    MMM-aviationwx (Aviation weather)
    111 Posts 12 Posters 146.1k Views 11 Watching
      Mykle1 Project Sponsor Module Developer @stephenmelody
      @stephenmelody said in MMM-aviationwx (Aviation weather):
      Standard: VFR-Blue MVFR-Green IFR-Yellow LIFR-Red Unknown-Grey
      Alternative: VFR-Green MVFR-Blue IFR-Red LIFR-Magenta Unknown-Grey
      Thanks for doubling my workload, Stephen. :-)
        allebone
        This is amazing collaboration. Anyone interested in hammering out a CSS/Config that would work well for an FBO or Flight Ops Office to coincide with this module? We have the Base Ops Office here, and its needed a good weather, NOTAMS, Ops Notes display for visiting people. I am pretty sure every FBO out there would love to have something too.
        Would be nice to config it up to where its just change ICAO and surrounding field ICAOs to get a workable display.
        We have actually talked recently about how we’d display an Airfield Diagram, but color code the RCR for all the Taxi-ways. We have limits to where we can taxi on Ice/Slush here in the Midwest, so it’d be nice to visualize. However, I haven’t begun to figure out how to crack that nut. (STS). :)
        Bryan
          stephenmelody
          @allebone - what colour scheme do you use for IFR/VFR/MVFR/LIFR? Personally I prefer the alternative one that I have called out above.
          @Mykle1 - no problem, always here to make life harder :-D
          Here’s another option that might be of interest, as it’s JSON format…
          https://www.icao.int/safety/iStars/Pages/API-Data-Service.aspx
            stephenmelody
            @allebone @Mykle1
            This would give you the NOTAM information…
            https://www.npmjs.com/package/notams
            METAR / TAF:
            https://www.npmjs.com/package/metar-taf
            https://www.npmjs.com/package/metar-js
            Don’t know if they help…?
              Would the text coloured per the rules work the same as a coloured circle? Yes - although a circle would be better for screen real estate I would imagine…
              Ok, I’ve coded the “Alterative” color scheme just now, as you’ve described it, using generic colors. You will get the corresponding colored circle depending on the Flight Rule. What I would like from you are HEX color codes for those five colors that work best against the black background. For instance, you may want a lighter blue as the generic blue is a little hard to see. Agreed?
              • cowboysdudeC Offline
                I would like #FCDFFF, #FAAFBA, #E45E9D, #FFFF00 and #87F717
                  stephenmelody
                  Is it in a CSS file? That way I’m guessing people could self-configure?
                  Here’s what the original module is using and it looks like the below.
                  .vfr {
                    color: green;
                  .mvfr {
                    color: blue;
                  .ifr {
                    color: red;
                  .lifr {
                    color: #f0f;
                  Blue looks ok through my glass, so I don’t see any issue with that.
                  alt text
                    Mixing color names and hex colors…bad format. I’d stick with hex and people can still change them
                      @stephenmelody
                      What are the last 2 entries on each line
                      10/-1 and (20:51)
                        stephenmelody
                        10 degrees C temperature / -1 degrees C dew point (time of report)
                          @Mykle1 said in MMM-aviationwx (Aviation weather):
                          @stephenmelody
                          10/-1 and (20:51)
                          Red and pink LOL
                            You would like that the same? Delete or move Altimeter?
                              @cowboysdude said in MMM-aviationwx (Aviation weather):
                              Red and pink LOL
                              Hot pink? :-)
                                stephenmelody
                                the format on that image is:
                                Wind direction @ wind speed: 220@05kt
                                Visibility: 10SM 10 statute miles
                                Sky Coverage: OVC - overcast, BKN - broken etc…
                                Cloud base: 150(00)ft
                                Temp: 10 degrees C
                                Dewpoint: -1 degrees C
                                Time of the report in 24 hour clock: 20:51
                                I’d say (personal opinion) that the pressure/altimeter setting isn’t that important. I’d prefer to keep the additional information, if you look at FDY and TBR above, they have:
                                -RA which is showers of rain
                                BR - which is fog (or haze, I can’t remember… 70% sure it’s fog, either way you can’t see through it well)
                                That to me is more important that the altimeter setting.
                                I can look for other examples if that would help?
                                  Nope, that’s good for now
                                    @stephenmelody
                                    How would I denote visibility if this is the data ?
                                    Visibility:1500
                                    Simply 1500? v1500? vis? other?
                                      stephenmelody
                                      Do you have an example airport you’re getting that from? Is it outside of the US where viz is usually XXSM?
                                        @stephenmelody
                                        https://avwx.rest/api/metar/uudd
                                        EDIT> My bad, that’s miles
                                          I thought that was the whole idea for this module, that it would be international, yes?
                                            stephenmelody
                                            Russian Viz is in metres, so they’d want to see 1500m I’m guessing.
                                            That’s the problem, you’re creating the ability to call weather from international airports but each country / region reports differently. The good thing with AVWX is it tells you the unit to use, so you could just append after the value the unit identifier, so in your example you have:
                                             "Visibility": "9999",
                                            and in the units section:
                                            "Visibility": "m",
                                            so you could concatenate it to be:
                                            visibility: 9999m
                                            Does that make sense? Have I answered the question?
                                            • 3 / 6
