    config error somewhere, need help
    21 Posts 7 Posters 12.4k Views 7 Watching
    • cowboysdudeC Offline
      My suggestion would be start over… use the standard config and add one thing at a time…see if it works then add the next until you get to what’s not working…
        cowboysdude Module Developer @TaylorTech22
        @TaylorTech22 said in config error somewhere, need help:
        @strawberry-3.141 config/config. js is what I enter
        What do you mean?
        • strawberry 3.141S Offline
          another thing I could spot from viewing your config is that the timezone for the clock module should go into a config: {}, but this will not help you out with the black screen.
            A Former User
            Somebody should make EASY configuration system, or… all module developers should provide DEFAULT ACTIVE SAMPLE CONFIGURATION.
            Or, at least, neater JSlint parser should be supported.
            strawberry 3.141S Mykle1M 2 Replies Last reply Reply Quote 0
              strawberry 3.141 Project Sponsor Module Developer @Guest
              @Sean all you mentioned exists ;)
                A Former User @strawberry 3.141
                @strawberry-3.141 ??? exists?
                • T Offline
                  TaylorTech22 @cowboysdude
                  @cowboysdude @strawberry-3-141 asked if my config file was named correctly
                    @Sean there is remotecontrol and admininterface to configure the mirror, most of the devs supply a sample config without api keys and and somewhere out there is a linter https://twitter.com/roramirez/ status/843121280601669632 @roramirez
                    ? R 2 Replies Last reply Reply Quote 0
                    • T Offline
                      @cowboysdude so whats the easy way to start over? may seem like a dumb question, but how to I remove current config and use default
                        strawberry 3.141 Project Sponsor Module Developer @TaylorTech22
                        @TaylorTech22 here is the sample config file https://github.com/MichMich/MagicMirror/blob/master/config/config.js.sample
                        • T Offline
                          TaylorTech22 @strawberry 3.141
                          @strawberry-3.141 just delete whats in there and paste this?
                          • T Offline
                            TaylorTech22
                            well, I figured it out… Thats what i get for not pasting the ENTIRE file into the syntax checker. The very first item of very first line had a ] before the text. dont know how it got there. good thing i copied my original config in a text editor. Thanks for all the help.
                            ? 1 Reply Last reply Reply Quote 2
                              @strawberry-3.141 Sounds nice. but looks not sufficient for beginners. (For me, sometimes configuration problem throws a headache to me. Even that module was which I made.) Maybe we need totally different approach in next version.(But I have no idea how to do. )
                              I’m not a developer, I worked as products and business designer, so I meet not only experts but also the end users in every day . One thing I’ve found, MM is a real good toy for hobbyists. but this approach is somehow difficult to who is not familiar with IT.
                              Whatever, my mention was just grumbling. nevermind. :)
                                A Former User @TaylorTech22
                                @TaylorTech22 Congratulation! :D
                                  Mykle1 Project Sponsor Module Developer @Guest
                                  @Sean said in config error somewhere, need help:
                                  Personally, I DO provide a config entry with each module and I think most others do, as well. However, I have seen some that were not complete, where copying and pasting would only result in an error.
                                  In the meantime, I refer people to How to add modules, which should give them a better understanding of the process.
                                    roramirez Core Contributors @strawberry 3.141
                                    @strawberry-3.141 said in config error somewhere, need help:
                                    This feature is include in the last release. Now you can use npm run config:check for check the configuration file :)
