      pjkoeleman @Nystro0m
      @Nystro0m
      Looks to me that there is two times the same code in the js-file ecxept for the language settings. So @cowboysdude has to look into this.
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @pjkoeleman
        @pjkoeleman said in MMM-NOAA - Another Weather Module:
        He’s doing a roofing job in 90° heat at the moment. On a Sunday! Who does that?
        I’m sure he’ll fix it as soon as possible. That’s what he does.
        • cowboysdudeC
          @Nystro0m and @pjkoeleman
          Thank you both!!! IT was doubled, not sure how that happened but all fixed!! :)
          Nystro0mN 1 Reply Last reply Reply Quote 0
            Johans
            installed module last night, settings all according the help file, but nothing is displayed.
            Switched back to the wunderground module, that’s working fine.
            any idea. I suppose that when the API key is working with the Wunderground module it should work with yours too.
            what information do i need to provide for further investigation - also tell me how to get that. (I’m newbee - sorry for this - i’m in a learning process )
            (language was set to “nl” and then changed again to “en”).
            And I see module is loaded, but not displayed.
            cowboysdudeC Nystro0mN 2 Replies Last reply Reply Quote 0
            • cowboysdudeC
              cowboysdude Module Developer @Johans
              @Johans check the console log and see what that tells you when it’s loading…
              You need to start your mirror and hit the ‘ALT’ key there will be a menu at the top…you want ‘toggle developer…’
              That’ll open up a side panel on the right and it will tell you what error there is…let me know so I can help you fix it :)
              • Nystro0mN
                Nystro0m @Johans
                @Johans
                Im running on a Raspberry pi B ver.1 and it have some problems loading information from time to time when it been pushed to far.
                I would make sure that it is no error in the console from NOAA or other modules:
                Either by Comwboysdude method, but you could also run: “npm start dev” when starting MagicMirror.
                Another way that i did find more speed efficient is to open the MagicMirror interface on a secondary computer by going to: “Your.PI.LocalIP:8080/”.
                And then right-click and choose “inspect” in Chrome. Here you can find the console.
                Make sure to have your WhitelistIP set properly.
                I could also recommend Jophys - Remote Control Module.
                With this you can restart you MagicMirror, enter the web interface and such remotely if you are not comfortable with ssh.
                  Johans @Nystro0m
                  @Nystro0m
                  thanks, learned again something new, on how to remotely connect to the MagicMirror.
                  Meanwhile problem is solved.
                  removed the line 400.
                  these chars created an error ==========
                    Johans @cowboysdude
                    @cowboysdude
                    thanks for showing me how to track & trace errors.
                    Found root cause - line 400 in module MMM-NOAA.js.
                    I removed the =========.
                    Also added the “nl”: “nl-NL” into the lang file section.
                    So now it’s all working - and in dutch - makes my wife happy :).
                    Very beautifull - thanks for you support.
                    • cowboysdudeC
                      @Johans said in MMM-NOAA - Another Weather Module:
                      @cowboysdude
                      You are welcome… yes I fixed that on Github
                      Thank you!!! :)
                      Glad you made your wife happy! We have a saying here…
                      “Happy wife, happy life.” HAHAA
                      • Nystro0mN
                        Nystro0m @cowboysdude
                        @cowboysdude
                        This update made messed up the CSS a bit, this screenshot is from default main.css and NOAA.css
                        alt text
                        The table content regarding the forecast data is fixed by:
                        .MMM-NOAA .tdh{
                        display: table;
                        That also make it align to the right, fixing a problem where the are not align properly if the lowest/highest temperature indexing inconsistent between tenths and some bellow (adding a number) for example :
                        (up) 10 (down) 8
                        (up) 16 (down) 11
                        Also, wFont does not response to font-size anymore. Im currently investing in this.
                        .MMM-NOAA .wFont {
                        And the barometer logo i can’t seem to find the resize option, i got around this by manipulating to core image.
                        I would also appriciate if there is a possibility to could change the “daylight”, “uv-index” and “humidify” colors in the .css.
                        Here are a Swedish translation for “Amount of daylight”:
                        Tillgängligt dagsljus
                        I found that this already consist in the translation-file. Does not seem to be loading for me.
                        • cowboysdudeC
                          cowboysdude Module Developer @Nystro0m
                          @Nystro0m Something is wrong with the layout… I’ll look at this later. Sorry about that.
                          What version of MM are you running? My dev machine is running 2.1.0 so that may be a reason you’re having issues… if you’re running a newer version so I just learned [Thanks @Mykle1]
                          Nystro0mN Mykle1M 2 Replies Last reply Reply Quote 1
                          • Nystro0mN
                            @cowboysdude
                            No worries. Im running the latest version of MM and NOAA.
                            There is no hurry, i have customized the css to fit my need for now :)
                            Happy to help out if there is something you need to be tested etc.
                            • cowboysdudeC
                              @Nystro0m said in MMM-NOAA - Another Weather Module:
                              @cowboysdude
                              We tried running it on the dev version of the mirror and it had lots of errors LOL
                              BUT that is a dev version… I’m running 2.1.0 because it runs on windows without having to do git bash windows stuff … I try running newer versions of MM but I just get all kinds of errors with MM and it won’t run so back to 2.1.0…
                              If I need anything I’ll let you know and I do appreciate your help!! :) Thank you!
                              [PS I am working on an update …changing the format of the bottom 4 day forecast ;) Shhhhh don’t tell anyone hahahahahha].
                              • Nystro0mN
                                @cowboysdude said in MMM-NOAA - Another Weather Module:
                                Haha i promise, i wont tell a soul lol! Looking forward for the update!
                                I also found out today i had excellently messed up my custom.css when trying to backup things.
                                So i think that that one could had unable me to adjust the wFont.
                                • Mykle1M
                                  Няма проблем моят приятел :^)
                                  • tbbearT
                                    tbbear Module Developer
                                    i love ur weather modul but i am from Germany so a few settings do not fit for my country.
                                    i already made a few changes to fix them so maybe i can help u in ur german version. Also u should
                                    update ur readme cause it took me a long time to find out where to get the key for the air values.
                                    I made a new translation for ur module according to the french one and i also changed a few lines in ur xx.js.
                                    Please let me know if its ok and u maybe like assistance for ur german version.
                                    "GATHERING WEATHER STUFF": "Empfange Wetterdaten...",
                                    "Currently: ": "Aktuell: ",
                                    "Current Temp: ": "Momentane Temperatur: ",
                                    "UV Index: ": "UV-Index: ",
                                    "Wind: ": "Wind: ",
                                    "From: ": "von: ",
                                    "Barometer: ": "Barometer: ",
                                    "Monday": "Montag",
                                    "Tuesday": "Dienstag",
                                    "Wednesday": "Mittwoch",
                                    "Thursday": "Donnerstag",
                                    "Friday": "Freitag",
                                    "Saturday": "Samstag",
                                    "Sunday": "Sonntag",
                                    "Overcast": "Bedeckt",
                                    "Cloudy": "Wolkig",
                                    "Rain": "Regen",
                                    "Clear": "Klar",
                                    "Partly Cloudy": "Teilweise bewölkt",
                                    "Snow showers": "Schneeschauer",
                                    "High:  ": "Hoch: ",
                                    "Low:  ": "Niedrig: ",
                                    "Humidity: ": "Feuchtigkeit: ",
                                    "Safe": "Sicher",
                                    "Moderate": "Moderat",
                                    "Very High": "Sehr hoch",
                                    "Extreme": "Extrem",
                                    "Sunset": "Sonnenuntergang",
                                    "Sunrise": "Sonnenaufgang",
                                    " hours ": " Std. ",
                                    " minutes ": " Min. ",
                                    "Amount of Daylight": "Stunden mit Tageslicht",
                                    "Good Morning ":"Guten Morgen ",
                                    "Good Afternoon ": "Guten Nachmittag ",
                                    "Good Evening ": "Guten Abend ",
                                    "Air Quality Index: ":"Luftqualitätsindex: "
                                    this was my new translation
                                    and this i changed in your ...js
                                    	var curCon = document.createElement("div");
                                    	curCon.classList.add("xsmall", "bright");
                                    	curCon.innerHTML = this.translate("Currently: ") + this.translate(current.weather);
                                    	wrapper.appendChild(curCon);
                                    Robert the Bear
                                    • cowboysdudeC
                                      cowboysdude Module Developer @tbbear
                                      @tbbear said in MMM-NOAA - Another Weather Module:
                                      “GATHERING WEATHER STUFF”: “Empfange Wetterdaten…”,
                                      "Wind: ": "Wind: ",
                                      "From: ": "von: ",
                                      “Monday”: “Montag”,
                                      “Tuesday”: “Dienstag”,
                                      “Wednesday”: “Mittwoch”,
                                      “Thursday”: “Donnerstag”,
                                      “Friday”: “Freitag”,
                                      “Saturday”: “Samstag”,
                                      “Sunday”: “Sonntag”,
                                      “Overcast”: “Bedeckt”,
                                      “Cloudy”: “Wolkig”,
                                      “Rain”: “Regen”,
                                      “Clear”: “Klar”,
                                      “Partly Cloudy”: “Teilweise bewölkt”,
                                      “Snow showers”: “Schneeschauer”,
                                      "High: ": "Hoch: ",
                                      “Safe”: “Sicher”,
                                      “Moderate”: “Moderat”,
                                      “Very High”: “Sehr hoch”,
                                      “Extreme”: “Extrem”,
                                      “Sunset”: “Sonnenuntergang”,
                                      “Sunrise”: “Sonnenaufgang”,
                                      “Amount of Daylight”: “Stunden mit Tageslicht”,
                                      So this is German? :)
                                      Nystro0mN 1 Reply Last reply Reply Quote 2
                                      • Nystro0mN
                                        @cowboysdude Haha yes! That is for sure German :)
                                        • cowboysdudeC
                                          @Nystro0m LOL right now I barely know what direction I’m going… I am SO busy with work… I will make the changes… LOL
                                          Would be SUPER easier if it were done on github with a pull request ;)
                                          • Nystro0mN
                                            Nystro0m
                                            @cowboysdude Im reinstalling my Mirror to .2.10 through ssh. So alot of waiting. Got a fresh cup of tea. Im on IT!
                                            Mykle1M cowboysdudeC 2 Replies Last reply Reply Quote 2
                                            • 34
                                            • 35
                                            • 4 / 35
