    config error somewhere, need help
    21 Posts 7 Posters 12.4k Views 7 Watching
      A Former User @strawberry 3.141
      @strawberry-3.141 ??? exists?
      • T Offline
        TaylorTech22 @cowboysdude
        @cowboysdude @strawberry-3-141 asked if my config file was named correctly
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @Guest
          @Sean there is remotecontrol and admininterface to configure the mirror, most of the devs supply a sample config without api keys and and somewhere out there is a linter https://twitter.com/roramirez/ status/843121280601669632 @roramirez
          ? R 2 Replies Last reply Reply Quote 0
          • T Offline
            @cowboysdude so whats the easy way to start over? may seem like a dumb question, but how to I remove current config and use default
              strawberry 3.141 Project Sponsor Module Developer @TaylorTech22
              @TaylorTech22 here is the sample config file https://github.com/MichMich/MagicMirror/blob/master/config/config.js.sample
              • T Offline
                TaylorTech22 @strawberry 3.141
                @strawberry-3.141 just delete whats in there and paste this?
                • T Offline
                  TaylorTech22
                  well, I figured it out… Thats what i get for not pasting the ENTIRE file into the syntax checker. The very first item of very first line had a ] before the text. dont know how it got there. good thing i copied my original config in a text editor. Thanks for all the help.
                  ? 1 Reply Last reply Reply Quote 2
                    @strawberry-3.141 Sounds nice. but looks not sufficient for beginners. (For me, sometimes configuration problem throws a headache to me. Even that module was which I made.) Maybe we need totally different approach in next version.(But I have no idea how to do. )
                    I’m not a developer, I worked as products and business designer, so I meet not only experts but also the end users in every day . One thing I’ve found, MM is a real good toy for hobbyists. but this approach is somehow difficult to who is not familiar with IT.
                    Whatever, my mention was just grumbling. nevermind. :)
                      A Former User @TaylorTech22
                      @TaylorTech22 Congratulation! :D
                        Mykle1 Project Sponsor Module Developer @Guest
                        @Sean said in config error somewhere, need help:
                        all module developers should provide DEFAULT ACTIVE SAMPLE CONFIGURATION.
                        Personally, I DO provide a config entry with each module and I think most others do, as well. However, I have seen some that were not complete, where copying and pasting would only result in an error.
                        In the meantime, I refer people to How to add modules, which should give them a better understanding of the process.
                          roramirez Core Contributors @strawberry 3.141
                          @strawberry-3.141 said in config error somewhere, need help:
                          This feature is include in the last release. Now you can use npm run config:check for check the configuration file :)
