    Update Error of v.2.2.0 :(
    21 Posts 11 Posters 22.0k Views 8 Watching
    • foxF Offline
      fox @bhepler
      @bhepler
      I tried the commands of the thread it, but no effect… Any help ?
      Issues With MMM-WatchDog known?
      https://forum.magicmirror.builders/post/29827
      Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
      • H Offline
        hoddog
        Same problem here. After yesterday’s update (git hub && npm install) two modules (MMM-PIR and MMM-MyCommute) has wrong version (except 50, got 48). After launching screen is just black. I’ve tried to update electron (npm rebuild --runtime=electron --target=1.4.15 --disturl=https://atom.io/download/atom-shell --abi=50)but nothing changed. How to start it?
        foxF F 2 Replies Last reply Reply Quote 0
        • foxF Offline
          fox @hoddog
          @hoddog Here is my result: https://forum.magicmirror.builders/post/33238
          • H Offline
            hoddog
            Should I wait for new update or install everything from beginning?
            • MichMichM Offline
              MichMich
              What you could try:
              • backup your module folder.
              • backup your config file
              • remove MagicMirror
              • reinstall
              • put modules & config back.
              F P 2 Replies Last reply Reply Quote 0
              • H Offline
                hoddog
                So i’ve used solution from here:
                https://forum.magicmirror.builders/topic/6045/black-screen-after-install-update-v2-2?page=1
                For my not working modules.
                And it works. Mirror started… Huuuh.
                Thank you mr ryck!
                • F Offline
                  Fonfon @hoddog
                  @hoddog said in Update Error of v.2.2.0 :(:
                  Same problem same modules
                  solution ?
                  • foxF Offline
                    fox
                    I did a complete reinstall. This was the last time that i did an Update of the Magic Mirror :)
                    This happend with every update till now.
                    • O Offline
                      open_book @bhepler
                      @bhepler @fox I had the same problem and followed the steps here to reinstall electron. It worked for me without further changes.
                      Thanks!
                      sudo insert motivational.quote
                      • F Offline
                        Fonfon @bhepler
