    Update Error of v.2.2.0 :(
    21 Posts 11 Posters 23.7k Views 8 Watching
    • H Offline
      hoddog
      Should I wait for new update or install everything from beginning?
      • MichMichM Offline
        MichMich
        What you could try:
        • backup your module folder.
        • backup your config file
        • remove MagicMirror
        • reinstall
        • put modules & config back.
        F P 2 Replies Last reply Reply Quote 0
        • H Offline
          hoddog
          So i’ve used solution from here:
          https://forum.magicmirror.builders/topic/6045/black-screen-after-install-update-v2-2?page=1
          For my not working modules.
          And it works. Mirror started… Huuuh.
          Thank you mr ryck!
          • F Offline
            Fonfon @hoddog
            @hoddog said in Update Error of v.2.2.0 :(:
            Same problem here. After yesterday’s update (git hub && npm install) two modules (MMM-PIR and MMM-MyCommute) has wrong version (except 50, got 48). After launching screen is just black. I’ve tried to update electron (npm rebuild --runtime=electron --target=1.4.15 --disturl=https://atom.io/download/atom-shell --abi=50)but nothing changed. How to start it?
            Same problem same modules
            solution ?
            • F Offline
              fox
              I did a complete reinstall. This was the last time that i did an Update of the Magic Mirror :)
              This happend with every update till now.
              Issues With MMM-WatchDog known?
              https://forum.magicmirror.builders/post/29827
              Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
              • O Offline
                open_book @bhepler
                @bhepler @fox I had the same problem and followed the steps here to reinstall electron. It worked for me without further changes.
                Thanks!
                sudo insert motivational.quote
                • F Offline
                  Fonfon @bhepler
                  • F Offline
                    Fonfon @MichMich
                    @MichMich Hi,
                    i backup my modules folder and my config folder
                    i delete MagicMirror folder
                    reinstall MagicMirror
                    copy/paste modules &config folders
                    i do that but same error on the same module
                    i don’t understand why
                    i need some help please
                    thanks
                    • F Offline
                      Fonfon
                      why update do that ?
                      need to reinstall all modules
                      now its good …
                        PRECIOUS VIRAL @MichMich
                        @MichMich How to solve this error?
                        pi@PrivatePiNetwork:~/MagicMirror $ git pull && npm install
                        Updating b799609…20823bf
                        error: Your local changes to the following files would be overwritten by merge:
                        fonts/package.json
                        modules/default/clock/clock.js
                        modules/default/currentweather/currentweather.js
                        modules/default/weatherforecast/README.md
                        Please, commit your changes or stash them before you can merge.
                        error: The following untracked working tree files would be overwritten by merge:
                        fonts/package-lock.json
                        package-lock.json
                        vendor/package-lock.json
                        Please move or remove them before you can merge.
                        Aborting
                          afedriansyah
                          hey I’ve been trying to install the magic mirror from https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash and once I clicked enter and this message appeared0_1546483547246_magicmirror.jpg
                          anyone any ideas how to solve this. a helpful answer and guide would be appreciated
                            SoleLo @open_book
                            @open_book How do you remove and reinstall the electron?
                              shbatm Module Developer @afedriansyah
                              @afedriansyah it looks like you already have it cloned to the directory, if you really really want to start fresh (WARNING WILL DELETE YOUR EXISTING INSTALLATION): rm -R ~/MagicMirror and then rerun the script. If you just want to upgrade, after the git pull, do npm install.
                              Finally, I wouldn’t recommend running MM as root, unless you know what you’re doing…
                                mdhenriksen @afedriansyah
                                @afedriansyah I’ve read that there might be some issues with the automatic installer in the Pi. If you do a re-install and it doesn’t work, try a manual install. All the instructions are on the GitHub page. ☺️
