    690 Posts 77 Posters 3.3m Views 70 Watching
    • Mykle1M
      @cowboysdude said in MMM-NOAA - Another Weather Module:
      Merged the pull request! :)
      He ran all the way home just to fix his module.
      Yeah, he’s that good! :^)
      And, well done @barnosch !
        barnosch
        thanks guys. Very nice to have some guys like you here. Like this it’s fun.
          pjkoeleman @cowboysdude
          Please PM me if you’d be interested in making any other translation files for this
          Just send you the dutch translation by Github. Don’t now if I did it the right way, so here it is as well.
          "GATHERING WEATHER STUFF": "Ontvangen weerdata...",
          "Currently: ": "Actueel: ",
          "Current Temp: ": "Huidige temperatuur: ",
          "UV Index: ": "UV-Index: ",
          "Wind: ": "Wind: ",
          "From: ": "van: ",
          "Barometer: ": "Barometer: ",
          "Monday": "Maandag",
          "Tuesday": "Dinsdag",
          "Wednesday": "Woensdag",
          "Thursday": "Donderdag",
          "Friday": "Vrijdag",
          "Saturday": "Zaterdag",
          "Sunday": "Zondag",
          "High:  ": "Hoog: ",
          "Low:  ": "Laag: ",
          "Humidity: ": "Luchtvochtigheid: ",
          "Safe": "Veilig",
          "Moderate": "Gemiddeld",
          "Very High": "Zeer hoog",
          "Extreme": "Extreem",
          "Sunset": "Zonsondergang",
          "Sunrise": "Zonsopgang",
          " hours ": " Uren ",
          " minutes ": " Minuten ",
          "Amount of Daylight": "Aantal uren daglicht",
          "Good Morning ":"Goedemorgen ",
          "Good Afternoon ": "Goedenmiddag ",
          "Good Evening ": "Goedenavond ",
          "Air Quality Index: ":"Luchtkwaliteitsindex: "
          • cowboysdudeC
            cowboysdude Module Developer @pjkoeleman
            @pjkoeleman Huge Thanks!!
            NOW with Dutch Language :)
            Download:
            [card:cowboysdude/MMM-NOAA]
            P 1 Reply Last reply
              @cowboysdude
              You’re welcome
              • Nystro0mN
                Nystro0m
                @cowboysdude
                I got a error after the update with following:
                /home/pi/MagicMirror/modules/MMM-NOAA/MMM-NOAA.js:399
                SyntaxError: Unexpected token ===
                I removed the ====== on line 399 with success to get the module working.
                Im not sure if this is just on my side, im still new to this. But i thought it could good to be shared.
                Edit: This could make a problem with updating the the module. I experience the clock getting stuck from time to time.
                  pjkoeleman @Nystro0m
                  @Nystro0m
                  Looks to me that there is two times the same code in the js-file ecxept for the language settings. So @cowboysdude has to look into this.
                  Mykle1M 1 Reply Last reply
                  • Mykle1M
                    Mykle1 Project Sponsor Module Developer @pjkoeleman
                    @pjkoeleman said in MMM-NOAA - Another Weather Module:
                    He’s doing a roofing job in 90° heat at the moment. On a Sunday! Who does that?
                    I’m sure he’ll fix it as soon as possible. That’s what he does.
                    • cowboysdudeC
                      @Nystro0m and @pjkoeleman
                      Thank you both!!! IT was doubled, not sure how that happened but all fixed!! :)
                      Nystro0mN 1 Reply Last reply
                        Johans
                        installed module last night, settings all according the help file, but nothing is displayed.
                        Switched back to the wunderground module, that’s working fine.
                        any idea. I suppose that when the API key is working with the Wunderground module it should work with yours too.
                        what information do i need to provide for further investigation - also tell me how to get that. (I’m newbee - sorry for this - i’m in a learning process )
                        (language was set to “nl” and then changed again to “en”).
                        And I see module is loaded, but not displayed.
                        cowboysdudeC Nystro0mN 2 Replies Last reply
                        • cowboysdudeC
                          cowboysdude Module Developer @Johans
                          @Johans check the console log and see what that tells you when it’s loading…
                          You need to start your mirror and hit the ‘ALT’ key there will be a menu at the top…you want ‘toggle developer…’
                          That’ll open up a side panel on the right and it will tell you what error there is…let me know so I can help you fix it :)
                          J 1 Reply Last reply
                          • Nystro0mN
                            Nystro0m @Johans
                            @Johans
                            Im running on a Raspberry pi B ver.1 and it have some problems loading information from time to time when it been pushed to far.
                            I would make sure that it is no error in the console from NOAA or other modules:
                            Either by Comwboysdude method, but you could also run: “npm start dev” when starting MagicMirror.
                            Another way that i did find more speed efficient is to open the MagicMirror interface on a secondary computer by going to: “Your.PI.LocalIP:8080/”.
                            And then right-click and choose “inspect” in Chrome. Here you can find the console.
                            Make sure to have your WhitelistIP set properly.
                            I could also recommend Jophys - Remote Control Module.
                            With this you can restart you MagicMirror, enter the web interface and such remotely if you are not comfortable with ssh.
                              Johans @Nystro0m
                              @Nystro0m
                              thanks, learned again something new, on how to remotely connect to the MagicMirror.
                              Meanwhile problem is solved.
                              removed the line 400.
                              these chars created an error ==========
                                Johans @cowboysdude
                                @cowboysdude
                                thanks for showing me how to track & trace errors.
                                Found root cause - line 400 in module MMM-NOAA.js.
                                I removed the =========.
                                Also added the “nl”: “nl-NL” into the lang file section.
                                So now it’s all working - and in dutch - makes my wife happy :).
                                Very beautifull - thanks for you support.
                                • cowboysdudeC
                                  @Johans said in MMM-NOAA - Another Weather Module:
                                  @cowboysdude
                                  You are welcome… yes I fixed that on Github
                                  Thank you!!! :)
                                  Glad you made your wife happy! We have a saying here…
                                  “Happy wife, happy life.” HAHAA
                                  • Nystro0mN
                                    Nystro0m @cowboysdude
                                    @cowboysdude
                                    This update made messed up the CSS a bit, this screenshot is from default main.css and NOAA.css
                                    alt text
                                    The table content regarding the forecast data is fixed by:
                                    .MMM-NOAA .tdh{
                                    display: table;
                                    That also make it align to the right, fixing a problem where the are not align properly if the lowest/highest temperature indexing inconsistent between tenths and some bellow (adding a number) for example :
                                    (up) 10 (down) 8
                                    (up) 16 (down) 11
                                    Also, wFont does not response to font-size anymore. Im currently investing in this.
                                    .MMM-NOAA .wFont {
                                    And the barometer logo i can’t seem to find the resize option, i got around this by manipulating to core image.
                                    I would also appriciate if there is a possibility to could change the “daylight”, “uv-index” and “humidify” colors in the .css.
                                    Here are a Swedish translation for “Amount of daylight”:
                                    Tillgängligt dagsljus
                                    I found that this already consist in the translation-file. Does not seem to be loading for me.
                                    • cowboysdudeC
                                      cowboysdude Module Developer @Nystro0m
                                      @Nystro0m Something is wrong with the layout… I’ll look at this later. Sorry about that.
                                      What version of MM are you running? My dev machine is running 2.1.0 so that may be a reason you’re having issues… if you’re running a newer version so I just learned [Thanks @Mykle1]
                                      Nystro0mN Mykle1M 2 Replies Last reply
                                      • Nystro0mN
                                        @cowboysdude
                                        No worries. Im running the latest version of MM and NOAA.
                                        There is no hurry, i have customized the css to fit my need for now :)
                                        Happy to help out if there is something you need to be tested etc.
                                        Reply Quote 2
                                        • cowboysdudeC
                                          @Nystro0m said in MMM-NOAA - Another Weather Module:
                                          @cowboysdude
                                          We tried running it on the dev version of the mirror and it had lots of errors LOL
                                          BUT that is a dev version… I’m running 2.1.0 because it runs on windows without having to do git bash windows stuff … I try running newer versions of MM but I just get all kinds of errors with MM and it won’t run so back to 2.1.0…
                                          If I need anything I’ll let you know and I do appreciate your help!! :) Thank you!
                                          [PS I am working on an update …changing the format of the bottom 4 day forecast ;) Shhhhh don’t tell anyone hahahahahha].
                                          • Nystro0mN
                                            Haha i promise, i wont tell a soul lol! Looking forward for the update!
                                            I also found out today i had excellently messed up my custom.css when trying to backup things.
                                            So i think that that one could had unable me to adjust the wFont.
                                            • 34
                                            • 35
                                            • 4 / 35
