    config error somewhere, need help
    21 Posts 7 Posters 10.5k Views 7 Watching
    • T Offline
      TaylorTech22 @strawberry 3.141
      @strawberry-3.141 config/config. js is what I enter
      • I Offline
        iamoric
        @TaylorTech22 Did you to remove the modules one by one to see which one is going wrong ?
        • cowboysdudeC Offline
          My suggestion would be start over… use the standard config and add one thing at a time…see if it works then add the next until you get to what’s not working…
            cowboysdude Module Developer @TaylorTech22
            @TaylorTech22 said in config error somewhere, need help:
            What do you mean?
            • strawberry 3.141S Offline
              another thing I could spot from viewing your config is that the timezone for the clock module should go into a config: {}, but this will not help you out with the black screen.
                A Former User
                Somebody should make EASY configuration system, or… all module developers should provide DEFAULT ACTIVE SAMPLE CONFIGURATION.
                Or, at least, neater JSlint parser should be supported.
                strawberry 3.141S Mykle1M 2 Replies Last reply Reply Quote 0
                  strawberry 3.141 Project Sponsor Module Developer @Guest
                  @Sean all you mentioned exists ;)
                    A Former User @strawberry 3.141
                    @strawberry-3.141 ??? exists?
                    • T Offline
                      TaylorTech22 @cowboysdude
                      @cowboysdude @strawberry-3-141 asked if my config file was named correctly
                        @Sean there is remotecontrol and admininterface to configure the mirror, most of the devs supply a sample config without api keys and and somewhere out there is a linter https://twitter.com/roramirez/ status/843121280601669632 @roramirez
                        ? R 2 Replies Last reply Reply Quote 0
