    690 Posts 77 Posters 3.0m Views 70 Watching
    • cowboysdudeC Offline
      cowboysdude Module Developer @Johans
      @Johans check the console log and see what that tells you when it’s loading…
      You need to start your mirror and hit the ‘ALT’ key there will be a menu at the top…you want ‘toggle developer…’
      That’ll open up a side panel on the right and it will tell you what error there is…let me know so I can help you fix it :)
      • Nystro0mN Offline
        Nystro0m @Johans
        @Johans
        Im running on a Raspberry pi B ver.1 and it have some problems loading information from time to time when it been pushed to far.
        I would make sure that it is no error in the console from NOAA or other modules:
        Either by Comwboysdude method, but you could also run: “npm start dev” when starting MagicMirror.
        Another way that i did find more speed efficient is to open the MagicMirror interface on a secondary computer by going to: “Your.PI.LocalIP:8080/”.
        And then right-click and choose “inspect” in Chrome. Here you can find the console.
        Make sure to have your WhitelistIP set properly.
        I could also recommend Jophys - Remote Control Module.
        With this you can restart you MagicMirror, enter the web interface and such remotely if you are not comfortable with ssh.
          Johans @Nystro0m
          @Nystro0m
          thanks, learned again something new, on how to remotely connect to the MagicMirror.
          Meanwhile problem is solved.
          removed the line 400.
          these chars created an error ==========
            Johans @cowboysdude
            @cowboysdude
            thanks for showing me how to track & trace errors.
            Found root cause - line 400 in module MMM-NOAA.js.
            I removed the =========.
            Also added the “nl”: “nl-NL” into the lang file section.
            So now it’s all working - and in dutch - makes my wife happy :).
            Very beautifull - thanks for you support.
              @Johans said in MMM-NOAA - Another Weather Module:
              @cowboysdude
              You are welcome… yes I fixed that on Github
              Thank you!!! :)
              Glad you made your wife happy! We have a saying here…
              “Happy wife, happy life.” HAHAA
              • Nystro0mN Offline
                Nystro0m @cowboysdude
                @cowboysdude
                This update made messed up the CSS a bit, this screenshot is from default main.css and NOAA.css
                alt text
                The table content regarding the forecast data is fixed by:
                .MMM-NOAA .tdh{
                display: table;
                That also make it align to the right, fixing a problem where the are not align properly if the lowest/highest temperature indexing inconsistent between tenths and some bellow (adding a number) for example :
                (up) 10 (down) 8
                (up) 16 (down) 11
                Also, wFont does not response to font-size anymore. Im currently investing in this.
                .MMM-NOAA .wFont {
                And the barometer logo i can’t seem to find the resize option, i got around this by manipulating to core image.
                I would also appriciate if there is a possibility to could change the “daylight”, “uv-index” and “humidify” colors in the .css.
                Here are a Swedish translation for “Amount of daylight”:
                Tillgängligt dagsljus
                I found that this already consist in the translation-file. Does not seem to be loading for me.
                  cowboysdude Module Developer @Nystro0m
                  @Nystro0m Something is wrong with the layout… I’ll look at this later. Sorry about that.
                  What version of MM are you running? My dev machine is running 2.1.0 so that may be a reason you’re having issues… if you’re running a newer version so I just learned [Thanks @Mykle1]
                  Nystro0mN Mykle1M 2 Replies Last reply Reply Quote 1
                  • Nystro0mN Offline
                    @cowboysdude
                    No worries. Im running the latest version of MM and NOAA.
                    There is no hurry, i have customized the css to fit my need for now :)
                    Happy to help out if there is something you need to be tested etc.
                      @Nystro0m said in MMM-NOAA - Another Weather Module:
                      @cowboysdude
                      We tried running it on the dev version of the mirror and it had lots of errors LOL
                      BUT that is a dev version… I’m running 2.1.0 because it runs on windows without having to do git bash windows stuff … I try running newer versions of MM but I just get all kinds of errors with MM and it won’t run so back to 2.1.0…
                      If I need anything I’ll let you know and I do appreciate your help!! :) Thank you!
                      [PS I am working on an update …changing the format of the bottom 4 day forecast ;) Shhhhh don’t tell anyone hahahahahha].
                      Nystro0mN 1 Reply Last reply Reply Quote 0
                      • Nystro0mN Offline
                        @cowboysdude said in MMM-NOAA - Another Weather Module:
                        Haha i promise, i wont tell a soul lol! Looking forward for the update!
                        I also found out today i had excellently messed up my custom.css when trying to backup things.
                        So i think that that one could had unable me to adjust the wFont.
                          Няма проблем моят приятел :^)
                          • tbbearT Offline
                            tbbear Module Developer
                            i love ur weather modul but i am from Germany so a few settings do not fit for my country.
                            i already made a few changes to fix them so maybe i can help u in ur german version. Also u should
                            update ur readme cause it took me a long time to find out where to get the key for the air values.
                            I made a new translation for ur module according to the french one and i also changed a few lines in ur xx.js.
                            Please let me know if its ok and u maybe like assistance for ur german version.
                            "GATHERING WEATHER STUFF": "Empfange Wetterdaten...",
                            "Currently: ": "Aktuell: ",
                            "Current Temp: ": "Momentane Temperatur: ",
                            "UV Index: ": "UV-Index: ",
                            "Wind: ": "Wind: ",
                            "From: ": "von: ",
                            "Barometer: ": "Barometer: ",
                            "Monday": "Montag",
                            "Tuesday": "Dienstag",
                            "Wednesday": "Mittwoch",
                            "Thursday": "Donnerstag",
                            "Friday": "Freitag",
                            "Saturday": "Samstag",
                            "Sunday": "Sonntag",
                            "Overcast": "Bedeckt",
                            "Cloudy": "Wolkig",
                            "Rain": "Regen",
                            "Clear": "Klar",
                            "Partly Cloudy": "Teilweise bewölkt",
                            "Snow showers": "Schneeschauer",
                            "High:  ": "Hoch: ",
                            "Low:  ": "Niedrig: ",
                            "Humidity: ": "Feuchtigkeit: ",
                            "Safe": "Sicher",
                            "Moderate": "Moderat",
                            "Very High": "Sehr hoch",
                            "Extreme": "Extrem",
                            "Sunset": "Sonnenuntergang",
                            "Sunrise": "Sonnenaufgang",
                            " hours ": " Std. ",
                            " minutes ": " Min. ",
                            "Amount of Daylight": "Stunden mit Tageslicht",
                            "Good Morning ":"Guten Morgen ",
                            "Good Afternoon ": "Guten Nachmittag ",
                            "Good Evening ": "Guten Abend ",
                            "Air Quality Index: ":"Luftqualitätsindex: "
                            this was my new translation
                            and this i changed in your ...js
                            	var curCon = document.createElement("div");
                            	curCon.classList.add("xsmall", "bright");
                            	curCon.innerHTML = this.translate("Currently: ") + this.translate(current.weather);
                            	wrapper.appendChild(curCon);
                            Robert the Bear
                              cowboysdude Module Developer @tbbear
                              @tbbear said in MMM-NOAA - Another Weather Module:
                              “GATHERING WEATHER STUFF”: “Empfange Wetterdaten…”,
                              "Wind: ": "Wind: ",
                              "From: ": "von: ",
                              “Monday”: “Montag”,
                              “Tuesday”: “Dienstag”,
                              “Wednesday”: “Mittwoch”,
                              “Thursday”: “Donnerstag”,
                              “Friday”: “Freitag”,
                              “Saturday”: “Samstag”,
                              “Sunday”: “Sonntag”,
                              “Overcast”: “Bedeckt”,
                              “Cloudy”: “Wolkig”,
                              “Rain”: “Regen”,
                              “Clear”: “Klar”,
                              “Partly Cloudy”: “Teilweise bewölkt”,
                              “Snow showers”: “Schneeschauer”,
                              "High: ": "Hoch: ",
                              “Safe”: “Sicher”,
                              “Moderate”: “Moderat”,
                              “Very High”: “Sehr hoch”,
                              “Extreme”: “Extrem”,
                              “Sunset”: “Sonnenuntergang”,
                              “Sunrise”: “Sonnenaufgang”,
                              “Amount of Daylight”: “Stunden mit Tageslicht”,
                              So this is German? :)
                              Nystro0mN 1 Reply Last reply Reply Quote 2
                              • Nystro0mN Offline
                                @cowboysdude Haha yes! That is for sure German :)
                                  @Nystro0m LOL right now I barely know what direction I’m going… I am SO busy with work… I will make the changes… LOL
                                  Would be SUPER easier if it were done on github with a pull request ;)
                                  • Nystro0mN Offline
                                    Nystro0m
                                    @cowboysdude Im reinstalling my Mirror to .2.10 through ssh. So alot of waiting. Got a fresh cup of tea. Im on IT!
                                    Mykle1M cowboysdudeC 2 Replies Last reply Reply Quote 2
                                      Mykle1 Project Sponsor Module Developer @Nystro0m
                                      Don’t forget Electron 1.4.15.
                                      Tea just won’t get it done for me after today! :^)
                                      • Nystro0mN Offline
                                        Nystro0m @Mykle1
                                        @Mykle1 And all the modules etc.
                                        I started of migrating all of my modules and main css-changes to a custom CSS.
                                        And now this gah, i will grab a beer after this tea. That will do it!
                                          @Nystro0m You have NO idea how much I appreciate that! THANK YOU and Tea is the nectar of the gods :)
                                          Nystro0mN 1 Reply Last reply Reply Quote 1
                                          • Nystro0mN Offline
                                            @cowboysdude No worries!
                                            Im not sure about this one that @tbbear. So i leave that to you.
                                            • 34
                                            • 35
                                            • 4 / 35
