    config error somewhere, need help
    21 Posts 7 Posters 11.1k Views 7 Watching
    • T Offline
      TaylorTech22
      I ran it through a syntax validator and everything checks out with that, but I’m still getting the Please create a config file error. I was modifying the MMM-iFrame module and hit a wrong key and the config closed. after bringing it back open i saved and reloaded and now nothing. I cant figure it out. Thanks for any help. Here’s my config file:
      var config = {
              port: 8080,
              language: "en",
              timeFormat: 12,
              units: "imperial",
                              module: "alert",
                              module: "updatenotification",
                              position: "top_bar"
                              module: 'MMM-GoogleMapsTraffic',
                              position: 'middle_center',
                              key: 'AIzaSyAQ7aXDzoA9IPfkxFmsl-V2HAat_vU0LhE',
                              lat: 41.5670065,
                              lng: -87.160403,
                              height: '300px',
                              width: '500px'
                              module: "clock",
                              position: "top_center",
                              timezone: "America/Chicago"
                              module: 'MMM-iFrame',
                              position: 'bottom_bar',
                                      url: ["https://app.actiontiles.com/panel/a8583a72-680a-47ea-8f51-7264b23617df"],
                                      updateInterval: 0.5 * 60 * 1000,
                                      width: "100%",
                                      height: "510px"
                              header: "US Holidays",
                                                      symbol: "calendar-check-o ",
                              module: "compliments",
                              position: "lower_third"
                              module: "currentweather",
                                      locationID: "4925006",  //ID from http://www.openweathermap.org/help/city_list.txt
                                      appid: "6666861a53a2f121c1e1f0f76accef00"
                              module: "weatherforecast",
                              header: "Weather Forecast",
                              module: 'MMM-Nest',
                              position: 'top_right',
                                      token:"c.iaFlhM5fBxDothVhOjhmeYA4ETBv0wCk175fAjgyfGZlXTvFGjOTdbzRG1zF117wqzduags7XigHcP4Lxb4t18g6YkVxmm7z0IbaHGYvLNFoO5zFgxe3k0Z3oDhsGL9LhBglQVohNeEUYQOc",
                                      displayType: 'visual',
                                      displayMode: 'nest'
                              module: "newsfeed",
                              position: "top_bar",
                                      feeds: [
                                                      title: "New York Times",
                                      showSourceTitle: true,
                                      showPublishDate: true
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @TaylorTech22
        @TaylorTech22 do you have the following line at the bottom?
        also is your config file named correctly
        T 2 Replies Last reply Reply Quote 0
        • T Offline
          TaylorTech22 @strawberry 3.141
          @strawberry-3.141 yes i do i just didnt include in the copy-paste
          • T Offline
            @strawberry-3.141 config/config. js is what I enter
            • I Offline
              iamoric
              @TaylorTech22 Did you to remove the modules one by one to see which one is going wrong ?
              • cowboysdudeC Offline
                My suggestion would be start over… use the standard config and add one thing at a time…see if it works then add the next until you get to what’s not working…
                  cowboysdude Module Developer @TaylorTech22
                  @TaylorTech22 said in config error somewhere, need help:
                  What do you mean?
                    another thing I could spot from viewing your config is that the timezone for the clock module should go into a config: {}, but this will not help you out with the black screen.
                      A Former User
                      Somebody should make EASY configuration system, or… all module developers should provide DEFAULT ACTIVE SAMPLE CONFIGURATION.
                      Or, at least, neater JSlint parser should be supported.
                      strawberry 3.141S Mykle1M 2 Replies Last reply Reply Quote 0
                        strawberry 3.141 Project Sponsor Module Developer @Guest
                        @Sean all you mentioned exists ;)
                          A Former User @strawberry 3.141
                          @strawberry-3.141 ??? exists?
                          • T Offline
                            TaylorTech22 @cowboysdude
                            @cowboysdude @strawberry-3-141 asked if my config file was named correctly
                              @Sean there is remotecontrol and admininterface to configure the mirror, most of the devs supply a sample config without api keys and and somewhere out there is a linter https://twitter.com/roramirez/ status/843121280601669632 @roramirez
                              ? R 2 Replies Last reply Reply Quote 0
                              • T Offline
                                @cowboysdude so whats the easy way to start over? may seem like a dumb question, but how to I remove current config and use default
                                  @TaylorTech22 here is the sample config file https://github.com/MichMich/MagicMirror/blob/master/config/config.js.sample
                                  • T Offline
                                    @strawberry-3.141 just delete whats in there and paste this?
                                    • T Offline
                                      TaylorTech22
                                      well, I figured it out… Thats what i get for not pasting the ENTIRE file into the syntax checker. The very first item of very first line had a ] before the text. dont know how it got there. good thing i copied my original config in a text editor. Thanks for all the help.
                                      ? 1 Reply Last reply Reply Quote 2
                                        @strawberry-3.141 Sounds nice. but looks not sufficient for beginners. (For me, sometimes configuration problem throws a headache to me. Even that module was which I made.) Maybe we need totally different approach in next version.(But I have no idea how to do. )
                                        I’m not a developer, I worked as products and business designer, so I meet not only experts but also the end users in every day . One thing I’ve found, MM is a real good toy for hobbyists. but this approach is somehow difficult to who is not familiar with IT.
                                        Whatever, my mention was just grumbling. nevermind. :)
                                          A Former User @TaylorTech22
                                          @TaylorTech22 Congratulation! :D
                                            Mykle1 Project Sponsor Module Developer @Guest
                                            @Sean said in config error somewhere, need help:
                                            Personally, I DO provide a config entry with each module and I think most others do, as well. However, I have seen some that were not complete, where copying and pasting would only result in an error.
                                            In the meantime, I refer people to How to add modules, which should give them a better understanding of the process.
