    Update Error of v.2.2.0 :(
    21 Posts 11 Posters 21.8k Views 8 Watching
    • foxF Offline
      fox
      And again, the next Magic Mirror update failed at me and broke my MM completely :(
      My fault, i “accidently” clicked on the update button in the MMM-remote…
      Bild Text
      And with
      npm start dev:
      > magicmirror@2.2.2 start /home/pi/MagicMirror
      > sh run-start.sh "dev"
      /home/pi/MagicMirror/node_modules/electron/index.js:9
        throw new Error('Electron failed to install correctly, please delete node_modules/' + path.basename(__dirname) + ' and try installing again')
      Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
          at Object.<anonymous> (/home/pi/MagicMirror/node_modules/electron/index.js:9:9)
          at Module._compile (module.js:571:32)
          at Object.Module._extensions..js (module.js:580:10)
          at Module.load (module.js:488:32)
          at tryModuleLoad (module.js:447:12)
          at Function.Module._load (module.js:439:3)
          at Module.require (module.js:498:17)
          at require (internal/module.js:20:19)
          at Object.<anonymous> (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
      npm ERR! Linux 4.9.56-v7+
      npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start" "dev"
      npm ERR! node v7.10.1
      npm ERR! npm  v4.2.0
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! magicmirror@2.2.2 start: `sh run-start.sh "dev"`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.2.2 start script 'sh run-start.sh "dev"'.
      npm ERR! If you do, this is most likely a problem with the magicmirror package,
      npm ERR! not with npm itself.
      npm ERR!     sh run-start.sh "dev"
      npm ERR!     npm bugs magicmirror
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!     npm owner ls magicmirror
      Issues With MMM-WatchDog known?
      https://forum.magicmirror.builders/post/29827
      Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
      • bheplerB Offline
        bhepler Module Developer @fox
        @fox Did you try reinstalling electron via the instructions given? ie, delete /home/pi/MagicMirror/node_modules/electron and reinstalling?
        This should be close:
        cd /home/pi/MagicMirror/node_modules
        sudo rm -rf electron
        cd ..
        npm install electron@1.4.15
        After that, I suspect a npm install and then npm start.
        foxF O F 3 Replies Last reply Reply Quote 1
        • foxF Offline
          fox @bhepler
          @bhepler
          thank you for your reply.
          Everything worked until the last command.
          Then i got
          pi@magicpi:~/MagicMirror $ npm build && npm start
          > sh run-start.sh
          Starting MagicMirror: v2.2.2
          Loading config ...
          Loading module helpers ...
          Module helper loaded: MMM-cryptocurrency
          Module helper loaded: MMM-Wunderlist
          Module helper loaded: MMM-ModuleScheduler
          WARNING! Could not load config file. Starting with default configuration. Error        found: Error: Module version mismatch. Expected 50, got 54.
          App threw an error during load
              at Error (native)
              at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:173:20)
              at Object.Module._extensions..node (module.js:583:18)
              at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:173:20)
              at Module.load (module.js:473:32)
              at tryModuleLoad (module.js:432:12)
              at Function.Module._load (module.js:424:3)
              at Module.require (module.js:483:17)
              at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bindin        gs/bindings.js:76:44)
              at Error (native)
          MagicMirror will not quit, but it might be a good idea to check why this happene        d. Maybe no internet connection?
          If you think this really is an issue, please open an issue on GitHub: https://gi        thub.com/MichMich/MagicMirror/issues
          Launching application.
          But it does not start.
          I did also
          pi@magicpi:~/MagicMirror $ npm list | grep electron
          ├─┬ electron@1.4.15
          │ ├─┬ electron-download@3.3.0
          │ ├─┬ electron-chromedriver@1.7.1
          │ │ └─┬ electron-download@4.1.0
          │ │ │ └─┬ electron-to-chromium@1.3.30
          │ │ │   └── electron-releases@2.1.0
          pi@magicpi:~/MagicMirror $ npm rebuild --runtime=electron --target=1.4.15 --disturl=https://atom.io/download/atom-shell --abi=50
          • bheplerB Offline
            This thread should help: https://forum.magicmirror.builders/post/7634
            foxF 1 Reply Last reply Reply Quote 0
            • foxF Offline
              fox @bhepler
              @bhepler
              I tried the commands of the thread it, but no effect… Any help ?
              • H Offline
                hoddog
                Same problem here. After yesterday’s update (git hub && npm install) two modules (MMM-PIR and MMM-MyCommute) has wrong version (except 50, got 48). After launching screen is just black. I’ve tried to update electron (npm rebuild --runtime=electron --target=1.4.15 --disturl=https://atom.io/download/atom-shell --abi=50)but nothing changed. How to start it?
                foxF F 2 Replies Last reply Reply Quote 0
                • foxF Offline
                  fox @hoddog
                  @hoddog Here is my result: https://forum.magicmirror.builders/post/33238
                  • H Offline
                    hoddog
                    Should I wait for new update or install everything from beginning?
                    • MichMichM Offline
                      MichMich
                      What you could try:
                      • backup your module folder.
                      • backup your config file
                      • remove MagicMirror
                      • reinstall
                      • put modules & config back.
                      F P 2 Replies Last reply Reply Quote 0
                      • H Offline
                        hoddog
                        So i’ve used solution from here:
                        https://forum.magicmirror.builders/topic/6045/black-screen-after-install-update-v2-2?page=1
                        For my not working modules.
                        And it works. Mirror started… Huuuh.
                        Thank you mr ryck!
