather Forecast”,
appid: “c8d34ea2cd422XXXXXXX101e96e894d1”
module: “newsfeed”,
position: “bottom_bar”,
feeds: [
title: “New York Times”,
url: “http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml”
Did MagicMirror install without any errors?
It is for just this type of situation that I wrote this:
npm WARN prefer global coffee-script@1.10.0 should be installed with -g npm WARN prefer global jsonlint@1.6.2 should be installed with -g npm WARN prefer global colorguard@1.2.0 should be installed with -g > uws@0.14.5 install /var/www/html/node_modules/uws > node-gyp rebuild > build_log.txt 2>&1 || exit 0 -
@greda YES.I have saved my config.js to the right place```
/config/config.js -
@greda I use :
sudo mv /var/www/html/config/config.js.sample /var/www/html/config/config.jsto create my config file,and then reboot.
@AlexHpoin You should just be in the directory
~MagicMirror/config
and typecp config.js.sample config.js
Isn’t it crazy?
@cowboysdude I did…but it does not work…
@AlexHpoin At this point I would just start over.
There’s really no way of telling what happened. There seems to be an error of some kind, whether it’s file permission or something didn’t install correctly.
I’m curious. Did you even try or look at this?
https://forum.magicmirror.builders/topic/4528/how-to-create-a-working-config-for-absolute-beginners
